A V8 roadster update- been a while!!
Discussion in 'The Hokey Ass Message Board' started by Chris, Oct 4, 2010.
  1. 41 Dave
    41 Dave
    Chris, Like the way you build and roll . . . . . Bet this will be a great ride for summer time !
    Dave
  2. tuki
    tuki
    hey man,,what is that radiator in the last pic.did u have that made or did u but it from like Walker.im trying to find a way to run the filler neck out my 32 shell on my av8 build
  3. OLLIN
    OLLIN
    THANK YOU, THANK YOU, THANK YOU, CHRIS for this post! I knew I had seen it here before, and now I found it again.
    I am doing exactly this on my av8 project right now, and this was very helpful.
    The frame i have already had the tabs for split bones, and they are too close for the bones I have. I guess they ran a model a axle and split bones before i got it?
    after seeing your car im really considering leaving the wish bone unsplit. I really dig the stance on your roadster, I want to keep my car's era early to mid 40's as much as possible and you nailed it.
    My axle is a 32 heavy axle, and i think the bones are 32's also but they appear to have been extended to clear the pan for a v8?
    The welds look good, and the car it came off of was well built so I think ill just run it that way.
    what kind of spring is your rear spring? I have a 41 ford rear end, but I dont know if ill use the spring?? The frame I have has a kick up of about 5" inches... Might have to go with something taller?
    What is your wheelbase also please? I dont have a body yet, but I want to set everything up meanwhile.
    Thanks again!
  4. OLLIN
    OLLIN
    PS:::::::
    anyone have an extra saddle thing laying around so I can do the same thing as chris on my f1 crossmember?
  5. cball
    cball
    chris looking forward to seeing more, I love the car.
  6. hydroshawn
    hydroshawn
    from Tx,Ca
    I'm also curios of rear spring & what kind of rake did you put on the rearend.
    Thanks
  7. Chris
    Chris
    The spring is a T spring, loweres it about 3" (once all the weight is on it)
  8. erlomd
    erlomd
    I like it! Keep it up and can't wait for more pics!
  9. 510madmav
    510madmav
    Find them new in Mac's
  10. OLLIN
    OLLIN
    What do I look under? I tried searching. Got a link? thanks!
  11. alchemy
    alchemy
    Sometimes those saddle things are called rear motor mounts. Try searching that.
  12. I just did mine on Saturday [​IMG]
  13. dsiddons
    dsiddons
    from Indiana
    I prefer the early stance myself to.
