About Continental engines
Discussion in 'The Hokey Ass Message Board' started by DeS, Aug 10, 2004.
  1. DeS
    DeS
    from Finland
    In my Kaiser is it's original Continental engine, now I got a crazy idea to change a bigger flatsix engine in it, with many carbs. Anyone have knowledge about these engines? Kaisers engine is f-engine, is there bigger f-engines than 226? And how much bigger ones is available? Is the bellhousings same in all f-engines? It ain't problem to make a adapter, but would be much nicer if it's same. Thanks allready
  2. yorgatron
    yorgatron
  3. DeS
    DeS
    from Finland
    [ QUOTE ]
    i think the important question is,did your kaiser come with a hydra-matic ( www.rodnkustom.com/rocketeers/hydramatic/index.html ) transmission? if yes,then a cadillac or oldsmobile is an easy swap-george
    [/ QUOTE ]
    Yes, there is different crankend if manual or automatic transmission. In my car is a threespeed, overdrive manual.Continental engines are quite easy to find, because those are used in lift trucks and other that kind of working machines. Indeed it's easier to get parts and cheaper to blueprint Continental engine than many other engine
  4. wasn't that what the early '50's"spitfire" Chrysler six was,ot did they just fit the same?
  5. I wish I would have known that when I pulled mine. [​IMG]
