Technical A833 shift linkage help!
Discussion in 'The Hokey Ass Message Board' started by farmer013, Aug 13, 2024.
  1. farmer013
    farmer013
    Hey guys, wondering if anyone has info on a833 shift lever lengths?
    I have a trans from a 1971 a body mopar and got a few different shift levers with it , trying to figure which ones are the proper lengths. I realize theres info about how there lettered and numbered, but some have the numbers ground off. If anyone has measurements from hole to hole?
    Thanks in advance
  2. gene-koning
    gene-koning
    Can't help you with the measurements, but the one with the big curve is reverse. Past that, put the trans in neutral, put the shifter in neutral, and slide a pin through the shifter levers to lock them into position. and match up the levers with the rods. All those shift rods have adjustments on them.
    lostone, 2OLD2FAST and vtx1800 like this.
  3. lemondana
    lemondana
    from Lincoln NE
    Brewers Performance is the place to ask. They specialize in the Chrysler 833 4 speed. They have anything and everything for the 833. Phone Numbers are 937-947-4416 and 937-698-4259. Ask for Dan.
    choptop4 likes this.
  4. farmer013
    farmer013
    Haha that was my first thoughts, unfortunately there closed right now cause there at the mopar nationals, just my luck
  5. lemondana
    lemondana
    from Lincoln NE
    I forgot about that, somebody over on FABO mentioned that.
