Hot Rods A trick you can do with a flathead.
Discussion in 'The Hokey Ass Message Board' started by Mart, Sep 12, 2010.
  1. nifty
    nifty
    from UK
    That's ace Mart. But swapping a 21stud to a 24 then dropping one head off it makes ****** all sense to me haha. Why did you need to remove the head mate? I thought she was running good after you dropped it in there.
  2. Mart
    Mart
    Knock knock...
    Who's there????
    No. 7 piston, that's who...!!!!!
    Mart.
  3. NoSurf
    NoSurf
    hahahahaa!!!!
    Lmao.
  4. guitar man
    guitar man
    from Tulsa OK
    Yep, I used to work for a rental company maintaining those, had an engine head on one side and a compressor head on the other. worked extremely well for powering jackhammers etc,
  5. the-rodster
    the-rodster
    Cool.
    I've often though about doing that very same thing.
    Neat to watch the valves.
    Pull the hose from the pump, plug the intake ports, and drive it :)
    Rich
  6. I played the video for an expert Small-Block Chev Engine Builder !! He knew all about this as he told me "Yeah, He's just got the VALVE COVER OFF and He's ADJUSTING THE VALVES" I still can't stop laughing !!! >>>>.
  7. flatheadpete
    flatheadpete
    from Burton, MI
    The guys here at work (Chevy Dealer) got a kick out of me pulling half the plugs off my flatty while it was running. Pretty cool little engines.
  8. FANTASY FACTORY
    FANTASY FACTORY
    Because he already knows he's changing thr bearing and seal on the water pump after running it dry.
  9. Teep
    Teep
    from Travis AFB
    thats too *****in!!!
  10. 46fatford
    46fatford
    There is some old air compressors at 1 yard I go to that are 21 stud flathead 8's that run on 4 cylinders and the other 4 are for air. They are not all on the same bank though. They alternate. It is definitely a factory design too. I'll see if I can find some pics.
    Matt
  11. Mart
    Mart
    That makes sense, Matt, If I remember correctly, to get 4 even firing cylinders on a V8 you need to run the outer two cyls on one bank and the inner two on the other. - Like the inlet manifolds are divided.
    Mart.
  12. mctommy
    mctommy
    from sweden
    How to make a blown 4 banger from a V8
    Raise the compression in four of the cylinders, feed them with gasfree air, disconnect their spark and lead the exhaust over to the other four live cylinders......
    Voila.... a supercharged fourcylinder!! :)
    Hmm... You would probably need to make a new camshaft that makes the blowercylinders lobes open double, giving compression on every stroke....
  13. Mart
    Mart
    I just noticed the big sparks jumping off one of the HT leads.
  14. Lotek_Racing
    Lotek_Racing
    There's a motorcycle design that does this already.
    Shawn
  15. mctommy
    mctommy
    from sweden
    Ok..... I thought it was just another crazy idea that popped up under the influence :)
    So, does it work? what motorcycle?
  16. Ford-Man
    Ford-Man
    Sorry, I skipped a bunch of this thread...
    Flattys were converted to many things...but for a compressor they would usually block out the middle 2 on each side. It would run on the outer 4 and compress on the inner 4. They look wild!
  17. Lotek_Racing
    Lotek_Racing
  18. AAFD
    AAFD
    from US of A
    Did something similar to that after a head gasket swap on a small block ford....we started it up but forgot to install the rocker ***embly on once head. It ran...kind of.
  19. flatoz
    flatoz
    thanks Mart,
    I have heard of this but never seen it, was cool to see in in a video.
    Don't know I would do it with my engine, but sure enjoyed watching yours!
  20. pat59
    pat59
    neeto thanks for the vid. :)
    -Pat
  21. brady1929
    brady1929
  22. Eric H
    Eric H
    I was not expecting that. Lol
  23. woodbutcher
    woodbutcher
    :D IIRC,there was an article in Popular Mechanics,Mechanics Illustrated or Mother Earth News that had a set of plans to make an air compressor out of a SB Ford.
    Good luck.Have fun.Be safe.
    Leo
