a833 tails
Discussion in 'The Hokey Ass Message Board' started by erk_f-100, Dec 3, 2008.
  1. erk_f-100
    erk_f-100
    how difficult is it to change tails on an A833? If I buy an old iron mid/late 60's A833 WITH AN A TAIL IS IT EASY TO CHANGE OVER TO A B/E TAIL .
  2. 73RR
    73RR
  3. I think you would need to change the output shaft in the trans as that is the major difference, the length of the unit.
  4. Here is a good representation of the differences
  5. 46binder
    46binder
    from Kenosha,Wi
    Contact P***on Performance, Jaime P***on rebuilds 833's, would be able to help with ?s Or you could ask on the Moparts site
  6. slayer
    slayer
    If you are trying to put an A body tail in a B body trans forget it. the main shaft is not the same length. On the other hand i think early B body and late B\E body transmissions have the same length tail shaft housing, so the housing should interchange.
  7. TagMan
    TagMan
    PM "Truckedup" here on HAMB (all one word). As I recall he rebuilds A833 transmissions and would probably be happy to answer your questions.
  8. tomslik
    tomslik
    you get to tear the sum***** apart, not just pop the tailshaft housing off and swap it.***holes that design ****;)
    hey pm me!
    i've got something hanging on the wall you can use....
