? about old style SUN tach and module...
Discussion in 'The Hokey Ass Message Board' started by dawg, Nov 16, 2010.
  1. dawg
    dawg
    I have a NOS module for my old SUN, and it had an old 1.35v battery in there that was original. My question is , will a new style aa 1.5 battery work? Or possibly a Nicad as they are usually about 1.35 volts? Sorry if this has been covered before, didn't find much with a search,and TIA...
  2. oldebob
    oldebob
    from Spokane WA
    Energizer E2 lithium AA 1.5v has been working fine for 5 yrs in mine.
  3. sololobo
    sololobo
    Great info, have a friend facing that situation right now. Great tip, Thanx! ~Sololobo~
  4. dawg
    dawg
    Thanks Bob, are they rechargeable? I was kind thinking of adding an external battery holder, so it would be more accessible? Any thoughts?...
  5. Automotive Stud
    Automotive Stud
    There were a few good threads just search for sun tach. I've been running the same AA batteries in mine for a few years now. I just take them out in the winter no need for rechargeables. I don't think it's as accurate as a new tach, but I don't know if it's from the age or the batteries or both. I only had about $15 tied up in mine so I figured worst case I blow it up and have to send it out anyway.
  6. oldebob
    oldebob
    from Spokane WA
    No they are not. They last a long time obviously. The real early Sun modules had a waferlike wierd battery that was hard wired in. It had to be unsolderd to be removed. These went bad and ruined the whole unit with corrosion like you wouldn't believe. Most of them use the replaceable battery. I also believe that they are not the most accurate tach . Probably why most serious comp cars, boats ect ran mechanical tachs back then.
  7. dawg
    dawg
    This is what I have and was really wanting to run it on the Lakes Roadster, as you can see my module is brand new. No corrosion inside, and hoping to run the new style batteries and everything works in it...
    what do y'all think?...
  8. AHotRod
    AHotRod
    Good info .....
  9. gwhite
    gwhite
    SUPER MODERATOR
    Dawg,
    Your Sun tach is a model D which dates it from 1946-1952 or 53. Mine is identical (red lettering and all) and is stamped 1-50 (January 1950). I believe the tachs with the red numerals pre-date the tachs with white numerals, but I have studied too few samples to be 100% sure.
    The transmitter you have is an EB-7A which dates from the early to mid-60's. If you want a period correct transmitter, look for a model E which uses a D cell battery, or a model EB with post terminals and a riveted-on tag.
    Here's a photo of my model D-3 tach and E transmitter;
    Come to think of it, I may have a correct mid-50's EB-9 (12v 8cyl) transmitter that might work for you...will see if I can dig it up.
  10. gwhite
    gwhite
    SUPER MODERATOR
    Here it is;
    Riveted-on chrome/enamel tag
    Electrical connection posts
    Dated January 1956
    Not sure if you're interested, but I have no use for this transmitter. PM me if you're interested, maybe we can work a deal.
  11. espo35
    espo35
    from california
    Nope. Won't work worth a poop. I guess it depends if you want your tach to be accurate or to just move when your engine goes "vroom-vroom".
    If you want it to be accurate, here is an email I received when asking for mercury batteries for my EB9a transmitter.
    I paid the 199.00 and it works sweet, now.... with no gay AA batteries taped to my ride.
    Hi Paul,
    There are no more mercury batteries to be had, and nothing else will work it
    correctly. We convert it to a no battery operation and it will work on any
    ignition system. The cost is $199. If you would like to send it in, you can
    send a check with your note or we can call you for a credit card. We will
    need the tach head as well to calibrate it to the box.
    Thank you for checking with us,
    Sandie
    @ Williamson's
    2018 E. Front Ave.
    Chester, AR 72934
    479-369-2551
