Technical A v8 Model A
Discussion in 'Traditional Hot Rods' started by rare 50, Dec 23, 2023.
  1. rare 50
    rare 50
    from Australia
    Hey Guys,
    Just a query, ive recently bought a 1930 Model A coupe with a flathead 59a engine. The car had been sitting for a long time before i purchased as it was a deceased estate. The shop i took it to to get checked over before purchase said the when sitting fuel was leaking through the carbs and their solution was to install a tap in the engine bay to turn off everytime the car was not running.
    My question is i know with a model A using the standard fuel tank its gravity feeding to the carbs, is this really necessary to have a tap when it was never there before and ive just rebuilt the carbs and installed a new mechanical fuel pump. ( I havent started it up again yet since rebuilding the carb and new fuel pump
    Thanks for your suggestions
  2. Happydaze
    Happydaze
    Really necessary? Probably not, but a worthwhile thing to have, especially if its already there. Useful security device too.
    Chris
  3. don colaps
    don colaps
    Model A’s already have a tap installed under the tank. Factory stock. I would say that was/is a necessity due to the gravity feeding system
    Pist-n-Broke, mad mikey and X38 like this.
  4. cederholm
    cederholm
    I’m ***uming you’re using the stock tank, in that case I would say yes, and put it back where Ford had it, directly under the tank. I know the sure fire way to tell if I haven’t closed it on my stock A is the small of gas in the garage.
    osage orange likes this.
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    Sounds like a good idea.
    I just wonder how much pressure would effect the carbs on a gravity feed Model A tank?
    2-4 lbs?
  6. rare 50
    rare 50
    from Australia
    Thanks for the replys, the original tap on the tank has been removed at sone point time, i think i will just buy a new one of them abd reinstall in the original position.
    Thanks
    2Blue2 and osage orange like this.
  7. RodStRace
    RodStRace
