A100 cargo van gasser or slammed
Discussion in 'The Hokey Ass Message Board' started by DoubleASedan, Jan 29, 2009.
  1. AnimalAin
    AnimalAin
    I'm not sure you've considered the technical aspects of this endeavor. Raising the van is certainly possible, but unless you are going to disect the whole vehicle and install a killer motor, it is almost totally without benefit. Even with a killer motor, it would probably work better at stock height. Lowering is possible, but has quite a number of substantial difficulties, not the least of which are clearances (to the wheel well right under the driver) and suspension geometry.
    If you can lower it effectively for a reasonable amount of money, I think you will dazzle and amaze quite a few of us......
  2. snagged these pics from ebay a couple years ago....
      37.4 KB
      40.4 KB
  3. DoubleASedan
    DoubleASedan
    I like that. Little bit of rake but on it's nuts
  4. Tony D.
    Tony D.
    I'm thinking lowered with a Scooby Doo paint scheme...:D
  5. koolkev
    koolkev
    from england
    Gassers rule.........
  6. Ned_Gob
    Ned_Gob
  7. Ned_Gob
    Ned_Gob
  8. Ned_Gob
    Ned_Gob
  9. Ned_Gob
    Ned_Gob
    Lowered in the front so far , but would love to slam it !
  10. rev106
    rev106
    Ever driven one of these things? Drift? Ha, that's a good one. At the local car night my girlfirend siad I should do a burnout in my van. I told her, no burnouts, the van will dissagree and something will fall off! These things handle like the ss minnow. [​IMG]
  11. A100
    A100
  12. 59mercsled
    59mercsled
    slam it as low as it will go i seen a van that drug doors at a show back when i was still in the custom truck sceen. It was tight as hell. but that look would work well on a nice set of mags or some white walls to.
  13. I like the lowered look too.
    I did the front and rear axle flip treatment on my Deora replica, with great success.
    However, the suspension travel is severely compromised, so consider C notching your framerails if you do this to your van.
    Either that, or try and find a place that will drop your stock front I beam axle.
  14. 1941ihkb5
    1941ihkb5
    got 14s up front on mine and a 2" lift in the rear with 295 60 15s in the assend both pickup and van. what a rake! looks killer. the only thing the van didnt about the rake was the ball n trunion u joint after the tranny failed so i modified my drive shaft to a regular u joint.
  15. Chaz
    Chaz
    They sit just fine the way they are.
  16. hifiguytn
    hifiguytn
    Slammed to the dirt.
  17. DocWatson
    DocWatson
    These are Econolines but Im sure they will work just as well with the A-100.
    Doc
  18. chrisclarkcustoms
    chrisclarkcustoms
    from las vegas
    Chopped chaneled sectioned...
    4406
    from Oklahoma
    I'm slamming mine. It's an 108 long wheel base window van.
  20. Cant beat a slight rake on the shorter vans.............kinda like that red dodge.....BITCHIN
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
  22. duke182
    duke182
    van- slam it!!!!!!
  23. slammin a van aint that easy kinda hard to move the wheels up when they are under your ass..JMO
  24. 4406
    4406
    from Oklahoma
    Whats wrong with a little road rash
  25. Drag race stance low down forward rake 15x32's out back and skinnies up front . Best to just accept it will corner like an elephant and on that note how about a blown hemi to keep you warm in there. Anyways my two cents, Rob.
