A833 Rebuild
Discussion in 'The Hokey Ass Message Board' started by ol55, Aug 20, 2012.
  1. ol55
    ol55
    from Virginia
    Trying to put this back together and the main shaft will not go into the input shaft after multiple tries. The pins (?) under the slider gear fall out or the gears/slider gear keep it from going in straight.The stop gear (syncro?) is on the input shaft. Are the any tricks to doing this? The only difference I see from the shop manual is that the case is vertical rather than horizontal when we are trying to do the install.
    Thanks,
    Larry
  2. HamD
    HamD
    I've never built a stick trans. that didn't benefit from having the slider in neutral between the input and the frontmost gear on the mainshaft. I'm not familiar with the "pins" or keys / struts on your box specifically but I'm used to blocker rings notched for clearance for them; can't see that on yours?
  3. Mr48chev
  4. dlmann
    dlmann
    from az
    i always install the input on the output shaft assembly on the bench without the front bearing-then install the assembly in the case --then install the front bearing and snap ring last----hope this helps -dave
  5. Me too on the assembly. I was thinking about a stray needle bearing.
  6. ol55
    ol55
    from Virginia
    Thanks for the advice. One of the pieces(3 total) that fall out is missing in the first photo. The slider gear is marked where the notches are in the synchro ring.
    We may need to put the input shaft on first but the mopar article shows it already in.
    Most of the time we don't get far enough to knock the bearings out...
    Larry
  7. daliant
    daliant
    There should be enough tension on the syncro struts (the 3 small rectangular pieces) to hold the slider in the neutral position without it falling out. Are you sure you have the strut springs in right? The bend on the end of each of the 2 springs should lock into 2 of the struts.
    Maybe the slider is off one tooth? The bumps on the struts should fit into the notches ground into the inside of the slider. You should be able to feel a definite detent as the slider moves from one side of the hub to the other.
  8. ol55
    ol55
    from Virginia
    Thanks for correcting me on the syncro strut. We got it today by taking the retaining spring off of the input shaft and dropping the shaft down (mounted vertically). At least that's how I think it happened.
    Thanks,
    Larry
