Technical AC vs DC Stick welding
Discussion in 'The Hokey Ass Message Board' started by tubman, Sep 25, 2024.
  1. tubman
    tubman
    When I was a teenager, my dad bought a 180 AMP Miller "buzzbox" welder. I took to it like a duck takes to water. I used it to build my first hot rod and first two race cars. It stayed at my folks house when I moved out. I got a MIG welder about 20 years later when I got back into the hobby and have been reasonably happy with it. A while ago, I bought an inverter-based stick/TIG welder because I wanted to do some ch***is work. The inverter welder is DC only. In the ensuing 65 years, it looks like I have forgotten how to stick weld. I have a quality Auto-Darkening" helmet and have equipped it with a lense whose magnification matches my bifocals (a tip from a friend who is a professional pipe-fitter). I have run dozens of test beads and am continuously dissatisfied with them. Back in the old days, we had a stock of "farmer's rod" (6011/6013) and I just went to town. This time, I actually spent some time boning up on different rod types, and have tried fresh examples of every type applicable, all with equal lack of success.
    My question is if I am just (at 82) too old to weld, or could there possibly be enough difference between AC and DC welding that has caused the problem. BTW, I have asked a couple of friends to try the inverter welder and they like it just fine.
    chryslerfan55 and Sharpone like this.
  2. Dan Timberlake
    Dan Timberlake
    what stick rods have you tried with you DC welder?
    Sharpone and warbird1 like this.
  3. tubman
    tubman
    6011, 6013, 7014.
    Petejoe likes this.
  4. Bentrodder
    Bentrodder
    from Cotati
    What size rod are you using? How many amps is the machine? Being it is DC only, I am going to ***ume that it is a smaller 110 machine and I have found that they just don't have the poop to burn the rod properly.
    chryslerfan55 and vtx1800 like this.
  5. tubman
    tubman
    It's a 220 machine and I haven't run it at it's full setting (140 AMPS) yet, because I have had burn through problems when practicing on tubing. (I remember running the old Miller between 100-125 AMPS back in the day; that's why I figured 140 would be plenty.) Rods are 3/32" and 1/8" (nothing larger). I have more rod types that I can't remember of the top of my head which I will post when I get back from my shop.;
  6. 2OLD2FAST
    2OLD2FAST
    from illinois
    When you say DC , do you mean DC RP ? I bought an AC/DC that had reverse polarity option & found that to be an improvement over my old AC Lincoln buzz box ,( 30 years ago) .
    6010-11-13 7014-18 ..
    chryslerfan55, deathrowdave and finn like this.
  7. tubman
    tubman
    It will run both (which I've tried).
  8. Bandit Billy
    Bandit Billy
    82? No pacemaker with Defib I hope. You'll get more than a lousy bead if you do.
    deathrowdave and Happydaze like this.
  9. tubman
    tubman
    Nope. Checked with the Doc; he didn't like it (on general principles, I think), but gave me the go-ahead.
  10. 2OLD2FAST
    2OLD2FAST
    from illinois
    I use 6013 @ 90A , DC RP most of the time as a drag rod , @ 76 , even with a 4x magnifier lens its getting harder to see ( wet AMD) .
  11. tubman
    tubman
    I'm finding a lot of things I'm "too old" for; I hope this ain't one of them. That'll mean a few unfinished projects.:(
    warbird1 and Bandit Billy like this.
  12. alanp561
    alanp561
    6011, 6013 and 7014 work best on AC. 6010 and 7018 work best on DC reverse polarity.
  13. Alan beat me to it. At tech school, we learned on DCRP and used 7018 rods.
  14. lostone
    lostone
    from kansas
    I always liked 7018 rod....
  15. tubman
    tubman
    Never tried either 6010 or 7018. Time to buy some rod. It's starting to sound like there is a bit of difference between AC and DC stick welding.
  16. Petejoe
    Petejoe
    from Zoar, Ohio
    7018 requires DC polarity.
  17. tubman
    tubman
    Given the reason for this thread, I sure hope so.:D
    Sharpone, alanp561 and Petejoe like this.
  18. ct1932ford
    ct1932ford
    7018 is the way to go!
  19. Petejoe
    Petejoe
    from Zoar, Ohio
    That’s all I ever used on high pressure vessel X-ray welding.
    Handles very well with minimal splatter and washes impurities very well.
    Most of the 6000 tensile strength rods work very well with dirty, rusty and oily metals.
    (Farmer’s rod) :)
    7018 burns hotter and works well with washing slag from the weld.
  20. drtrcrV-8
    drtrcrV-8
    Make it easy on yourself : 3/32" 7018 set at about 105amps DCRP for openers, then adjust to suit. keep the rod you're going to use in some kind of "rod oven" to keep it dry : any small insulated box you can seal up & put a small light bulb in to provide heat will work fine.
    Sharpone and alanp561 like this.
  21. Forty years ago, I had the use of an ancient AC welding machine. A welder friend of mine suggested I get some 3/32 7018 AC rod, designed specifically for machines like the one I was using. Worked well. Lots of upgrades to welding technology today, even that 7018 rod.
    warbird1, chryslerfan55 and Sharpone like this.
  22. Roothawg
    Roothawg
    Man….7018-7024…brings back memories.
    warbird1, lostone and Sharpone like this.
  23. jimmy six
    jimmy six
    6013 is for flat plate..we called it mud rod at our power plant. I had a red Lincoln AC/DC 220 195 amp and it was perfect. 7018 is a great rod DC only and I’m back yard guy at 80 years old now. We bought a Hobart mig and I became pretty good.
  24. 2OLD2FAST
    2OLD2FAST
    from illinois
    Hard to buy a light bulb that emits heat these days .
  25. tubman
    tubman
    I've got a"built-in" house oven converted for powder-coating (and free electricity in my shop). I'll bet I could use that. Got a recommended temperature?
  26. alanp561
    alanp561
    7024 JetWeld. Greatest thing in the world for welding flat down or filet welds. Ran miles of Jet on the floors and roofs of oil storage tanks. Set your heat right and you can watch the slag peel off the weld. Rarely have to power brush or grind it. @tubman, wish that I lived closer to you. Oh ****, what am I saying, it gets cold where you are! Wish you lived closer to me; I could get you back on track with your welds pretty quick. All you need is good eyesight and practice, practice and more practice. Oven temp at 250 F. If your rod has been sitting around exposed to humidity, put it in the oven for 4 hours. Don't forget to use your gloves to handle it.
  27. tubman
    tubman
    Not a problem 'cause I go to Florida for the winter. (It is required when you get past a certain age.)
    I ordered 5 lbs of 7024 "Premium" 1/8 rod from Amazon just now. They did have "Jetweld", but the minimum order was 50 lbs! (I can't believe there's that much difference.)
  28. alanp561
    alanp561
    Most of the welders I knew could easily burn 50 to 75 pounds of Jet in a day. By the way, 7024 runs better with DC straight polarity.
    Algoma56 and Sharpone like this.
  29. tubman
    tubman
    Lemme see if I got this right; Reverse polarity for 6010 and 7018. Straight polarity for 7024.
    Sharpone likes this.
  30. alanp561
    alanp561
    Right, you got it
