Accelerator retrn spring install ('38 Ford)?
Discussion in 'The Hokey Ass Message Board' started by Big Earl, Dec 10, 2010.
  1. Big Earl
    Big Earl
    Can someone tell me how to remove my broken accelerator return spring and install the new one? I could cut the original on off, but cannot get the new one on.
    Thanks,
    Earl
  2. looks like you could work it around those 2 90 degree corners. or heat the bottom one or use a different spring somewhere else. you're right "I'm no help"
  3. TomT
    TomT
    I did this for the car in my avatar not long ago (mid summer maybe?) - I did it just as noname said. Just takes a bit of patience ....
  4. BISHOP
    BISHOP
    You can get it on there, just have to spin it.
  5. Big Earl
    Big Earl
    Used a cut off wheel to remove the broken spring, and with some finagling and patience I was able to bend it around each corner. Installed... no more stuck throttle!!! Thanks guys.
