A question for '32 frame builders
Discussion in 'The Hokey Ass Message Board' started by Irish Mike, Jun 23, 2009.
  1. On a '32 frame, at the bead area, is the bead and top outside corner of the frame square to the top plane? In other words, if I laid a straight edge across the top of the frame, would the top outside corner and the bead be at 90 degrees? I always thought the section (about 5") above the bead would be 90* but the frames I saw at the roadster show this section is at a slight angle and the bead and top edge appear square to the top plane. How where the Henry frames? Thanks
  2. yule16met
    yule16met
    from Hudson, WI
  3. HotRodMicky
    HotRodMicky
    Henrys are Not 90°.
    Same As the the repro.
