A V8 centre crossmember
Discussion in 'The Hokey Ass Message Board' started by Ben Hall, Mar 24, 2010.
  1. Ben Hall
    Ben Hall
    from Adelaide
    I am planing on running a 39 trans, with a 1941 Mercury Flathead. In Model A rails. Vern Tardel is not doing a centre crossmember anymore? What should i do? Is there any other companys that make a simliar item? The car will be RHD for australia.
  2. Just Jones
    Just Jones
    I can't help with repop 32 crossmembers, but I can suggest using a f1 truck crossmember and pedals - works great and is very traditional - all Ford! There is a lot of info here on the HAMB about it.
  3. Ben Hall
    Ben Hall
    from Adelaide
    Cheers i will check the posts,
  4. ironfly28
    ironfly28
    from Orange, CA
    I ran into that problem myself.... I found a certain post about about a sport coupe hop up where the owner built his own...That's about the time I happened to glance at a cracked model A rear crossmember I had laying around and decided to make it my center cross member.. remember this is hot rodding not rocket surgery.. use what's between your ears.
  5. McFly
    McFly
    There's a guy on ebay selling whittled down k-members for an Av8. Very similar to Verns.
  6. Cliff Ramsdell
    Cliff Ramsdell
  7. Flat Ernie
    Flat Ernie
    Tech Editor
    I believe Dagel's makes an X-member...much stronger.
  8. flatford39
    flatford39
    I havean f1 in mine. It is pretty easy to adapt and is set up for the pedals on either side. You will want to use the F1 pedals as well.
  9. Flat Ernie
    Flat Ernie
    Tech Editor
    Here is the Dagel's:
    http://www.dagelsstreetrods.com/super_x_crossmember.htm
    The X member is superior to the K member for torsional rigidity...the Model-A frame is significantly smaller than the later V8 frames.
    Yes, it's been done countless times, as has the F1, but the 33-34 X-member is a good upgrade over the 32 K-member (especially given the price of 32 parts). The Dagels is a good compromise again.
  10. 40Chevy
    40Chevy
    from california
    First thing i'd do is get that book: "How to build a traditonal Hot Rod" by Tardel and Bishop. Gives good insight on how to solve many problems. I'm running a RHD here in the states. Lots of challenges here, PM me for solutions.
  11. StrickV8
    StrickV8
    Contact MnStumpjumper. He makes them. Fit is perfect and believe it or not think he has a Right hand drive one......
  12. I cut down a nice 32 K-member from a RHD car for my AV8. The dimensions in the book where spot on for the crossmember part but I did my legs differently. LOTS of work but I am very happy with the results. If I had to do it all over I'd use an F1 or 33/34 X-member mainly for economic purposes. Jason...
  13. walter
    walter
    I used an original 32 crossmember and it works great. The great thing about it is all the pedals, transmission, e brake all bolt togeather with no modifacation.
  14. flatbrad
    flatbrad
  15. lowsquire
    lowsquire
    from Austin, TX
    The Lilow one looks nice.
    If you want to battle with an original 32 K member give me a call. number on my website.
  16. tysond
    tysond
    Has anyone done later X-members in an A, like a 35 and later style? Are they too big?
  17. Flat Ernie
    Flat Ernie
    Tech Editor
    The later frames are taller, so you have to trim the later X-members where they rivit/weld onto the A frame.
    That's why a custom made one like Dagel's makes so much sense for most folks...
  18. Shaggy
    Shaggy
    from Sultan, WA
    I did a '37 X in a '32 frame for my 27 T, a lot of work, but sure looks slick, pretty straight forward, the rear legs are too narrow and didnt meet before the kickup so i had to piecut them so they were an inch or two wider, and height wise they are a little too tall even for '32 rails and need to be split and narrowed
    I can honestly say if you feel good with your metal working skills, they work Good in a '32 but i probably wouldnt put one in a model a frame
  19. hotrodlane
    hotrodlane
    I know this is an old thread but I am bumping it to the top because I think it is a good one.
    ironfly28 likes this.
