Technical A rattle can primer question.
Discussion in 'The Hokey Ass Message Board' started by TVC, May 2, 2023.
  1. TVC
    TVC
    We've been using Duplicolor grey high build primer in the aerosol can to spot in small areas/panels after the body work on the latest project. Kind of time to do a total body spray and we're wondering if anyone might know if this brand of rattle can primer is lacquer or enamel?
    I know that you shouldn't spray lacquer over enamel as it will lift the enamel base. Before we pick up a quick quart of pre-mix primer, want to be sure that we're getting something that will be compatible with the Duplicolr that we've been using.
    Thanks !
    Deuces and Tow Truck Tom like this.
  2. Harv
    Harv
    from Sydney
  3. Rickybop
    Rickybop
    I don't hear a lot of talk about this, but waterborne barrier primer is a good product to use if you're ever worried about reactions between various coatings. You can apply it over anything and then put anything over it. It's easy to use and it cleans up easily... it's water-based. You can get it in high fill and it sands easily.
    I used it on a project years ago. Lacquer over enamel.
    No issues.
  4. larry k
    larry k
    Lacquer wasn’t any good in the 60s ,,,, and it ain’t any good now !!!
  5. bobss396
    bobss396
    It is not the same lacquer primer it was years ago. I've been using SEM or Transtar primers lately, a bigger can at 15 ounces.
    caseywheels, seadog and alanp561 like this.
  6. TVC
    TVC
    Thanks all. We just want to get a decent heavy coat of high build on the car after using up so many rattle cans and not really getting a decent result. Now that I know that the rattle cans are lacquer, I'll grab a quick quart of high build lacquer and have at it. After that a sealer, then the single stage enamel top coat. Weather is warming up, time to paint—
    2Blue2 likes this.
  7. Bandit Billy
    Bandit Billy
    I spend way too much on my finishes to spray anything out of a can on them. Mix it, spray it and sleep well at night knowing your paint aint all bubbled up in the morning.
    overspray, SS327 and gimpyshotrods like this.
