AC info - help needed
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Jun 5, 2012.
  1. Looking for some air conditioning info , book recommendation, or links.
    I have a computer controlled AC system that I need to have functional via 60s technology. I have very limited knowledge on AC, so this will be a learning experience.
  2. drptop70ss
    drptop70ss
    from NY
  3. Thanks, ill check it out.
  4. Any AC gurus in the house ?
    I know enough to be dangerous but I may be over complicating it.
    Pressure switch to shut clutch relay off maybe all I need ?
  5. 57 HEAP
    57 HEAP
  6. outlaw256
    outlaw256
    im needing to learn about ac myself.as long as ive worked on cars ac is not something i had a interest in. dumb*** me lol. ive got 4 underdash units now i have to see what else i need to get a couple of cars with cool wind. i am now old!! remember the days when we got a car with air and that was the first thing we took off! not anymore lol
  7. The computer makes sure high speed fan is on.
    * that's easy.
    The computer triggers ac compressor for initial start up.
    * that's easy
    The computer toggles AC clutch via pressure sensor readings.
    That's the fuzzy part at this point.
    Thanks Heap
  8. Iceberg460
    Iceberg460
    I'm no expert on A/C systems for sure, going off memory from a Ford cl*** I took a couple years ago, but can add a few things. Hopefully someone will correct me if I get things horribly wrong.
    Most systems will use 3 switches (often with 2 built into one part). The high/low pressure switch will shut off power to the field coil (compressor clutch) if for some reason the system over pressurizes, or if you spring a leak and lose all your refrigerant, this will keep your compressor from burning up. The 3ed switch turns the compressor on when pressure drops during normal operation.
    EDIT: Whats the year/make/model of car the systems from? Would be able to find more info for you.
  9. mattcrp1
    mattcrp1
    If you use a cycling clutch system as in a ford car, you need to have fixed orifice tube in the line. The two switchs operate in the two pressure side of the a/c system low and high. They are pretty basic and not to complicated.
  10. I don't thing what you are saying makes your system computer controlled the switches you are talking about are normal and relays can make the system work Do you have a computer for the system you want to install?
  11. Well it seems to be computer controlled,
    most certainly involves a computer, the computer determines how the system runs and cycles by its one sensor that has 5 volt reference and reads high and low pressures.
    I want to eliminate the computers involvement entirely.
  12. dirt t
    dirt t
    Dennis Overholser wrote a book "Hot Rod Wiring" I bought it on line at Wolfgang Publications.Page 138 has a diagram with how to.
    I would post it but I don't want to violate any copy right law.
  13. HighSpeed LowDrag
    HighSpeed LowDrag
    from Houston
  14. ...
  15. HighSpeed LowDrag
    HighSpeed LowDrag
    from Houston
  16. I need the system to work and function just like any pre 80s pre computer system did.
    I'm sure its relatively simple, I just don't have a good grasp on the theory or component function to satisfy the needs.
    I don't want this to go off topic any further than A/C already might be.
  17. badshifter
    badshifter
    Put a common a/c binary switch on the high side. That will disengage the clutch if no or low pressure. You can also wire in a thermostat with a probe that will control temp cycling. Check the vintage air catalog. You can buy them individually.
    http://www.vintageair.com/catalog11/pg75.pdf
  18. Bigchuck
    Bigchuck
    from Austin, TX
    If you want to learn all about auto ac, a good source of info is a training for manual ASE exam book. Maybe more info than you need, but it covers the basics for sure. Not expensive either.
