A little progress on a Belly Tank build
Discussion in 'The Hokey Ass Message Board' started by patina steve, Sep 19, 2010.
  1. saucerhead
    saucerhead
    Who (name of shop and where it is) rolled the tubing into circles? Your build looks great!
  2. patina steve
    patina steve
    Linders Specialty Company
    St Paul, MN
    http://www.lscmetalfab.com/
  3. saucerhead
    saucerhead
    Thanks for the info.
  4. POLYFRIED 35
    POLYFRIED 35
    Too Cool !!! Very nice!
  5. 36tbird
    36tbird
    Steve, I have a tank from an Albatross, same vintage. I'm saving pics of your build for when I finally get started. If you don't mind me asking, where is that center mounted rack and pinion from? Also, what height person did you build for? Curious about the approximate measurement from the front axle to the rear, vertical roll cage supports? Thanks for the updates.
  6. patina steve
    patina steve
    The rack & pinion is from pro works 20 : 1 ratio
    http://www.pro-werks.com/partlist/951/
    I can't give you any measurements, I am traviling untill Feb 15 2011, contact me after that and I will take any measurements you need
  7. 36tbird
    36tbird
    Thanks, Steve. Besides the info on the r&p, the pre-bent roll cages look like they could be a great time saver. Look forward to contacting you mid-Feb. Happy holidays, Lou
  8. Really nice stuff! I love fabrication, making parts and welding -- you've done a fantastic job so far. Best of luck and hopefully the FlatCad team will see you on the salt next year!
    Dale
  9. blackjack21
    blackjack21
    from Denver, CO
    Steve it looks beautiful! Great to see the dream become a reality. Happy Holidays. BTW, I'm Nick Hardie's son.
    Best,
    -Tyler
  10. Steve, shoot me your Email and I will forward the PDF of DJs new Hans type device. Looks like it will work well in tight spaces.
  11. 94hoghead
    94hoghead
    Man! I'd love to build something like that! I just don't have the talent...
  12. Bearing Burner
    Bearing Burner
    from W. MA
    What size tubing did you use? What material?
  13. patina steve
    patina steve
    1 3/4" OD .134 wall dom tubing
  14. patina steve
    patina steve
    For the first time rolled the ch***is out into the sun today
  15. Thanks for the update Steve!
  16. 38FLATTIE
    38FLATTIE
    from Colorado
    Wow, Steve! I'm not sure how I missed this thread.
    Very nice work- I'm suscribed!
  17. shmoozo
    shmoozo
    from Media, PA
    That is one strong-looking cage.
  18. Brad54
    Brad54
    from Atl Ga
    That's awesome.
    What trans are you running? And more importantly, how many gears, and how are you shifting it?
    -Brad
  19. patina steve
    patina steve
    Still in the planing stage, but thinking 3 or 4 speed trany with all the gears removed except 2, hydraulic clutch, shift cable to trany linckage.
  20. Brad54
    Brad54
    from Atl Ga
    A couple buddies and I talked about building one for a little while, and I thought using a 4- or 5-speed internal-rail style trans would be the ticket.
    I thought I could bolt the stock ball-and-socket shifter (like a T-5 from a Mustang) in place, and up front next to my right arm, I could put another ball-and-socket shifter, and connect them with a piece of solid rod running along the hull, then bending at a 90-degree and going to the shifter on the trans.
    That's explained horribly, but I think it would work. Basically, it's two ball-and-socket style shifters, solidly connected with a rod and actuated in tandem.
    -Brad
  21. We are going to run a 3 speed (unless a 4 shows up) with reverse removed. I am going to copy the simple and effective Jack Kelly Bellytank and run a Hurst shifter up front with Morse Cables connecting the ******. No monkey motion needed.
    Scroll down on Sumners site
    http://purplesagetradingpost.com/sumner/bvilleother/page 9.html
  22. Dr Goggles
    Dr Goggles
    First of all great build Steve. Now ,a word of warning....I was 10 and a half stone stone for 25 years, eighteen months after starting our tank I turned 40 , it was like a switch got thrown and my weight changed to 12 and a half stone in no time and settled there....makes it a tighter fit...:D
    We have the same box as the Kelly n Hall tank, Morse cables but at the moment we have two sticks, looking at a straight line shifter,( I'd go the 4 speed if I were you Trent,ditch reverse and make a new rear plate).Despite what you'll hear quick shifts make a huge difference
    Our first two years on the salt we started in 2nd gear, now that we're re-gearing the rear end to 2.56:1 we'll be using first. As it is at that ratio the split on 3/4 is around 6300 to 4200....we've only got 220hp down there,
  23. patina steve
    patina steve
    A little more progress
  24. Candy-Man
    Candy-Man
  25. Looking good Steve. These things are a labor of love, I know. I see the picture of the ammo, will ask him about it when we have breakfast.
  26. Mopar Jack
    Mopar Jack
    That is great...
  27. neverdun
    neverdun
    Beautiful workmanship. Good luck!
  28. basicbob
    basicbob
    Hi Steve, we know I'm mentally challenged so you will have to help me. If your engine can make 100/120 horsepower would you be better off with a open drive rear end rather than a quickchange rear that will rob you of 10 to 20 HP?
    I know you did the research!
    Great project, Bob
  29. Speed~On
    Speed~On
    Your belly tank is SICK!!!! It would be soo cool to own one. You are a lucky man!
