Projects A/V8 speedster ‘Sat Nite Spcl’
Discussion in 'Traditional Hot Rods' started by Oldtmtech, Jul 28, 2022.
  1. Oldtmtech
    Oldtmtech
    IMG_6046.jpeg Heads are installed
    Didn’t have a full set of the factory washers and the washers that I had bought with the new studs and nuts were not as thick as the originals so I purchased these and then cut the OD down to match IMG_6056.jpeg IMG_6025.jpeg used spray copper gasket IMG_6041.jpeg IMG_6042.jpeg also needed to space the spark plugs
    Never had luck drilling copper washers but I had sealing washers from a kit and put them in a collet together and then drilled them out
    Worked great they are.055” thick IMG_6012.jpeg IMG_6013.jpeg IMG_6014.jpeg IMG_6015.jpeg I also bought some of these IMG_6057.jpeg took the fuel pumps that I had bought at the swap meet and installed new diaphragms that are supposed to be ethanol compatible
    The fuel pumps were brand new on the inside IMG_6001.jpeg IMG_6002.jpeg Hot humid summer weather has settled in so I may keep the engine in the climate controlled ba*****t for a while until I am totally ready to get it running on the run stand
    May switch my efforts to exploring the’35 motor
    Bigcheese327, rwrj and fatassbuick like this.
  2. Oldtmtech
    Oldtmtech
    Started some dis***embly on the’35
    I am determined to do this in a nondestructive fashion
    Took 3 hours to get the first head off only hour and a half for the second
    First look IMG_6061.jpeg IMG_6060.jpeg to be expected the aluminum heads have deep corrosion IMG_6080.jpeg IMG_6079.jpeg I am thinking for a running exhibit I can fill the corrosion holes with aluminum epoxy and mill flat
    If I want a road worthy engine I actually have a good set of flat top cast iron heads I had bought for the’34 before I switched to the dome pistons
    Determined that I had three stuck pistons and one stuck valve
    Worked on the valve first
    It was stuck open so was able to rotate the valve and work it loose
    Some how during working on it or maybe it was already I broke the valve spring
    Tried hitting the valve guide with one of those c shaped tools that go around the valve head to remove the valve guide but it appears to be super tight
    I think I can put in a valve spring the way it is
    I know I removed valve springs when I was dis***embling the’34 IMG_6082.jpeg as for the stuck pistons I just started hammering the tops of the pistons with a piece of oak and also hammering on a wrench on a grade 8 bolt that I had in the end of the crank also used a cylinder hone to clean up the walls
    After about 2 hours I have a free turning motor with all the valves going up and down
    Just as a side note I was getting a noise every 2nd revolution determined that because I am missing one valve spring you get backlash in the cam gear
    Then removed the oil pan
    At this point it needs a good cleaning but I have done a quick examination
    The camshaft looks excellent IMG_6089.jpeg as do the lifters IMG_6094.jpeg the core plugs in the pan rail look excellent IMG_6095.jpeg the connecting rods have no witness marks no punch marks no number stamps nothing
    It’s like it’s a new motor except there is about 3 inches of sludge in the bottom of the pan
    The oil pump seems to be stuck in place but I did remove the suction screen and end plate the gears look excellent
    I wish these motors could talk cause now we get to the pistons
    The pistons don’t have any markings other than a faint ford script IMG_6078.jpeg so okay you figure factory piston must be standard size
    The bore is measuring.010” oversize above the ring groove at the top of the bore and at the bottom of the bore and a big taper in between with clean wear pattern IMG_6081.jpeg this motor sure looks like it has never been apart before but here is the real mystery IMG_6090.jpeg it has the piston expanders
    Was this a reject motor that they put.010” over pistons with the spring expanders?
    My plans are to clean up the motor
    Remove 2 rods so I can measure the crank
    Look at one of the main bearings
    Remove one piston to measure and look at the rings
    Take notes for future reference and then put it back together with a new gasket set
    Also in cleaning out the old shop I found this IMG_6083.jpeg IMG_6084.jpeg IMG_6085.jpeg I’m thinking I can mount my head fixture to this to get my valve pocket angles on the milling machine IMG_6086.jpeg IMG_6087.jpeg also doing some mockup on the’34 for run in stand IMG_6058.jpeg IMG_6059.jpeg
    Outback and rwrj like this.
  3. Oldtmtech
    Oldtmtech
    What a beautiful morning
    Just got back from a motorcycle ride it’s been over a year since I’ve had the bike out been neglecting some of my other toys
    Someday hope to have the speedster out on a Sunday morning
    Back to the’35
    Used 4 cans of oven cleaner and the motor cleaned up good
    Got the valve spring installed IMG_6106.jpeg IMG_6107.jpeg IMG_6108.jpeg IMG_6110.jpeg Was able to get it in fairly easily
    This spring has more coils than the others but at this point a valve spring is a valve spring
    Noticed one bent valve and that may have been my doing when I was prying the head off
    I just used a br*** punch and beat it down into the seat and then checked it with a.0015” feeler gauge looks like it was sealing
    Checked valve lash
    All between.013”-.015”
    Noticed when turning engine over that the lifters are even rotating excellent
    So the valve train looks good next week we will start working on the bottom end
    Found a couple of surprises so check in next week
  4. Oldtmtech
    Oldtmtech
    Like to start off by saying thank you for the likes
    It lets me know that there is interest in what I am doing and I see some new names so welcome
    Start today’s lesson with video
    we left off starting to look at the bottom end
    Removed one piston
    The rings are all seized IMG_6116.jpeg did find the factory rod stampings they’re on the side of the rod IMG_6131.jpeg at this point I was thinking about how far I want to go
    Clean everything up and reinstall
    New rings
    Would require removing all 8 pistons
    Then with closer inspection noticed this IMG_6115.jpeg piston measures as standard size so decision is made new standard pistons and rings
    Removed piston from rod
    No c-clips so just gently pressed wrist pin out and discovered what I am guessing is original factory pins held in by a ring in the middle IMG_6112.jpeg IMG_6113.jpeg the broken piston was the only one that was missing the expander was wondering where it went
    Went out in the woods where I had s****ped out the gunk from the bottom of the pan and discovered this IMG_6114.jpeg just a little bit distorted
    Maybe the cause of the engine being parked?
    Like I said if this engine could talk
    Removed crank from block IMG_6140.jpeg eveything measures as standard
    Conclusion
    Untouched original 1935 motor
    Low miles
    And from my research the major problem with these early motors was the piston and cylinder bores IMG_6139.jpeg got in some new rod bearings IMG_6142.jpeg so next what I will do is hone the cylinder bores do a cleaning
    Spray some paint on the block
    Then do a swap with the’34
    Bring the’34 on the run stand out of the ba*****t to the shop then take the’35 to the engine ***embly room (the ba*****t)
    Put the crank shaft in the lathe for a quick polish
    Then re***emble with new pistons rings and con rod bearings
    a look at the crankcase ventilation system
    Air comes in at the back through the oil filler
    Then in front of the block there is a tube IMG_6135.jpeg with the p***age way coming out the bottom of the block IMG_6136.jpeg and then the pan has a separate chamber IMG_6137.jpeg that is open to allow air to escape IMG_6138.jpeg other thoughts and observations
    the valves look just outstanding IMG_6132.jpeg the intake runners have grinding marks like they were matched to the gasket IMG_6133.jpeg the oil pump idler gear bearing is perfect
    the head studs go in to the water jackets where the’34 are blind holes
    I’m glad I didn’t have this motor laying around when I was ***embling the’34 cause I would have stolen alot of parts
    Till next time
    jet996 and rwrj like this.
  5. rwrj
    rwrj
    from SW Ga
    When I rebuilt my 1928 Model A engine, I discovered that same circlip arrangement in the rods. I had trouble re-***embling them. The squared end of the wrist pen would **** up against the circlip and stop, and I didn't want to force it, so I turned a little round-nosed bullet out of bar stock. One end was just a few thousandths smaller than the wrist pin, and it tapered slightly to smooth round shoulder. The whole thing wasn't but an inch or so long. I just pushed it through ahead of the pin and it expanded those clips nicely. Hearing them pop into the grooves is quite satisfying. I really like your thread, and your knowledge and work habits make me feel inadequate. Haha.
  6. Some amazing tech here. Please keep the updates and detailed photos coming. You are helping alot of people.
  7. continentaljohn
    continentaljohn
    Great information and thank you for sharing your knowledge
  8. Oldtmtech
    Oldtmtech
    Thanks for the heads up
    I hope to reuse the pins with the new pistons so that may save me some frustration on re***embly
  9. Oldtmtech
    Oldtmtech
    As often happens when you are buying old parts off of the internet and really no ones fault, the pistons that I got in can’t all be used
    The problem that has come up is that standard size pistons are hard to find
    I had found 7 pistons that were hand labeled as standard but were not stamped on the piston top, turned out they were .025” oversized
    I’ll just add these to my inventory of parts that haven’t worked out I’ll be able to have my own booth at a swap meet someday
    Had also gotten one piston by itself and that one is good so we are back to just replacing the broken piston and reusing the rest
    Looking at the rings these have a one piece top ring three piece second ring and four piece oil ring which is actually the same as the old rings IMG_6160.jpeg IMG_6165.jpeg IMG_6164.jpeg IMG_6163.jpeg Got out one of my old books IMG_6169.jpeg IMG_6171.jpeg IMG_6172.jpeg Measured top compression ring at.006” actually alot better than I expected
    This got me thinking about when I was in my early twenties and my mentor at the time what I had seen him do and that was to recut the ring groove and install a spacer just like the ones that had come out of the old piston IMG_6168.jpeg IMG_6166.jpeg would have 2 problems with doing this
    1 the old spacers are worn to narrow so there would not be enough support for the compression ring
    2 my parting tool is 1/8” so would have to modify it for smaller size (.118” new ring.094”+.024” spacer)
    The old book says to recut the ring groove to the next fractional size
    In this case going from 3/32” to 1/8” which would be easy if I had 1/8” rings
    But we will learn later that all of this is irrelevant
    Also have to keep in mind the mission and not suffer from mission creep
    I will next have to clean each piston and check for any other damage
    In the event that I do need another piston I still have the.030” over flat top pistons that came out of the’34
    I do know that pistons are not machined round because of expansion but I feel I could machine a.030”over piston down to fit inside one of these worn cylinder bores (got to keep in mind the mission unless I can find another standard size)
    Although when dis***embled the wrist pin was centered obviously sometime it was not (original ***embly?)
    So you think that is why the broken piston
    Wrong different hole
    Although they share a crank journal (#4 and #8 cylinders)
    So this new development really doesn’t change anything
    It would require a overbore regardless for a proper rebuild just maybe now going with.050” over bore or a sleeve
    So again keeping the mission statement in mind just going to put a piston back in the hole
    Now let’s start talking about changes from’34 to’35
    If you go way way back to the beginning when I was putting in the motor mounts in the A ch***is I talked about the motor mounts sitting lower IMG_6148.jpeg IMG_6149.jpeg ‘35 on left
    1 5/8” difference between’34 and’35
    One of the’35 mounts needed repair but I was able to find a reasonable price pair of’34 mounts so now both motors will be the same
  10. Oldtmtech
    Oldtmtech
    Got the cylinder bores honed out a final cleaning then some paint IMG_6192.jpeg
    I think I saved another one from the s**** pile
    it’s really a shame that it has that wrist pin scouring
    All the other cylinders cleaned up really nice
    This maybe my last post for a little while
    Been neglecting some other projects
    The’35 will be ***embled this winter when it’s cold and snowing just like I did the’34 last winter
    I need to get the’34 running on the run stand which requires finishing the fabrication of the run stand
    But right now I have to start getting ready for the steam and tractor show https://www.somersetsteamandgas.org/pasture-party
    Been neglecting my old tractors
    Also have saved a date in October
    Been told I need to check out this show and after looking at some YouTube videos I am really looking forward to attending IMG_6179.jpeg have only gotten in one cruise in this summer because of weather so hopefully will get some cruise time in the second half of the summer
  11. Oldtmtech
    Oldtmtech
    I thought I would give you a short update on installing my distributor on the’34 but I had a little issue and I was going to refer you to an earlier post but figured out that I had never made that post so we need to go back in time……
    …… a few years earlier
    ‘34 distributor rebuild
    While I had several distributors apart thought it would be a good time to see if I could slot the mounting holes
    Why would I do this? It’s was a challenge and I was hoping to install timing marks on the front pulley so maybe having more adjustment on the distributor would be useful IMG_0933.jpeg IMG_0932.jpeg actually was easier and turned out better than expected
    While researching the distributors found out that the trick thing to do is use the’41 internals marked 11A on the end of the shaft because of the better advance curve and better points
    Was lucky enough to find a nos 11A advance plate and cam ***embly and installed that in my ‘34 case with the’34 rotor and side caps (I will need to do a separate post on the interchangeability of the’32-‘41 divers helmet distributor parts)
    Then needing a way to set the dwell angle made a fixture to mount the distributor in the lathe IMG_0931.jpeg IMG_0930.jpeg IMG_0928.jpeg should also make a post on setting dwell angle but there is plenty of information out there basically it involves blocking off one set of points setting dwell and then setting dwell with both points https://youtube.com/shorts/NsLUqthaV48?si=lvt7xmAJtJS16wxb
    Also need to do a post on using the slow motion feature on your phone as a diagnostic tool https://youtube.com/shorts/b9tAz7T7qW0?si=PAXlxgijwFeUeaIZ
    ……present day
    Drilled a hole for the cotter pin in my new cam ****on like the original
    The distributor tang all ready had a hole IMG_6208.jpeg IMG_6211.jpeg IMG_6212.jpeg IMG_6214.jpeg I set the timing using the buzzer feature on my multi meter and I am going for 4* btdc IMG_6205.jpeg first red mark is tdc first white mark is 5*btdc
    Second set of marks are 20* and 25* btdc for total advance
    Now here comes that previous work on slotting the mounting holes
    I had to adjust the distributors own timing adjustment and my slot adjustment all the way in one direction to get my 4* reading
    I am thinking that the combined tolerances of the cam, the adapter ****on, and the distributor are giving a retard timing reading and without my slot adjustment I wouldn’t have been able to obtain my 4* btdc
    With my previous posts on finding tdc and cam timing I am confident that I haven’t made any errors
    Also check my rotor ****on IMG_6217.jpeg and it’s pointing dead on number 1
    I will also have to do a post on my coil setup
  12. Oldtmtech
    Oldtmtech
    Needed to put helicoils in my fuel pump stand
    Milled flats on the back side so I could get it to sit flat in the mill IMG_6225.jpeg drilled and tapped for the helicoil IMG_6230.jpeg but I have to admit that I got sloppy installing the helicoils and screwed one of them up
    Was using the plastic installation tool instead of a good metal one and the helicoil skipped a thread
    Took some time but I salvaged it IMG_6227.jpeg you can’t get complacent with your machining practices
    Also drilled thru the backside will have to epoxy but that is up against the firewall so won’t be noticed IMG_6232.jpeg mocking up the front of motor so I can place the radiator IMG_6238.jpeg IMG_6240.jpeg I’ve got a lot of this 2” solid bar that I used on the front mount IMG_6239.jpeg think I will use the same for the radiator mount
    The extended fan mount was the first one I made using a pre shaped piece that won’t be used on the car but will come in handy on the run stand so I can get the radiator as far forward as possible to allow good access to the front of motor
  13. Oldtmtech
    Oldtmtech
    I’m back
    After a break from the project and enjoying the late summer and early fall
    So we left off mounting the radiator
    Bought a second radiator IMG_6270.jpeg instead of welding in the mounts bolted them in using existing threaded holes in the frame IMG_6323.jpeg and got some flex hoses IMG_6322.jpeg finished the throttle pedal mount that I had started when putting together the ch***is IMG_2296.jpeg IMG_6317.jpeg what I lack with my stick welding skills I make up with my use of a die grinder( I know longer have access to the tig welder that I was using back when I started this project )
    Just a refresher the throttle ***embly is model A with the ball arm turned 180* and I think a v8 spring with the ends rebent
    I used replacement model A throttle linkage for my original setup up IMG_2293.jpeg they were pretty awful the spring would pull thru the end
    Needed to make a new linkage for my high rise manifold so a big shout out to Vintage Speed (Charles Price on YouTube and realrodder on eBay) for having these linkage ends IMG_6318.jpeg IMG_6320.jpeg IMG_6321.jpeg 1/4-28 thread so I bent and threaded my own rod
    The ends fit the big new ball on the carb and also the old worn out model A ball on the arm
    I will be getting more of these in the future and also the progressive throttle linkage for when I add the second carb
    Bolted up the exhaust manifolds with new stainless hardware IMG_6329.jpeg starting to make flanges for the exhaust IMG_6332.jpeg 2 flanges for the run stand and 2 flanges for the car
    1 5/8” pipe
    1/2” thick
    Until next time
    Jeff34, fatassbuick, NoSurf and 3 others like this.
  14. Oldtmtech
    Oldtmtech
    Nothing much is currently happening on my projects but would like to share some future ideas
    About 35 years ago I had purchased at a auction of my local tech school a Bear ch***is dyno IMG_6341.jpeg it was unused but my genius dad was able to figure it out and he actually installed it in the floor of a ba*****t of one of the shop buildings IMG_6314.jpeg IMG_6313.jpeg IMG_6312.jpeg IMG_6311.jpeg I was never able to find any information for it but I did use it several times
    The platform and ramps dad had used as a grease rack
    I am now working on moving it
    IMG_6315.jpeg What I am thinking is that it would be more useful if I used the load cell as more of a engine dyno
    At least put a load on an engine on my run stand IMG_6308.jpeg When I had worked at the race shop we had a engine dyno and I just loved it
    This would probably happen with the’35 motor because the’34 will be going in the speedster ch***is
    Now that I’ve got most of the equipment moved and installed I’m thinking that for my year end rap up I will do a virtual open house and show all the equipment and maybe some video of the more unusual pieces
    set me on fire and NoSurf like this.
  15. PINEAPPLE
    PINEAPPLE
    This thread is just what we all need to get inspired for our projects. Thanks very much for taking the time to do***ent all of this craftsmanship you are capable of carrying out. I am now watching your thread, anticipating updates.
  16. Oldtmtech
    Oldtmtech
    Unfortunately the updates are coming in very slowly but I’m still trying to continue moving forward
    The good news is at my current pace you will be able to get updates for years to come
    Just wanted to show the control panel that I will be using for the run stand
    Again I am just reusing something that my dad built (same project that I got the frame of the run stand) IMG_6326.jpeg I just cut off the base that was for bolting it to the floor and welded it to a model A brake drum after doing a little machining to the bearing hub to fit inside the pipe
    Top folds up and already wired IMG_6199.jpeg IMG_6198.jpeg complete with a tachometer water temperature and oil pressure and also ignition resistor
    I just need to mount a coil and starter solenoid
    NoSurf likes this.
  17. Oldtmtech
    Oldtmtech
    We left off machining the exhaust flanges IMG_6332.jpeg got the mill set up and drilled the holes
    Then was ready for the center hole for the 1 5/8” pipe
    Dad was a big fan of hole saws IMG_6369.jpeg this collection is 9/16” to 3”
    Hole saws usually cut oversize so I used a 1 9/16”
    One of dad’s favorite tricks on using hole saws in thick material is to drill chip holes IMG_6346.jpeg With the chip holes I just used the power feed on the quill because you don’t have to stop for chip removal IMG_6348.jpeg pile of chips underneath IMG_6349.jpeg there used to be a bin full of these slugs in the old shop useful for washers and spacers IMG_6350.jpeg only needed.025” to clean up to final dimension did that with one p*** with the boring head IMG_6354.jpeg then to the bandsaw IMG_6365.jpeg and the big disc sander IMG_6368.jpeg It’s nice to have all the shop equipment set up and functioning
    Now starting to mockup the exhaust for the run in stand IMG_6361.jpeg IMG_6359.jpeg This is all good practice for when I have to make the exhaust for the speedster
    For the speedster exhaust I still plan on going with an original style cross over pipe and then either merging into one pipe or two pipes on the p***enger side And because the engine is sitting so low in the frame the exhaust will be on the inside of the frame
    Found this old photo you can just see the original exhaust bolted up CB4205AD-39B8-4D89-9854-AE828A0F5FB5.jpeg
    Bigcheese327 and NoSurf like this.
