A little help identifying a small block please...
Discussion in 'The Hokey Ass Message Board' started by nash19d, Jul 12, 2012.
  1. nash19d
    nash19d
    from San Diego
    Proud new owner of a 71 Chevelle, only problem is I'm not quite sure what it is running, beyond the basics.... My numbers are:
    Partial Vin/ Code- 16S106183 / V0821CKT (I'm 98% it is a C and not a 0, O or D in the suffix)
    Block- 3970010
    Date- H205
    Composition- 010, 020, 178
    I've seen the Z28 site-
    CKT [FONT=Arial, Helvetica, sans-serif]1972[/FONT][FONT=Arial, Helvetica, sans-serif] 350 [/FONT][FONT=Arial, Helvetica, sans-serif]tur hydramatic [/FONT][FONT=Arial, Helvetica, sans-serif]LT1 [/FONT][FONT=Arial, Helvetica, sans-serif]255 [/FONT][FONT=Arial, Helvetica, sans-serif]4 [/FONT]Z28
    But the date stamp says 5.... 65' or 75'. That casting wasn't made in 65 (i think) and I don't think they were making engines for a 72 in 75?
    Thecamaroguy.com said this-
    <table cl***="pgtable" border="1"><tbody><tr><td>1970
    </td> <td>Chevelle
    </td> <td>396cid, Manual Trans.
    </td> <td>375
    </td> <td>
    CKT
    </td> </tr> <tr> <td>1970
    </td> <td>Nova
    </td> <td>396cid, Manual Trans. With Aluminum Heads.
    </td> <td>375hp
    </td> <td>
    CKT
    </td></tr></tbody></table>
    This excited the **** out of me, but also furthered my confusion.
    I can't find the suffix OKT, DKT, ect... I've tried the combos and none of it makes sense.
    Thank you guys for any and all help! It's much appreciated!
  2. first off 71 's are not traditional second a 396 is a bigblock if you posted a pic it may help chevy engine id numbers have allways been apain to figure out is it a two barrel?
    is the car stockish? its more then lickly a350 or a307 could be later 305
  3. squirrel
    CKT from 1976 is...hiding from me. They used a couple that were close that I can find, CKU and CKW and CKY.
    It is definitely a 1976 model year engine, with that partial VIN.
    And it is a small block guys, look at the block casting number
  4. Russco
    Russco
    from Central IL
    Like Squirrel Said the 1=Chevy the 6=76 model year the S=St Louis plant. All Vettes were made in STL CKX is a 76 Vette code for the L48 350 base vette motor maybe its a X instead of a T
  5. BONNEVILLE BOB 95
    BONNEVILLE BOB 95
    Block casting # is for a 350 c.i. '69-'79 I belive.
  6. nash19d
    nash19d
    from San Diego
    Here you go guys!
  7. squirrel
    I believed you about what the number say....but there were a lot of engine codes in the 70s, sometimes the books don't have everything.
    By that time there wasn't much difference in the 350 engines, they were pretty much all low compression smog motors. Trucks had 4 bolt mains, Vettes might have, or maybe not.
  8. nash19d
    nash19d
    from San Diego
    Tried to make it bigger?
  9. squirrel
    I don't think the letters are going to change, unless you do some real photoshopping.
  10. nash19d
    nash19d
    from San Diego
    There was also a M stamped sideways on the p***enger side towards the front?
  11. nash19d
    nash19d
    from San Diego
    Hahahaha I don't want them to change, I just wanna know what this puppy is.
  12. bob t!
    bob t!
    Engine casting is 69\79 350 cu.in. Date casting of H205 is sept. 20 1975 which was probly installed in a 1976 vehicle . CKT [if correct] shows as a 72 Camero.
  13. brad chevy
    brad chevy
    Like Squirrel said you have a basic 350 engine .That block was used from 68 to 79 in a lot of cars and trucks. About the only difference would be the ones put in trucks were 4-bolt mains. Heck if it runs good don't worry about it. I don't think there were enough Covettes made to account for everybody that claims theres came out of a Vette.
  14. nash19d
    nash19d
    from San Diego
    Yeah your right. It's a quality piece of metal and I guess that's all that matters. Thank you guys for all your help!
  15. nash19d
    nash19d
    from San Diego
    How much horse power do you think this thing has of now? You suppose it's a 5.7 L? I have some Magnaflow delta 40's on the way, and as soon as I pin down what kind of headers I need, they will be en rout as well.
    Only upgrades I can see-
    Edlebrock 1406
    Edlebrock Performer intake
    Red fan
    Bare with me guys, I'm by far no motor head so bare with me, decided this would be a cool hobby after I got out of the Army.
  16. squirrel
    You kind of need to find a nice muscle car forum to hang out at...we don't really do this "late model" (post 1964) stuff here.
    The casting number means it's a 350 block. that's 5.7 L for the young-uns.
    Factory hp was 160-210 depending on carb and cam.
