Technical a low question
Discussion in 'Traditional Customs' started by gdrummer, Aug 17, 2023.
  1. gdrummer
    gdrummer
    hi, i'm working on a 51 vic coupe and want to lower it. i remember reading somewhere that ford aerostar coil springs will fit directly and drop the front about 2".
    is that true? also i also seem to remember that it was a moog part number, maybe cc150? can anyone confirm this info?
    thanks
    Dos Cincos and Squablow like this.
  2. Mr48chev
    dana barlow, Tman, alanp561 and 4 others like this.
  3. guthriesmith
    guthriesmith
    Moog CC850 and the thread referenced above spells that out. That is also what I put in my 56.
  4. Squablow
    Squablow
    Got them on mine and they work nice, along with blocks in the rear gives a nice drop without a ****py ride for very little money. Seems that the price of those Aerostar coils have gone up some in recent years but still a relative bargain.
    guthriesmith, Dos Cincos and alanp561 like this.
  5. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Changing spring height will destroy any hope of getting the camber angle you need. You should get a dropped spindle setup to keep wheel alignment adjustments possible. Alignment shops will not work on front end alignment if spring height is changed to lower the car.
  6. guthriesmith
    guthriesmith
    That’s interesting. I have probably had 30 or 40 vehicles lowered with shorter coil springs that align, drive, and wear tires just fine. It’s been done for years.
  7. Jim Bouchard
    Jim Bouchard
  8. Not all alignment shops will work with you. Most are “toe and go” shops. But not all alignment shops are the same.
    We lowered lots of rides. The alignment shop we used never said no.
    Our cars are simple. Some old turning plates, measuring tape and a bubble gauge and we’re good.
    Put Aerostar springs on my merc. Bubble gauge said all is well.
  9. Atomic Kustom
    Atomic Kustom
    I think there is a joke about being half a bubble off in there somewhere o_O
  10. The camber does change with the dropped springs and if out of range with the eccentric, a camber kit will fix it. Easy to install and allows you to use shims to make the adjustments.
  11. alanp561
    alanp561
    Hey Glenn, have you ever been dirt track racing? Just wondering;)
    warhorseracing and Tman like this.
  12. 57 Fargo
    57 Fargo
    Shorter spring’s definitely affect the alignment, the question is if there’s enough adjustment to correct it.
  13. miker98038
    miker98038
    A couple more thoughts on the Aerostar’s, but my experience was my 55 bird.
    I replaced previously cut stock springs so mine didn’t lower. The ride improved significantly from the progressive spring windings. Softer on small bumps, but increasing stiff on big ones. Car never bottoms driving.
    The Mustang sites show spacers to raise the car if it’s too low. They’re the correct diameter for the Aerostar’s. The Mustang guys use them to tune ride height for cars too low, and they work elsewhere.
    Alignment and bump steer were not a problem
  14. gdrummer
    gdrummer
    thanks for all the replies folks. very helpful!
    no alan, never been dirt tracking
    guthriesmith and Just Gary like this.
  15. CyaNide
    CyaNide
    from Texas
    Not to toot my own horn, but I am the original finder of the Aerostar spring swap. I worked at O’Reillys and found them in the catalog by specs. I ordered about 5 different sets and found the Aerostar springs were the best for what I was looking for on my shoebox. They worked great as everyone has found out. My friend Dave had a 57 ford and we tried them on his and they worked great there too. Get them, the ride is good and the price is good as well.
    CN
  16. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Maybe I was just unlucky. In the '60s in Denver no one would even try to align a car with shotened front springs. They wouldn't even talk to you, just NO! Today I know equipment and better training for those using it have changed drastically. That's good but I am too old to worry about such things now. :(
    guthriesmith likes this.
  17. poco
    poco
    from oklahoma
    I have some in a 50 ford, and the work fine and did align fine.
  18. dwollam
    dwollam
    Put them in my '51 coupe several years ago. Amazing transformation! Just do it!
    Dave
  19. Hillbilly Werewolf
    Hillbilly Werewolf
    " Precision Springs" are made in USA
    # SP08160 (fit Aerostar, 49-50+ Ford, and '42-53ish Mopar)
  20. X-cpe
    X-cpe
    Set the toe, collect the dough.
    anthony myrick likes this.
  21. 57 Fargo
    57 Fargo
    Totally off topic but on most new vehicles the only adjustment is toe…
  22. ^^^^ yes and no
    Alignment correction parts and kits have been common place for a while.
  23. Old-Soul
    Old-Soul
    Had them in my old '49, 3 years and lots of miles and my alignment was fine. Rode like a dream too.
    We owe a debt of gra***ude to @CyaNide for his homework.
    Now we need a similar option for 49-54 Chevrolets. MOOG #8558 is about a 1" drop but it'd be nice to have an "off the shelf" option that offers more.
