A Model fuel filler help
Discussion in 'The Hokey Ass Message Board' started by HotRod31, Dec 28, 2010.
  1. HotRod31
    HotRod31
    I am looking for a supplier that carries a fuel tank fill neck for a 28-29 A model. Or if some one has an original that was cut out of theirs to smooth the cowl. I am trying to add an outside (its in the trunk now) fuel filler to my coupe and wish to use a 28 cap on it. I guess I could have a piece of tubing threaded, anynoe know the thread size-pitch?
    Thanks, Mark
  2. wingedexpress
    wingedexpress
    I don't know the thread pitch but the radiator neck is also the same as the gas tank.I don't know if you could make a filler out of one of those.
  3. Model A Vette
    Model A Vette
    On my '30 I got an extra dummy radiator neck and used a radiator cap instead of the fuel cap.
  4. HotRod31
    HotRod31
    Thanks, I didn't realize the rad. neck was the same.
    Thanks, Mark
  5. Just Gary
    Just Gary
    Take a look at these then check your PMs.
  6. HottRoddin29
    HottRoddin29
    the size is 2"x 20tpi (Metric) x how ever long you need it to be......
