a hambers websites list; or every site you need to know about
Discussion in 'The Hokey Ass Message Board' started by atch, Jan 6, 2006.
  1. crackernutz
    crackernutz
    from tx
    good cadillac database
    www.cadillaclasalleclub.org/
  2. 53choptop
    53choptop
  3. Im draggin this back to the top.....forgot how much good stuff was on this,Thanks even if it is YEARS old!
  4. atch
    atch
    here's a site i've had bookmarked for quite a while, but it's not strictly "technical" in nature so i never put it on here. very interesting none-the-less.
    twin engine dragsters
  5. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
  6. PegLegStrick
    PegLegStrick
    Gonna bump this back to the top for the FNGs
  7. 52 csb
    52 csb
    Thanks atch again everybody else too.. Finally got it bookmarked will print some of it.... CHEERS to the HAMB....52 csb:D:D:D:D:D:D:D:D
  8. elrobo818
    elrobo818
  9. Blown Mopar
    Blown Mopar
    from abc
    atch, you and Brad54 have done a lot of work. Thanks.
  10. RoadkillCustoms
    RoadkillCustoms
    from Mesa, AZ
    Reference:
    Automotive Math Formulas and Conversions
    Decimal Equivalents of Common Fractions
    Wire / Sheet Metal Gauge Inch Equivalents
    Guide to Metal Types and Properties
    Hot Rod Glossary
    OBDII Diagnostic Trouble Code Database
    Dictionary of Automotive Terms
    Dictionary of Historic Automotive Terms
    Welding Theory and Application Reference
    Body
    GM Body Style Codes
    Mopar Body Style Codes
    Drive Train
    Transmission Cross Reference Database
    Transmission Dimensions
    Transmission Ratios
    Differential Identification
    Differential Gear Ratio Calculator
    Axle Flange Housing Identification
    Selecting Proper Rearend Gear Ratio
    Determining Engine and Pinion Angle
    Speed Potential Calculator for Ring Gear and Pinion Changes
    Speedometer Calibration / Tire Size Change Calculator
    Wheel Bolt Pattern Reference
    Wheel Bolt Pattern Cross Reference Database
    Tire Size Comparison Calculator
    Tire Size Calculator
    How To Read A Tire Sidewall
    Frame / Ch***is
    Wheelbase Measurements for Popular Cl***ic/Vintage Cars
    Determining Ride Height
    Suspension Coil Spring Rate Calculator
    Early Ford Beam Axle Dimensions
    Rear End Widths
    Engine
    Engine Displacement Calculator
    Horsepower Gain from Additional Blower Pressure Calculator
    Determine Your Small Block Chevy Water Pump Type
    Connecting Rod Ratios
    Chevrolet Engine Block Numbers
    Ford Engine Block Numbers
    Mopar Engine Block Numbers
    Engine Motor Horsepower Estimate Calculator - Trap Speed
    Engine Motor Horsepower Estimate Calculator - Elapsed Time ET
    Automobile Fuel Economy Efficiency Comparison Calculator
    OBD-II Diagnostic Trouble Code Database
    Exhaust
    Recommended Exhaust Tubing Sizes
    Electrical
    Guide to Wire and Fuses
    Test Center
    Master Cylinder Test
    Power Brake Booster Test
    Paint
    Automotive Paint Glossary
    Automotive Paint Troubleshooting
  11. bjinx
    bjinx
    It has been several months since this thread has been bumped. It has helped me many times, so enjoy.
  12. grits
    grits
    btt for the newbies
  13. drfreeze
    drfreeze
    This needs to be in it's own section .....awsome info !
  14. norms30a
    norms30a
    Wow, bookmarked for sure!!!!
  15. 1960CHEVY
    1960CHEVY
    A Great Resource ! Thanks for everyone's research.
  16. retiredfireguy
    retiredfireguy
    Great list. Checked out some of the links. Most were good. One turned out to be an unrelated adverti*****t.
  17. cruzincougar
    cruzincougar
    A lot of great info!!
  18. Rice n Beans Garage
    Rice n Beans Garage
    Excellent info, Thanks
  19. Smokin' Joe
    Smokin' Joe
    WOW!!! What a wealth of GREAT info!!!
  20. GPR
    GPR
  21. Russ V.
    Russ V.
    I hate to show how dumb I am with computers....but, how do I save all this valuable info?? What is bookmarking?? :confused: Can I somehow save the entire thread??:confused:
    Sorry for the numb questions, but others may be in the same computer-challenged shape that I am in. Lots of great info that should be at our fingertips.:rolleyes:
    And, thanks for all the effort to catalog the info.
    Russ V.
  22. superchiicken
    superchiicken
    maybe subcribed to the thread. see the box above ^^^^ " thread tools " box , click and then subcribed to it. it will save it to ur profile .
  23. Donnda
    Donnda
    Exelent thread have subscribed
  24. atch
    atch
    hi, folks.
    me again.
    i just received a pm from vince falter of fordgarage.com. in the very first page of this post, where i copied brad54's old post into this new one, there was a link to broken stud removal which originated in fordgarage.com. it's the 27th (+/-) link in the post.
    his site has now changed names and URLs, and the link originally shown in the post is now broken. i've went back and edited the link and now it will work again.
    as i said above, brad54 originated the first version of this thread and he gets the credit for finding the link. however, i can tell you that i've tried this trick since originally seeing it and IT WORKS!
  25. retiredfireguy
    retiredfireguy
    Great tip! Thanks for sharing it.
  26. atch
    atch
    over on the Garage Journal Stuart in MN just posted up the link to the bolt reference charts on boltdepot.com. pretty cool.
    here's a short clip that describes that these do:
    "These PDF charts, tables, and other printable tools will help you identify the size and type of fastener you are looking for. Feel free to print them for your reference.
    Lay-over Charts
    After printing, lay your fasteners directly on these full size charts to identify them."
  27. weps
    weps
    from auburn,IN
    Thanks for taking the time to do this.:D
  28. hasty
    hasty
    Fantastic thread - thank you.
    I tried this link above without any luck. Also typed in the address. Any other ways to get into this site?
