Projects ABS GM STEERING COLUMN COVER
Discussion in 'Traditional Hot Rods' started by Buckshot40, Mar 22, 2017.
  1. Several years ago I remember seeing an ABS cover for a GM steering column. It covered the column from the column drop/dash to the floor. Does anyone remember these covers and does anyone know if they are still available?
    Thanks,
    W.C.
  2. Mr48chev
    I remember seeing them advertised but have no recollection of where. A bit of searching found a thread that mentioned it on another board several years ago and the maker was Rod Doors who are out of business now.
  3. Atwater Mike
    Atwater Mike
    Out of business...Try later, under the present administration. 'Older out-of' businesses seem to be regrouping.
  4. Jalopy Joker
    Jalopy Joker
    had one, did not fit well - tried selling at swap meet for a long time - just form some thin sheet metal or, just use carpet to cover column.
  5. scrap metal 48
    scrap metal 48
    They sure were ugly...
  6. 325w
    325w
    Got one send me a PM.
    tb33anda3rd likes this.
  7. Frank Carey
    Frank Carey
    Bought mine back in the late 1980s. Still on car. Suits me. Don't remember where I got it.
  8. nmpontiac
    nmpontiac
    from Taos, NM
    ABS sheet material is available in 1/8" thickness from most plastic supply stores - making one ought to be pretty easy.
  9. TTTT8
    TTTT8
    Had one. Seems like I got it from Juliano's.
  10. Frank Carey
    Frank Carey
    Here's mine. The bulge on top covers the ignition switch. There's also a narrow bulge along the top that provides space for the rod that goes to the ignition switch and also for the wiring which breaks out just behind the column drop. Makes for a very clean installation. I'll be surprised if it's no longer available.
  11. mgtstumpy
    mgtstumpy
    Speedway have these upper and lower parts
