A little help please
Discussion in 'The Hokey Ass Message Board' started by Tim morrison, May 1, 2011.
  1. Tim morrison
    Tim morrison
    I think I know whats wrong, but not sure. What do y'all think?
    I have a 283 that I changed the heads on. After I made the change it is running like sh_t!! it is not even building enough vacuum to operate the power brakes. The engine was running great before I changed the heads. After the swap, it starts easy enough but it just won't run smooth or build enough vacuum. I think I have the distributor off a tooth or two.
    What do you all think?:eek:
  2. fossilfish
    fossilfish
    from Texas
    well you did something wrong. Distributor concern sounds like it could be it, Misplaced intake gasket maybe? Pull the plug, bring it up to tdc on the number one cylinder and check for distributor position. If that looks good then start the engine and spray some carb cleaner around the intake gasket area and see if the engine speeds up if not the intake is not leaking there.
    Timing? too much retard will do that. Wires in the right order?
  3. luckyuhaul
    luckyuhaul
    Check for vacuum leaks, did you use the rubber end rails?
    Timing should match up with prior settings if the distributor is timed OK.
    Valve adjusted correctly? Noises?
    Kind of need some more info, to help.
  4. Tim morrison
    Tim morrison
    all of the valves are adjusted correctly and all of the vacuum lines are new. i will check all of my intake and carb mounting gaskets for leaks. thanks for the heads up
  5. JOECOOL
    JOECOOL
    tim, take a propane torch and turn it on,don't light it ,and run it around the intake and carb base gaskets. It will bring the idle way up if they are leaking. It won't check the ubderside tho.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What heads did you install. Could have to large of a chamber and large runners that can reduce vac. signal.
  7. Giovanni
    Giovanni
    It probably wouldn't hurt to check your compression as well.
  8. RichG
    RichG
    My money's on either the carb base gasket or the intake manifold gaskets...
  9. tucknroll
    tucknroll
    from iowa
    x2 richg if valves are set right
  10. Tim morrison
    Tim morrison
    The new heads have a smaller chamber Thats why I changed them.
