Projects A/V8 speedster ‘Sat Nite Spcl’
Discussion in 'Traditional Hot Rods' started by Oldtmtech, Jul 28, 2022.
  1. Oldtmtech
    Oldtmtech
    You get 2 postings this week
    Pistons
    The first thing I noticed was the pin retaining clip groove was much smaller than the clips that I had
    Van pelt gives a dimension of .041” wire thickness
    I matched up some retainers from McMaster Carr IMG_5393.jpeg IMG_5394.jpeg they come in a bag of 50 so I have extras
    The pins are also different IMG_5369.jpeg IMG_5368.jpeg these must be the tapered wall pins that people refer to
    The old pins weigh 82 grams the new pins 67 grams
    The old piston and pin total weight is 385 grams
    New piston and pin weight is 395 grams
    Balanced the pistons by putting them in the lathe IMG_5346.jpeg piston and rod ***emblies installed smoothly IMG_5376.jpeg IMG_5379.jpeg rod side clearance of.014”-.019”
    While looking for my ring compressor I did find these IMG_5395.jpeg IMG_5396.jpeg each one made for a specific size
    Cool
    Up next will be valve ***embly
  2. Oldtmtech
    Oldtmtech
    Got a lot to cover so this is going to be a lengthy post
    I was going to taper the valve guides (like everybody suggests doing) by wiring the split guides together and putting them in the lathe but found that the guides are already flush with the port IMG_5402.jpeg IMG_5403.jpeg IMG_5405.jpeg difference in one piece valve guides?
    difference in early block?
    Don’t know but didn’t have to modify guides
    Next was getting installed spring height
    Didn’t have a good way of measuring until I I remembered the drawer in Dad’s drafting table (Dad’s memory is going to be playing a big role in todays post)
    Found these inside measuring caliber IMG_5412.jpeg after measuring all of the valves it was time to look at spring pressure
    When I worked on cylinder heads at the race shop as a young man we used a fixture like this IMG_5410.jpeg when I started working from my dad’s shop he made me this fixture IMG_5418.jpeg I remember asking him how do you know that the gauge is reading actual lbs
    He gave me some scientific explanation about the size of the piston and alot of more detail that all went over my head
    But I see that the spring checkers they sell now are very similar IMG_5411.jpeg like always Dad was way ahead of his time
    My spring install height ranged from 2.145”-2.200”
    With stock being 2.125” my numbers sound right for old valves that have been previously ground
    With a number of 2.165”and a .060”shim I have readings of 50-55lbs seat pressure and 100-110lbs at.365” valve lift IMG_5423.jpeg IMG_5423.jpeg Ol Ron says 50 lbs seat pressure is all you need so I’m good
    To keep everything in order I had laid everything out on a sheet of packaging paper IMG_5429.jpeg with all my notes written right on the paper I’m thinking of framing this when I’m done
    Right before I was going to ***emble the valves I was watching one of Mart’s videos and he was talking about how to tell exhaust valves (intake and exhaust are the same size) from intakes
    Exhaust valves are not magnetic
    Of course I didn’t mark the valves when I dis***embled I was just going by the shape of the valve (the flatter ones being intakes)
    IMG_5430.jpeg Mart was right the exhaust are not magnetic or slightly magnetic the intakes are definitely magnetic
    I was right too
    Now time to ***emble the valves again using one of dad’s old tools IMG_5432.jpeg upon dis***embly I had chipped some of the valve guides
    Dad had always kept a flathead valve ***embly on his desk (could be a 8n tractor aren’t they the same?) so I am using that guide on number 8 exhaust closets to the driver
    Cam timing
    Had to find TDC
    IMG_5467.jpeg Using the positive stop method
    Cut a slot in a bolt for a pointer IMG_5468.jpeg IMG_5437.jpeg IMG_5438.jpeg made a pointer for the crankshaft pulley IMG_5449.jpeg after marking the pulley I put it in the mill on the rotary table
    Put notches at 0*,5*,20*,25* btdc
    Smaller notches at 2.5* and 22.5*
    For ignition timing
    Also notches every 45* for valve adjustment or diagnostic purposes IMG_5440.jpeg IMG_5445.jpeg IMG_5447.jpeg next put the valves on number one to zero lash and checked cam timing IMG_5460.jpeg intake
    IMG_5462.jpeg IMG_5464.jpeg IMG_5466.jpeg Exhaust IMG_5459.jpeg IMG_5458.jpeg IMG_5457.jpeg IMG_5416.jpeg Everything looks good
    I’ve had this cam gear for a couple of years was never satisfied with it
    Bolt holes are sloppy and the shoulder bolts that came with it just make it worse
    Went to my local tractor supply store and bought some 1/4”spacers and some grade 8 bolts
    Reamed out the spacers to5/16” cut to length then reamed out the gear to 3/8” and pressed the bushings in IMG_5452.jpeg IMG_5453.jpeg cut the bolts to length
    You have to be careful on the length they go thru the cam and into the thrust face
    Oops can’t upload anymore files
    End part 1
    oliver westlund likes this.
  3. Oldtmtech
    Oldtmtech
    Start part 2 IMG_5455.jpeg the last thing I wanted to do was check lifter rotation on my hand finished lifters
    Well I don’t have lifter rotation IMG_5473.jpeg IMG_5474.jpeg or very little
    I think I put to much of a radius on the lifters
    After alot of contemplation I decided to order a new set of lifters but I am still thinking of ways to salvage the originals
    I think first I need to grind them flat
    Ford lifters are 1”so they will fit a collet on my index fixture IMG_5475.jpeg IMG_5476.jpeg it’s my understanding that the radius is 96”(8feet) on the lifter
    So here is a rough outline IMG_5477.jpeg just some ideas right now but at least I will have some new lifters to check out rotation and profile
    I have got a whole lot of work to do yet before the valves need to go in
    Also for those of you installing higher lift cams you differently need to drill holes for valve adjustment and I would drill them even lower down than I did IMG_5471.jpeg IMG_5472.jpeg I had done a preliminary adjustment like Mart does so your final adjustment is very little
    You’re all caught up now
    I need to do some more thinking on the lifters but I don’t want to kill my new cam so I might install the new lifters and put the old ones on the shelf for another day
    I’m curious to see how much lifter rotation there is with a new lifter also I haven’t checked the 14 other lifters yet
    Tell next time
    ezrodder1 likes this.
  4. Oldtmtech
    Oldtmtech
    I will start this post with a video I found about flat tappets
    It really says what I have been finding out thru my own findings and what I have been reading
    My new tappets arrived and they look great they do have an issue that I will talk about in a minute
    The ones that I got are identical to the Johnson lifter even down to the adjusting screw
    New lifters have a weight of 82 grams to the original 78 grams IMG_5497.jpeg the isky instruction gives a cam taper of.001” IMG_5493.jpeg I have actually measured this cam and it does have a.001” lobe taper
    So if you want a corresponding taper on the lifter you would want .0005” over half of the lifter
    I have even read of .0002”
    Set up to measure the new lifters IMG_5481.jpeg measured all 16 and they were the same at.001”(which is the number I will try to get when I recrown my originals anything smaller is to hard to measure) IMG_5487.jpeg IMG_5485.jpeg then started to check for lifter rotation
    I am having some trouble with burrs in the lifter bore I think from where I drilled the adjustment holes so I need to remove the cam and run a brake hone thru the bores
    But I do have lifter rotation (I have turned the motor over so many times you can actually smell the rings seating in)
    Was having trouble with setting valve lash on some of them that is when I discovered this IMG_5490.jpeg the adjustment screw threads aren’t parallel with the body
    The adjustment screw face was ground with the screw installed in the body so depending on how you have it positioned you can actually double the error
    So my solution is to remove each screw mount it in an original lifter (which are straight) chuck it in the lathe and face the screw and also add more chamfer IMG_5499.jpeg that should minimize the error and give the best surface area for the valve stem
    I also feel that the out of square adjustment screw can effect the lifter rotation
    I still plan on working on the original lifters but that will be a future project
    I have really gotten bogged down with these lifters and need to move on
    I have thrown out the spin fixture idea
    I can face the lifter flat with a carbide bit in the lathe and then get the.001” taper
    I measured up to a.008” taper on the ones I did freehand
    I also think my finish was too polished
    I think I can get them serviceable if I was to ever buy a used race cam!!;)
    I don’t know if anyone caught it but I had a brain fade when I was notching my pulley in my last post
    I put a notch every 45* when I needed only 90*
    Found that out while adjusting valves totally freaked me out for a while
    But I do tend to get confused when talking cam timing
    Hopefully by next week I will have the valves installed and we can move forward
  5. Oldtmtech
    Oldtmtech
    IMG_5502.jpeg IMG_5505.jpeg I have often read that the valves are noisy on the flathead
    This was even addressed in my old repair manual IMG_5507.jpeg IMG_5508.jpeg particularly the square of the lifter and valve stem IMG_5510.jpeg
  6. Oldtmtech
    Oldtmtech
    I had read about modifications to the model A oil pump decided to look at my rebuilt’34 pump
    The shaft is already turned down on these pumps so I just opened up the hole that comes out of the pump and into the block IMG_5511.jpeg used o-rings like Mart did IMG_5515.jpeg drilled a hole in the casting for safety wire IMG_5517.jpeg IMG_5518.jpeg the bolts that hold everything together IMG_5520.jpeg installed the oil pump idler gear IMG_5523.jpeg IMG_5524.jpeg had gotten a new 50# spring and plunger for the pressure relief valve in the front of engine IMG_5532.jpeg IMG_5531.jpeg IMG_5528.jpeg the plunger was obviously to long probably meant for blocking off the relief port when using a later pump that have a built in pressure relief valve IMG_5529.jpeg IMG_5530.jpeg next will be flywheel oil pan and front timing cover
  7. Tim
    Tim
    from KCMO
    Just found this thread, looks like a lot of good tech info I’ll have to come back and get caught up!
  8. AmishMike
    AmishMike
    Never seen safety wire on con rod. Is that common on flathead?
  9. Oldtmtech
    Oldtmtech
    No the con rods are supposed to have cotter pins but because the nuts I’m using are not castled I don’t have room for one
    Also the one rod that I had to use washers on doesn’t have room for safety wire either IMG_5352.jpeg
    AmishMike likes this.
  10. Oldtmtech
    Oldtmtech
    Flywheel installed
    My safety wire skills are not the best in cramped areas IMG_5577.jpeg IMG_5575.jpeg IMG_5573.jpeg and since I have been following the old repair manual I checked the run out IMG_5585.jpeg IMG_5580.jpeg IMG_5579.jpeg IMG_5584.jpeg IMG_5583.jpeg it gives a limit of.005”
    I got.003” on the outside of clutch face and.0045” on the bore
    The manual reads that you can turn the flywheel 180*on the crank and recheck but I did mark the flywheel when I dis***embled the motor and reinstalled it that way
  11. Oldtmtech
    Oldtmtech
    Needed to make a new dipstick tube but didn’t know what length so I put 5 quarts of water in the pan and then allowed for the oil pump volume
    That makes it level with the windage tray IMG_5538.jpeg IMG_5539.jpeg Installed the tube fitting IMG_5639.jpeg installed the sleeve for the new one piece front seal
    When pressing it on it developed 2 creases where it went over the key way cutout
    Gently m***aged ,filed and polished it back into shape IMG_5557.jpeg IMG_5561.jpeg a lot of time can be used up on little stuff like this water drain pea**** IMG_5603.jpeg IMG_5641.jpeg with all the beating and banging I did on the oil pan it had a twist and the holes didn’t properly line up
    So instead of enlarging holes I opted for studs
    This worked well also holds the gasket in place IMG_5601.jpeg what I didn’t account for was how difficult the cork gasket that goes over the rear main was to install
    Should have glued this in place before I started
    Was worried that it was out of place but was able to get my phone in the starter hole and get some pictures
    Looks okay keep my fingers crossed IMG_5616.jpeg used these serrated flange nuts for the pan so I don’t have to use lock washers IMG_5659.jpeg IMG_5632.jpeg IMG_5638.jpeg and the front timing cover has to be installed at the same time IMG_5646.jpeg IMG_5648.jpeg when I don’t have real Henry hardware for the outside parts I take new hardware and machine off the markings give it a chamfer then bead blast and use gun blueing then soak them in oil IMG_5658.jpeg IMG_5642.jpeg IMG_5643.jpeg motor mounts installed IMG_5645.jpeg
    rwrj likes this.
  12. Oldtmtech
    Oldtmtech
    Mixing it up this week
    I’m back to intake and carbs
    As mentioned I’ve got two different y manifolds one single plane and one dual plane
    I want to use the dual plane did the machining still need some hand porting IMG_5672.jpeg IMG_5671.jpeg the problem is that it is shorter than the other one and will have clearance problems with the generator IMG_5684.jpeg IMG_5686.jpeg I happen to find a chunk of aluminum and because I couldn’t find any dimensions I made up a drawing for a 3 bolt carb mount IMG_5568.jpeg did some machining IMG_5534.jpeg IMG_5535.jpeg IMG_5536.jpeg I wanted to make my own spacer because the ones that you buy don’t match the shape of the manifold or the adapter so they look added on
    I plan on shaping the spacer so it blends in and will look more one piece IMG_5676.jpeg IMG_5673.jpeg IMG_5678.jpeg while I was taking pictures it occurred to me that I should leave a boss for a fuel manifold to mount too IMG_5682.jpeg IMG_5677.jpeg then I thought why not make the fuel manifold integral to the spacer IMG_5677.jpeg that’s what I’m going to do should be one of a kind
    Also needed to flatten the castings where the nuts go so they bolt up flat
    Found this setup that my dad had put together
    Worked really well IMG_5660.jpeg IMG_5663.jpeg IMG_5664.jpeg IMG_5666.jpeg also with all this manifold thought it best if I added some heat back
    So put some 3/8” holes in the plugs I had made for the exhaust cross over IMG_5533.jpeg here it is with the generator all the way up IMG_5679.jpeg there is going to be nice spacing between all the components
    Nothing is going to look to crowded and with this engine being mounted low in the ch***is and flatheads being short the elevated carbs should bring a good visual IMG_1397.jpeg
    CSPIDY likes this.
  13. CSPIDY
    CSPIDY
    Boy, your work fits right in with the old saying
    “The Devil is in the Details “
  14. Oldtmtech
    Oldtmtech
    I may have to change the name of this project
  15. Oldtmtech
    Oldtmtech
    Been plugging away at the intake spacer
    Drilled and tapped for the fuel manifold
    Free hand milling
    Will now need to do some die grinding to blend in the contours IMG_5709.jpeg IMG_5712.jpeg IMG_5714.jpeg IMG_5721.jpeg IMG_5723.jpeg IMG_5724.jpeg IMG_5725.jpeg IMG_5726.jpeg IMG_5727.jpeg IMG_5729.jpeg IMG_5731.jpeg IMG_5732.jpeg IMG_5733.jpeg IMG_5734.jpeg
    Bigcheese327 and richard noble like this.
  16. Such an excellent build with so much information. Thank you for doing this thread. Keep the updates coming.
  17. Oldtmtech
    Oldtmtech
    Starting to look at the cylinder heads
    There was already a problem I knew about that being the 2 center cylinder domes not being cut to the same depth on the p***enger side IMG_5740.jpeg part numbers on these heads are
    68-6049B
    68-6050B
    Which makes them a’36 design
    Casting dates of
    8-13-46
    10-22-46
    So replacement heads
    My book gives a combustion chamber volume of 75-78 cc for a compression ratio of 6.3 to 1
    From what reading I have done.050”to.060” can be milled off
    One problem being how thin it is to the water jacket
    You can definitely put your fingers into the water jacket and feel how thin it is IMG_5739.jpeg Did some preliminary measuring using tin foil
    IMG_5736.jpeg IMG_5738.jpeg I don’t have a used compressed gasket to use so most give a compressed gasket measurements of.050” and if you are looking for.050” clearance between piston and head and valves to head you are looking at zero clearance with no gasket
    With the measurements I got don’t think these heads have been milled before and being replacement heads that would make sense
    Taking.050” off the heads I think would still give sufficient clearance over the valves and pistons the exception being the 2 cylinders mentioned above
    So some hand m***aging of those areas will have to be done
    For education purposes will try to come up with a way to get a before and after cc volume measurement of the combustion chambers
    Also I like the very deep transition area in the combustion chamber so I shouldn’t lose airflow when milling the heads and will add turbulence with the squish area over the piston IMG_5740.jpeg
    Next task is to actually get them securely mounted on the milling machine table
    Hot Rod Ron likes this.
  18. Oldtmtech
    Oldtmtech
    Came up with a cheap way to cc the combustion chambers
    Found a piece of plastic that was big enough to do 4 chambers at one setup IMG_5774.jpeg found this turkey cooking kit in the kitchen IMG_5752.jpeg and with some bolts to hold the head IMG_5775.jpeg was able to get measurements pretty quickly IMG_5773.jpeg IMG_5772.jpeg results
    1. 80 cc. 5. 78 cc
    2. 78 cc *. 6. 80 cc
    3. 76 cc *. 7. 78 cc
    4. 78 cc. 8. 78 cc
    * two center chambers mentioned in previous post
    currently working on a fixture for mounting heads on the milling machine hope to have more on that next week
    As a side note
    Been back to working on my new shop
    Got 50 amp electrical service installed
    So moved the welder and welding table from the back door of the house to the shop
    When the heads are finally bolted to the block the engine will then be moved out of the ba*****t and put on the run stand in the shop to get finish ***embly and what ever work that needs to be done on the run stand (radiator,exhaust,fuel,battery,control panel )
    Still working on a floor in my lean to shed so I can bring the rest of dad’s equipment including the shop air compressor which I badly need and the hydraulic press and some smaller bits and pieces
    Once I get the engine running I can then bring the rolling ch***is home where it will be dis***embled the frame painted and then the engine and trans can be installed in the frame (almost forgot that the steering box has to be installed before the engine and that the left hand cylinder head cannot be removed when engine is installed because of the steering box that is why I am doing a run stand so I know that everything is good before being installed
    I can also easily install different carbs manifolds or other parts on the engine while I am working on the frame)
    For those new to my build here is my steering box installation which can be found somewhere in a early post IMG_0579.jpeg IMG_0572.jpeg IMG_2256.jpeg
  19. Oldtmtech
    Oldtmtech
    Posting a little late today
    Was just able to grab an hour today to continue the fixture for milling the heads
    Using a 1/2” plate drilled and tapped 4 holes 7/16-14 and made studs to hold the head IMG_5793.jpeg IMG_5794.jpeg IMG_5796.jpeg I will use locknuts so I can adjust the level of the head IMG_5797.jpeg IMG_5798.jpeg drilled and tapped2 holes 1/2-13 for bolts to hold the head down IMG_5799.jpeg IMG_5800.jpeg was worried that this wouldn’t be rigid enough but it seems real solid
    Still have to finalize it
    Need to drill holes to bolt it to the mill table but it is looking very promising
    Hopefully soon will be making chips
    Actually been preparing for this for 4 years that’s when I made the fly cutter anticipating the need to mill the heads
  20. Oldtmtech
    Oldtmtech
    Part 1
    Got a lot of material today so will break it up into a couple of posts
    Continuing with the head milling fixture
    My plate wasn’t flat so had to mill it flat was also a good test for my fly cutter IMG_5808.jpeg spent several hours tramming the mill
    Got it as good as I could about .0007” on a 9”dia. IMG_5804.jpeg IMG_5805.jpeg then I was ready to mount a head IMG_5811.jpeg IMG_5813.jpeg IMG_5817.jpeg All the preparation I have done was worth it
    Head was easy to set up and adjustments were precise and repeatable
    Head was staple and solid
    Started making some cuts IMG_5824.jpeg the carbide inserts dull pretty quick (probably a combination of cheap inserts and using lathe turning cutter for a milling operation but it is a positive rake insert)
    I did find that I could touch up the inserts with my diamond file
    Hopefully I can make them last through the second head
    Was left with a slight parting line when I finished but you can not feel it
    That.0007”from above IMG_5829.jpeg well pleased with the final result
    Better than I had hoped for again all the preparation made it seem easy IMG_5828.jpeg all the pitting from corrosion was cleaned up
    Removed.050”
  21. Oldtmtech
    Oldtmtech
    https://www.fordbarn.com/forum/attachment.php?attachmentid=5732&d=1275935985
    Part 2
    While doing some research I found this file on the ford barn
    It’s a comprehensive guide to compression ratios for flatheads
    My interest was on page 10
    Plugging in my 78 cc combustion chamber and my.030”over piston I have a compression ratio of 6.28:1
    After milling I couldn’t wait to see the difference so while it was still mounted on the mill did a quick volume check on cylinder 7
    Wow
    Brought it down to 68 cc
    Better than I had expected
    Compression ratio 6.96:1
    This is great a 3/4 point increase in compression with a more efficient squish area and little reduction in air flow
  22. Oldtmtech
    Oldtmtech
  23. Oldtmtech
    Oldtmtech
    Still working on the cylinder heads but taking a break this week
    A shot of the progress more to come soon IMG_5874.jpeg finished up the intake manifolds IMG_5861.jpeg IMG_5862.jpeg IMG_5863.jpeg IMG_5865.jpeg finished the porting and profiling IMG_5870.jpeg IMG_5871.jpeg IMG_5867.jpeg IMG_5868.jpeg IMG_5869.jpeg made a carb block off plate (got fancy added my logo) IMG_5864.jpeg IMG_5873.jpeg here is some useless info
    Carb spacer started at 1281 grams ended up at 662 grams
    Pre war swap meet is coming up this week in Luray Virginia https://www.mapwsm.com/
    Will give a review next week
    Always a good time
  24. Oldtmtech
    Oldtmtech
    Swap meet recap
    Another good year at the pre war swap meet
    A pair of extended shaft small logo 59 carbs (obviously the end carbs of a 3x2 setup) IMG_5922.jpeg carbs appear to be in great shape chokes deleted
    Be interesting to see what jets and power valves are installed
    I’m used to seeing nails used on my old tractors but didn’t expect to see them on a hot rod setup IMG_5924.jpeg a large logo 59
    The main body appears to be old but the top and base appear brand new no play in the throttle shaft at all IMG_5928.jpeg IMG_5929.jpeg to be totally honest I have been thinking about getting one of those cheap repro 94 carbs for the initial start up but with a gasket kit and new accelerator pump and power valve this will be better (got this carb for 5$)
    Paid a little money for this pieces but I think they may help me in a tight situation
    IMG_5937.jpeg IMG_5938.jpeg IMG_5939.jpeg IMG_5940.jpeg IMG_5941.jpeg IMG_0403.jpeg If you remember when I was working on generators and thinking about a mid mount fan I picked up one of these IMG_5931.jpeg a v8 wiring harness that I was told will fit a model A IMG_5933.jpeg a nice little rear view mirror IMG_5934.jpeg IMG_5935.jpeg fuel pumps IMG_5932.jpeg a fire wall this might help me for ideas IMG_5947.jpeg maybe using this on the inside and making a second fire wall on the engine side IMG_1232.jpeg picked up some more spare tire holders IMG_5944.jpeg use them for making hose reels IMG_5946.jpeg and then to prove that I am sick with flat head fever came home and followed up on a lead IMG_5949.jpeg IMG_5948.jpeg so now I need to finish the heads so I can get the’34 mounted on the run in stand which will free up the engine stand for the’35
    Nothing like a weekend of spending money to get you motivated
    I’m burning up with fever
    Some random photos of the swap meet IMG_5884.jpeg IMG_5885.jpeg IMG_5888.jpeg IMG_5890.jpeg IMG_5893.jpeg IMG_5894.jpeg IMG_5895.jpeg Old saw mill power plant didn’t get the belt pulley in the picture IMG_5896.jpeg IMG_5887.jpeg
  25. Oldtmtech
    Oldtmtech
    Just a little update
    Haven’t finished the heads yet but I’m really close
    I’ll do a complete review when I’m done
    It’s been a real learning experience and I would definitely do some things differently
    Got my old shop compressor moved IMG_5978.jpeg this will really increase my productivity
    While I was at the old shop I looked in on the rolling ch***is
    This is what the firewall looks like IMG_5951.jpeg IMG_5953.jpeg I think that was a good 25$ spent I think I will be able to use some of it especially around the drivers area
    ‘35 engine
    Motor is locked up but I will first clean it and then take off the heads pan and all and clean some more
    I learned from the first engine you don’t even start working on it until you clean all of that old qunk out
    The interesting part is that it looks like all the original hardware that maybe this engine hasn’t been into before
    That would be great because those floating rod bearings are alot easier to come by in standard size or even.002” undersized
    But of course this engine is just another distraction
    The only difference between the’34 and’35 are the’35 has studs for the main caps and there first attempt at crank case ventilation so I do have some spare parts for getting it to run
    Also it would be nice to know its condition for use as a backup motor IMG_5980.jpeg as often happens my mind starts thinking about other parts of the project
    I would like to run 2 oil bath air filters IMG_5981.jpeg That would involve siamising the 2 together
    That would put the cut line here IMG_5986.jpeg That might be hard to do I’ll have to think about that
    Haven’t found a match for the filter I have yet
    Maybe some s curve pipe
    dwollam likes this.
  26. I just found this thread...outstanding work, details and thought process! Thanks for taking the time to bring us along.
    I too have an all manual milling machine...I really appreciate your work (especially the free hand manifold spacer!), and effort to make and set up fixtures.
  27. Oldtmtech
    Oldtmtech
    Thanks for all the support on my journey
  28. Oldtmtech
    Oldtmtech
    Wow its been a month since the last cylinder head update
    I had actually gotten a little frustrated and took a step back but this last week I got motivated and finished the heads
    Everything went great after the break
    This first part will be what work I did and the final results and part 2 will be what I would do differently and some random thoughts
    We left off I had milled the heads (.050”) now was time to check piston and valve clearance
    It suddenly dawned on me why working on flatheads is so difficult
    When I worked in the race shop 35 years ago we checked piston and valve clearances all the time but you did it with dial indicators where you got accurate readings because your valves and spark plugs were overtop the pistons and any machining that was done was done to the piston dome and not to the cylinder head
    Valve in block engines are completely different you need to use clay or tinfoil to check clearance and I found this to be very difficult to get accurate measurements and time consuming
    This is the reason I chose going for zero clearance with no head gasket
    The gasket giving you your clearance
    I started with the head (right side) that had problems with the 2 center dome areas
    ****med everything then placed the head on the block with 4 studs then turned the motor over several times while gently rocking the head back and forth when ever the head raised up off the block IMG_5833.jpeg IMG_5834.jpeg got a definite line on the pistons of the 2 inside cylinders IMG_5837.jpeg after much thought came up with a way to remove material in a perfect circle IMG_5839.jpeg IMG_5841.jpeg IMG_5845.jpeg then took sanding disks on a drill to blend together IMG_5847.jpeg IMG_5848.jpeg IMG_5849.jpeg this is where I got really involved and didn’t always take pictures
    Keep repeating procedure removing material where needed IMG_5855.jpeg IMG_5856.jpeg that went better than expected then turned my attention to valve clearance
    I had bought large end mills several years ago just for this job
    Settled on the 1 3/4” IMG_5852.jpeg IMG_5853.jpeg IMG_5854.jpeg end mills don’t cut flat which in this case is fine because the valves are at an angle to the head
    I also adjusted the fixture to help with this angle (see part 2 post for more detail) IMG_5859.jpeg again didn’t take alot of pictures at this point
    Repeated procedure until all valves are clearanced
    Moving on to head number 2 (left side)
    Had to remove along the perimeter of the dome area for all 4 ( no clearance issues on the middle or center of the domes for all 8 just the outer perimeter)
    You all have probably seen this diagram IMG_6016.jpeg there is a call it 3* difference in valve angle between the right and left side and that makes a huge difference in valve clearance
    This is where I got frustrated and took a break before I messed something up
    Finally settled on using a small stone in the die grinder to clearance the small area of interference on each valve and then blending
    Final results IMG_6005.jpeg combustion chamber volume before and after
    1. 80 68 cc
    2. 78 68
    3. 76 67
    4. 78 67
    5. 78 69
    6. 80 70
    7. 78 69
    8. 78 68
    And by my previous calculations I am calling this a 7:1 compression ratio with enhanced squish area and increased air flow around the valves
    Next will be head stud install and capping off the short block
    rwrj likes this.
  29. Oldtmtech
    Oldtmtech
    Part 2
    Maybe not a good idea to remove.050” from a stock head with a high lift cam?
    I think with some modifications to my setup it can be done much better and easier
    I have since tapped the two remaining spark plug holes in my fixture so there is support when milling valve pockets IMG_5994.jpeg have also added bushings for the spark plug holes IMG_5988.jpeg IMG_5989.jpeg would also love to have a radius end mill for the valve pockets but I don’t see that happening
    I had used the jack screws to adjust for the valve angle (just guessed at it)
    I think I can install jack screws on the fixture plate and adjust the whole plate then use an angle finder to get a precise angle for each cylinder head
    Would also like to make a dimensional drawing of the cylinder head (have looked for one but haven’t found one) so I can center over each valve for making my cuts ( much like a modern day cnc mill)
    I know they also made a valve pocket cutting tool that used the stud holes
    I didn’t do this but I think you can use a feeler gauge for when the head lifts up to determine how much material to remove or even calculate a smaller clearance
    My dad had made this lettering fixture and it actually fit the plate (struggled with the spacing at first) IMG_5996.jpeg IMG_5998.jpeg IMG_5999.jpeg so now when they auction off my estate somebody might actually know what it is
    Would also like to have a cutter for the domes ( ol’ Ron talks about them in his book)
    But that might be beyond my capabilities
    Maybe if I had a set of aftermarket aluminum heads it would be worth while but the prices on 21 stud speed parts are pretty stiff ( that’s why I like cast iron heads)
    The new’35 motor will have the flat top piston so there is no advantage to milling those heads other than to gain compression and you lose all of your airflow then
    I really hope those aluminum heads don’t have to much corrosion they look good on the outside I’m dying to get into that motor but I need to get the’34 finished
    rwrj likes this.
  30. Oldtmtech
    Oldtmtech
    Came up with a quick drawing of the cylinder head if anyone sees a problem with any of the dimensions let me know IMG_6019.jpeg IMG_6020.jpeg
