Technical A hole in my head...
Discussion in 'Traditional Hot Rods' started by zz29, Dec 2, 2018.
  1. zz29
    zz29
    I am a newbie, but I’m going to ***ume the block in the Big Block Chevy needs a hole as much as I need one in my head.
    I was giving the 29 Phaeton a good engine cleaning before I fill it up and put it away for the winter, when I noticed that next to the valve cover there was a rusty hole. Its big enough to stick a carpenter pencil in at an angle, and goes in for at least half inch. I also noticed that right in that spot there seems to be a piece of some material adhered to it. Like the thickness of a gasket. Almost like it perhaps was patched? Is that a thing? Hope the pics help. I have a feeling the HAMBERS will tell me the block is shot. :-( IMG_5674.JPG [​IMG][​IMG][​IMG]
  2. Mr48chev
    It's right over the manifold heat p***age but it is also in a spot where someone in the past might have used a pry bar to try to pop the manifold off.
    Over the past 50 something years I've seen a number of engine parts that suffered the ravages of the big pry bar and got broken or damaged in the process.
    At first I thought it was part of the gasket that had squeezed out.
  3. zz29
    zz29
    I looked at it again, since I’m new at this, and I guess the hole would technically be in the “head”; it’s not in the manifold and not the block. Seems I could swap that out. If I knew how to do it.
  4. Fordors
    Fordors
    It’s been years since I had a BBC but it looks like your OK. There is a depression in the casting both above and below the exhaust heat crossover p***age and the gasket just got “cooked” and has a hole poked in it.
    Google BBC head images and you will see what I’m referring to. The exhaust heat moves through the center hole, it is connected to an exhaust port. I have no idea why Chevy added those depressions but they are non-functional.
    classiccarjack likes this.
  5. blowby
    blowby
    from Nicasio Ca
  6. I have a deep space in the same place on my spare 454 truck block.
    It’s a heat riser p***age that the intake gasket covers up but yours looks like the gasket got ripped out.
    Don’t worry about it, won’t affect the running of the engine.
  7. Flingdingo
    Flingdingo
    As long as there’s no oil, coolant, or parts shooting out of it, you’re fine.
  8. classiccarjack
    classiccarjack
    Fordors is right... Mopar big blocks have it too. Nothing to worry about...
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
  9. squirrel
    this is what you're seeing...perfectly normal.
    F-ONE likes this.
  10. zz29
    zz29
    Learning so much on Youtube! Cylinder head and Mr48Chev you seem to be right that the hole is in the p***age for the manifold. Replacing these seems like a very involved project; remove carburetor, intake and exhaust manifolds, as well as the valve springs/rockers whatever they are. Geez that ****s.
  11. 57 Fargo
    57 Fargo
    If you took the time to read the above you would know there is absolutely nothing wrong with your engine, no repair needed.
    gimpyshotrods, F-ONE and X38 like this.
  12. zz29
    zz29
    Oh! For some reason I missed the response last night after getting lost in YouTube. Phew!! Well, I can breathe again. Thank you so much for taking the time to explain this to me. I’ll stop googling and getting freaked out. Thanks!!
