A radiator in the Fly?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Oct 23, 2006.
  1. Yes, it's more practical...and won't hurt the look
    50 vote(s)
    52.1%
  2. Maybe if you hide it in the rear of the car somewhere...
    34 vote(s)
    35.4%
  3. Are you smoking crack? No, not ever, you'd ruin the look of the car
    12 vote(s)
    12.5%
  1. Roothawg
    Roothawg
    You guys are just so used to seeing it on here.......maybe it needs a makeover.......I need to call HGTV.
  2. Root,
    I have seen some guys tap into the freeve plugs on the side of the block, rear ones, and run them through an electric pump to a small rad hidden under the car. This way you can keep the front of the car clean, no pump, no belts, no plumbing visable since your motor is set back so far, and you can begin to control the motor temps somewhat. Later if you have proven this out you could increase the cooling capacity by instaling a second rad or a larger one. Just a thought.
    Love the way the car looks.
  3. Zeke
    Zeke
    I was thinking the same thing...
  4. dragrcr50
    dragrcr50
    Geeze , how long does it take to put a radiator in the thang?????????:cool:
  5. i am sure some else said this, but no matter how hot it is in side the cab, it is still cooler than what is coming out of the block. and you already have the cooling lines run it appears...
    (remotely located electric water pump and large radiator ayed down in the cab, w/ an electric fan?)
