Projects A new '32 project of my own.
Discussion in 'The Hokey Ass Message Board' started by hot rod pro, May 3, 2015.
  1. Muttley
    Muttley
    When I win the lottery you are building me a car. ;)
  2. gnichols
    gnichols
    from Tampa, FL
    Excellent-Oh! Gary
  3. hot rod pro
    hot rod pro
    from spring tx.
    i started on the exhaust the other day. full 3" stainless. i'm trying something new to help with the stresses on the header collector. i'm not really liking how ugly it is, but a bellow will give a little flex in the front half of the system.
    i plan to use a small starter, but i wanted to be able to fit a big starter if i ever got stranded. also i will be running a short oil filter for clearance.
    -Danny
    63fdsnr, kiwijeff and D-Russ like this.
  4. MAD 034
    MAD 034
    from Washington
    Stunning craftsmanship. What size are the rear/wheels tires?
  5. hot rod pro
    hot rod pro
    from spring tx.
    16x13 with 345/55-16
    The final wheel and tire combo for the back will be 16x10 with 14/31-16 dirt track tires.
  6. As always sir, your work is exceptional. I've also been watching on Instagram, and am glad you posted here as the larger photo's really demonstrate the detail, which is inspiring.
    I did have a couple of questions if I may,
    (1) I've been searching for some front spring shackles just like those, is this a product you guys typically carry?
    (2) the rear Q/C, is this something you've had for ages, or a recent sourced item? I'm after basically the same arrangement for my coupe, and trying to look at where my options lie.
    Again, admire this build, and appreciate the updates, both on insta, and here.
    Cheers,
    Drewfus
  7. gtolarry
    gtolarry
    from Texas
    very pretty work!! I'm in. when you get to the clutch linkage please post pics
  8. 3wLarry
    3wLarry
    from Owasso, Ok
    well that ****s...some of us old guys don't Instagram
    kidcampbell71 and Blue One like this.
  9. maneri
    maneri
    from ohio
    THANKS (an other old guy)
  10. DDDenny
    Danny--
    Please reconsider.
  11. DDDenny
    Attention moderators---Is this the complaint dept.
    Can someone make sense of this action.
    Tap Tap Tap, is this on.
  12. Bummer..... Even the Boss praised your work. [emoji45]
  13. Dick Stevens
    Dick Stevens
    Count me as another one who is not happy with not being allowed to follow the build of this fabulous hot rod. :(
  14. Blue One
    Blue One
    from Alberta
    This double ****s :D
  15. DDDenny
    There is a reason that I don't do: Facebook Instagram Pinterest or Quilting.
    I discovered the HAMB
    fauj likes this.
  16. Blue One
    Blue One
    from Alberta
    You know Danny, there is also the other side of this.
    Even if your thread had remained in the traditional rods section, your plan of keeping it away from other posts would not have worked anyway because all posts appear in the general forum (hokey *** message board).
    So, there is no real need to be so sensitive. I don't see a problem with the majority of what was posted, plenty of praise and a few questions.
    Possibly you are a bit over sensitive ?
  17. I love all the custom machined brackets. Very well thought out ch***is. Thanks for sharing.
  18. modernbeat
    modernbeat
    from Dallas, TX
    And after a while, those other venues look so much better than the current HAMB.
  19. 3wLarry
    3wLarry
    from Owasso, Ok
    What's wrong with the current Hamb?
    kidcampbell71 likes this.
  20. modernbeat
    modernbeat
    from Dallas, TX
    This build thread thrown into General Discussion instead of Traditional is what's wrong this time.
  21. Blue One
    Blue One
    from Alberta
    You guys know that Ryan has asked for help in a survey don't you ?
    Instead of whining about it do the survey and make suggestions.
    One of my suggestions was just that, creating a separate section for build threads.
    And a big NO ! In no way are the other venues better than the HAMB.
  22. hot rod pro
    hot rod pro
    from spring tx.
    i have filled out the survey, before this happened.
  23. Blue One
    Blue One
    from Alberta
    My comment on the survey was not aimed at you, I believe you should keep posting your progress.
    We all appreciate what you are doing and have done.
  24. Well if the thread ain't gonna get closed keep posting. We'll follow along!
  25. hot rod pro
    hot rod pro
    from spring tx.
    my complaint is causing drama, which is what i hate about the main page. for the past ten years, all i have wanted out of posting is to show people what can be done on hot rods. please understand, by no means have i done this to create a buzz about this project.
    if ya'll like what i do and care enough to take the time to comment, i guess i need to put on my big boy pants and continue to post. thank you for helping me see both sides of the issue.
    -Danny
  26. 3wLarry
    3wLarry
    from Owasso, Ok
    and now we return you to our regularly scheduled program
  27. hot rod pro
    hot rod pro
    from spring tx.
    a different angle of the rear shock bracket.
    the rear ladder bar brackets fresh out of the mill.
    steering box mount fresh out of the mill.
  28. DDDenny
    Life is good again!!!
    Thanks for my morning fix Danny .
  29. hot rod pro
    hot rod pro
    from spring tx.
    Transmission dropout flanges.
    golferforpar and D-Russ like this.
  30. alchemy
    alchemy
    What do you do to those milled parts to give them that "forged" look? Is it just a minute in the blasting cabinet? Do you use a special blast material, or just regular sandblast sand?
