Hot Rods Abandoned “custom” hot rod or never finished
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Jan 6, 2021.
  1. A39368D9-BE43-4F20-A9C2-811667F94B89.jpeg 2D83AAB0-9529-491B-9111-7102EFAA5DEF.jpeg
    015B31A3-7B95-4298-9621-195B4DFC3DE1.jpeg 137A24F7-82C4-4F3A-99F1-B6BEAB4075C6.jpeg
    crazy stuff comes up for sale. This jalopy has seen better days. Wonder if it was ever driven as a hot rod or the builder gave up.
    Lil32, Stogy, Budget36 and 2 others like this.
  2. Thats pretty bad.
    anthony myrick and hotrodjack33 like this.
  3. Crying shame right there.
    Looks like it was supposed to be something and is now not much of anything .
  4. Probably cobbled together by some kids and made a trip or two around the block before dad told them no.
  5. hotrodjack33
    hotrodjack33
    Here in Upstate NY (rustland) that would be marketed as "just needs some TLC ".:eek:
  6. Torana68
    Torana68
    from Australia
    after the doors were welded it was all filled and painted so I'm thinking it was finished, what do those engine mounts fit?
    anthony myrick likes this.
  7. inthweedz
    inthweedz
    Yeah, I was thinking about the thought that went in to those engine mounts as well... Wonder what was in there??
  8. It has the torque tube in another pic I didn’t post.
    Flathead?
  9. Stogy
    Stogy
    I'm sure it was one of the roadworthy jalopies of the past and I use that term with a little apprehension but even today there are pretty sketchy things operating on the roadways perhaps many times more dangerous than this was in its heyday...I'd love to know the story regardless...
    The smoothed trunk area and tailights seem to have some level of skill applied...looks like a rust belter for sure and seeing tires worn into slicks always freaks me out and speaks poverty and a desire to be a Hotrodder no matter where your financial position.
  10. Torana68
    Torana68
    from Australia
    ... and maybe a bolt on aluminium trans adapter, buy it and rebuild it
    kidcampbell71 likes this.
  11. 49ratfink
    49ratfink
    ""HOT ROD OR NEVER FINISHED""
    it looks like it is finished to me. finished, done, kaput...
    56don likes this.
  12. It’s offered at $1500
    id give a couple to to prove a point.
  13. AHotRod
    AHotRod
    It would make cool yard art
    Stogy likes this.
  14. Contacted the seller. No info other than it belonged to a deceased relative.
    Stogy likes this.
  15. getow
    getow
    Hmmm. Wild stuff, but somewhat worked for a minute or 2. Was obviously a low buck, use what ya got build. Shock mount extensions to use to long of shocks. Way short split wishbones. Motor mounts as already stated, were what they could make work. Steering column might be salvageable. Rear end, toque tube set up might be useful to someone also. Not $1500 of useful stuff tho. At least to me.
  16. lostone
    lostone
    from kansas
    Its one of those old man " its not for sale, I'm gonna fix it up one day" things.... I guess 1 day never came....
  17. I think I see a fairly thick coat of Bondo.
    Stogy likes this.
  18. Could have been an early drag car with the motor set up and the firewall....guess that motor torque is what did it in !
    Stogy likes this.
  19. Stogy
    Stogy
    I wonder when did bondo replace lead...just curious...I suspect it's period bondo...the doors were welded and skimmed I mean caked over...but again regionally fixing old shit has its challenges...
    The Shift Wizard likes this.
    Stogy likes this.
  21. Stogy
    Stogy
    I saw that too...crude flames molded with lead or bondo...beer infused...
    You know many of these wacky Hotrods may have been shared in B & W in their heyday right here...it looks to have been a Cabby or Coupester...Anthony did you ask just for provenance IF there may have been an old picture to put some of the past to the forefront...
  22. I guess this one is definitely not homogenized
    B Bay Barn and Stogy like this.
  23. Squablow
    Squablow
    First thing I noticed, too.
    Some neat bits there, I could fix that body, if I had the desire for one of these, but $1500 is pretty steep, and I'm usually an optimist when it comes to pricing stuff like this.
  24. Stogy
    Stogy
    ;)...your right just part of the BIG picture...thanks for sharing as choppy as it is it may have even saw ink who knows...
  25. Question. Say for instance this orphan ended up at your shop(no I’m not buying, just a hypothetical)
    Would you preserve the “art” on the qtr panel?
  26. Stogy
    Stogy
    If it was mine I would stand back and give it some thought once I had it straightened out at ride height how it all falls into place...the bondo or lead is holding it together...you can see a c notch in the body...this was lowslung
    If I was to keep it I might give it a more flame like flow...
  27. Stogy
    Stogy
    I really believe many Hotrodders had great ideas but lacked in execution...
  28. Stogy
    Stogy
    Then someone with that skill stole their idea and made it showworthy and claimed it as theirs...:oops:
  29. Mr48chev
    No but they didn't call my buddy JD Fikes in Waco Bondo John for nothing.
    The car isn' worth 1500 from what I see but I could see paying what the chassis is worth in the condition it is in for it. If you are actually interested in it, wait them out as long as you figure you dare an show up with cash an a trailer.
    An hour with a cutting torch and hand full of cut disks would double the value of that chassis if it isn't rotted out towards the back.
    Guys on here have fixed worse than that body but it might demand every skill you have and teach some new ones. I'd guess there is a hundred hours of patch panel install on it.
    Those shock brackets look tall because they are welded to steel plate scabbed to the frame rather than bolted to the frame, Probably to use the F 1 shocks that came with them.
    anthony myrick and Stogy like this.
  30. lippy
    lippy
    from Ks
    What was it? Lippy
    Stogy likes this.
