Hot Rods ac unit
Discussion in 'The Hokey Ass Message Board' started by 29moonshine, Oct 11, 2025.
  1. 29moonshine
    29moonshine
    anyone have any experience with restomod ac units or should stay with vintage air . it is for a 55 chevy
  2. BJR
    BJR
    VA all the way.
  3. olscrounger
    olscrounger
  4. '49 Ford Coupe
    '49 Ford Coupe
    Old Air Products out of fort Worth has the best performance design. They may even have a kit that fits your car. But their design is different in that the fan is a draw through the coil so the inlet of the fan it's not exposed to the interior and as a result it's quieter and gives better and more consistent air flow through the full face of the coil..
    https://www.oldairproducts.com/products?filtercache=64b21c7f-d148-4dae-8d4a-5f0fe9f0af52
    lostn51, jimmy six and TheC5Surgeon like this.
  5. TheC5Surgeon
    TheC5Surgeon
    I can second for Old Air Products. Just installed one on my 76 Burb.
  6. TheC5Surgeon
    TheC5Surgeon
    They have pretty good tech support also
  7. Bandit Billy
    Bandit Billy
    I installed the VA product myself in my PU and it was well planned, well designed and well built. AC blows cool, heat and defrost work better than any old car I've ever had.
    gimpyshotrods likes this.
  8. jimmy six
    jimmy six
    Old Air was my choice so I could remove my stock radio if needed. They will freeze you out on medium fan. VA does offer floor heat and can convert your stock heater controller as does OAP. I made my own panel. IMG_3882.jpeg
    6inarow, williebill, Ziggster and 3 others like this.
  9. lostn51
    lostn51
    from Tennessee
    I’ve used Old Air products on my shoebox and it was an easy install and worked great. Looked like the original heater box. I might put a VA in my woody because it’s a really big car and I know they will freeze you out.
    6inarow likes this.
  10. 325w
    325w
    VA Cl***ic Auto and Old Air make good stuff. Flip a coin to see where you go. VA has more electronics in my opinion
  11. bubba55
    bubba55
  12. gimpyshotrods
    gimpyshotrods
    I have tried everything, and will not ever install anything but VA.
    olscrounger and rockable like this.
  13. Ziggster
    Ziggster
    Wow! That looks factory!
  14. rockable
    rockable
    I've installed about 6 AC units. All but one was VA and all from here on will be VA. The first one I installed was not.
