Technical Acc supply to Relay fused?
Discussion in 'The Hokey Ass Message Board' started by Jeremy Shay, May 22, 2016.
  1. Jeremy Shay
    Jeremy Shay
    from Las Vegas
    Does the acc source need to be fused on a relay? (Relay is line, load, ground, acc)
    I stole what seemed to be acc power(radio acc) on an 'out of the box' unit. That worked well in testing, but after terminating ends, I dropped from 12 volts to .13.
  2. squirrel
    Fuses are there to protect wires. If there's a wire with voltage at one end of it, and it could get shorted, what would happen? Would the wire get hot and start a fire? or would a fuse blow?
    No way of knowing what you need without more info, sorry.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ???? Also, what's a "out of the box" unit ? Aftermarket fuse box, wire kit ? Pic's please.
  4. Jeremy Shay
    Jeremy Shay
    from Las Vegas
    Disregard... problem solved. A lighted switch had a misleading label; and popped a fuse.
    Terminating ends = putting something at the end
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Now that would be equal to a terminated circuit ;)
