Technical A more attractive overflow bottle?
Discussion in 'The Hokey Ass Message Board' started by menacekustoms, Oct 16, 2014.
  1. Shamus
    Shamus
    from NC
    Simple bracket - works great.
    wingnutz, Model T1, spuds and 2 others like this.
  2. 56shoebox
    56shoebox
    Lots of great ideas on this topic. I love the Pyrene fire extinguisher, and the polished canteen looks really, really good.
    Can you show another photo of how you mounted the canteen?
    Muttley likes this.
  3. I use an old paint pot mine has paint on it but they polish up good .
  4. SuRfAcE_RuSt
    SuRfAcE_RuSt
  5. alchemy
    alchemy
    When you get to cleaning up the wiring and other stuff, take a look at your fuel line. It looks pinched between the filter and carb.
  6. timwhit
    timwhit
    lothiandon1940 likes this.
  7. ct1932ford
    ct1932ford
    My two!
    Model T1 likes this.
  8. menacekustoms
    menacekustoms
    The pinched hose is really just loom. The actual fuel line is not pinched inside.
    I just got a bunch of cool old medical gl*** from my grandfather. I might be able to find something in there.
  9. steel rebel
    steel rebel
    Glad to see this thread. I was thinking of starting one like. I loose some coolant in my roadster over time and it's hard to keep up with it. Yeah I know it is because my radiator is so low. I don't want something that is so cute that it jumps out at you. Leaning toward a plastic Marvel Mystery Oil quart bottle because it is an old product and it is red but not sure how I'll mount it. I'm keeping my eye on this thread. Keep posting.
  10. Robert Crosse
    Robert Crosse
    from WNY
    After 60+ years the washer 'bottle' broke, this was an exact fit.
    You may not want gl***, but for us it's what was used for the washer.
    Bob
  11. menacekustoms
    menacekustoms
    Thanks! That picture helps a lot. I probably will go with gl***, it's "right".
  12. 56sedandelivery
    56sedandelivery
    Lots of drinking water, "water bottles" out there, everything from plastic to spun aluminum, and stainless steel. What about that "coil bracket" bolted to the head? You've got to do something with that. I am Butch/56sedandelivery.
  13. tikiwagon13
    tikiwagon13
    I used a Rolling Rock bottle.....
  14. AZbent
    AZbent
    I know what you mean about the wiring, that is the first thing I saw. At work, if the job doesn't look good, it probably wasn't done right. I am sorry, but the wiring doesn't look good. I don't mean to change the subject.
  15. czuch
    czuch
    from vail az
    Man that looks like a colostomy bag.
    I just put a PBR can up against the inner fender and m***ively achieved the red neck look.
    Theres alot of winning ideas here. I think I need a spun aluminium water bottle.
  16. menacekustoms
    menacekustoms
    Lol, colostomy bag. Like I said, wiring is next on the list. You should see the wire nuts on the bottom of the car! Over all it's not bad wiring, just no thought as to routing or aesthetics. I agree about the coil, but I'm limited until I get new plug wires.
  17. joeycarpunk
    joeycarpunk
    from MN,USA
    A billet overflow painted black if needed looks OK, how much attention do you want to draw to it. Some of the cans, pop, beer, desert water bags, etc. look gimmicky to me.
  18. green73
    green73
    I got a reproduction finned oil cooler (Filcoolator) Style from the garage sale section of Speedway for free (wasn't a gift or anything it was listed as having a pinhole leak, which I haven't found) a while back. I wanted to try and reconfigure it for a housing for a filter if I go with a full flow oiling system on the flatty. I am now leaning on configuring it for an overflow. Overkill...maybe, but I will use it one way or another.
  19. verno30
    verno30
    Check out the one I used on my '32. Maybe not for everyone's taste but I liked it.
  20. gatz
    gatz
    the leather strap looks good on that Jack Daniels bottle.
    would a SS Thermos bottle work ?
  21. This is the Dollar canteen in my old Roadster...
    Model T1 and Max Gearhead like this.
  22. loudbang
  23. [​IMG] Made from a Huey fuel pressure reservoir and DC3 airframe clevises. Sits on top of the spring hanger for the suicide axle
    hotrod54chevy likes this.
  24. ago
    ago
    from pgh. pa.
    The one above is one of the better ones.
    Ago
  25. tommyd
    tommyd
    from South Indy
    Sometimes a simple question that seems so obvious turns into a really good thread. This is one of the good ones. Lots of great ideas here.
  26. Road Runner
    Road Runner
    Period correct puke bottle ...
  27. HOTRODPRIMER
    HOTRODPRIMER
    This thread has me thinking about the lack of a overflow bottle/tank on my Deuce pickup and after seeing what some of you guys have done I remembered a had a couple of tall gl*** SHELL oil bottles and this is what I have decided to use...I'll post photo's after I gather up all the hardware to mount and cap it. HRP
  28. mike bowling
    mike bowling
    Like someone said- if you're looking for "clean", just buy one and paint it black.Or make one from copper pipe and paint it to match your radiator hoses.All those beer cans and additive containers do just the opposite of clean- they focus attention on something you're trying to make go away.Just my 2 cents worth- don't mean to step on any toes-It's up to the individual.
    seadog likes this.
  29. kidcampbell71
    kidcampbell71
    Yep....and I like the old FE upper br*** antifreeze tanks(picture not needed). Some can be cut down and brazed.....or...... you can find other styles similar, and maybe a better fit....between grille/cowl support rods. Br*** always looks like it was always there.
    [​IMG][​IMG]
  30. pitman
    pitman
    Something about Schlitz beer cans.
