Projects Achievable Pre-War Supe Job Build
Discussion in 'Traditional Hot Rods' started by RyanAK, Sep 17, 2022.
  1. Rather than a washer either side of the axle, I normally turn up a fatter spacer and put it under the axle for that extra 1/8" drop...
    RyanAK and Six Ball like this.
  2. RyanAK
    RyanAK
    Hi friend! I originally had it set up like that but my thicker spacer wasn’t quite thick enough to fill the gap. For whatever reason I wasn’t keen on stacking washers so I split the difference. Good eye!
    Six Ball likes this.
  3. RyanAK
    RyanAK
    Does anyone have information on this accessory “STOP” light? My good friend Hitchhiker Matt at Seattle Speed Shop managed to source a bucket and bezel in his stash, but no lens. Spencer is smitten and brings it up whenever we’re working on the car. “It says ‘STOP’! Why don’t new cars say that?”
    Good question, kid.
    I’ve been looking for one since before I owned a ch***is. Ha. Any help appreciated!
    There was a similar one with a blue lens too, but I’m not sure you can run them with modern laws…
    Ragged Edge and 41 GMC K-18 like this.
  4. 5window
    5window
    You could ask this guy: http://www.taillightking.com/ and check your PMs!
    Six Ball, RyanAK and 41 GMC K-18 like this.
  5. 5window
    5window
  6. 41 GMC K-18
    41 GMC K-18
    Hey @RyanAK
    I have one that is like the one, that was mentioned about from Matt @Hitchhiker
    It even has the mounting bracket as well, and the lens isn't broken.
    If this interests you, and if it will keep the kid happy, PM me and include your mailing address and I will donate it to the project.
    Don't let the "JESUS" name badge cause any confusion, it was just stuck on that big piston.
    Enjoy from Dennis.
    Bigcheese327, Steves46, brEad and 8 others like this.
  7. RyanAK
    RyanAK
    Geez Seattle people are great. Must be the salt air and evergreens. PM inbound Dennis!
    Great leads, Jeff! I’ll take a look at my inbox soon!
  8. 41 GMC K-18
    41 GMC K-18
    Hey @RyanAK
    I replied to your PM, the light will be boxed and sent in the mail tomorrow !
    Thanks from Dennis in Seattle.
    Steves46, Hitchhiker, brEad and 6 others like this.
  9. 5window
    5window
    Dennis, that is very generous. Spencer is a very cool kid and it will mean a lot to him.
  10. Outback
    Outback
    from NE Vic, Oz
    That brightened my day, can't imagine how excited Spencer will be! :D
    brEad, Six Ball, Ragged Edge and 2 others like this.
  11. 41 GMC K-18
    41 GMC K-18
    These engines were so cool, when adapted to the pietenpol air frame.
    Six Ball and RyanAK like this.
  12. RyanAK
    RyanAK
    Totally agree the cool factor is high. Wonder if Spencer would want to build an airplane from nothing…
    Isn’t there wonderful people in this life? Say ‘pre-war’ and the clan rallies to get one of these cars built. Add in a special kid with a vision and drive to do work on the car, and ALL the clans rise. People have been super kind and generous. ‘5window’ is a neighbor and friend. He helped amp Spencer to the idea of building a car by giving him a tour and providing enough old hot rod mags to fill the trunk of a ‘63 Olds.
    Still have your trophy from Spencer’s car show, Jeff? :)
    Special people. Thanks everyone. And know Spencer recognizes and appreciates the kindnesses.
    CSPIDY, Six Ball, Ragged Edge and 2 others like this.
  13. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Ryan;
    When you get the new lens n light, you could make(cast) a duplicate of the lens. Could possibly use the broken one, but I think it'd require a couple castings to get the crack outa the final lens. For extras in case one breaks, or someone else needs one. I know gl*** is best(or at least most wanted/preferred) - in which case I'd have a gl***blower duplicate it after making a proper mold for it. Since plastic is easier, go to Smooth-On plastics. They have all kinds of plastics, & the silicone material to make a perfect casting. Not all that expensive. You might want to experiment w/tints to get a good yellow, then for the red,(I'm ***uming you'd use one of the clear plastics), if you don't want to cast two pieces, use model-car candy red paint on the backside of the lens. Just lightly & completely sand the backside 1st where you want to paint, & the candy will come out great(no primer, no base-coat, & no sanding marks will show thru. If you would rather mask, then sand, tape & candy w/yellow & then red. Trick I learned eons ago for model car windshields, side n backlights, headlights, etc for anything made of clear plastic. Of course, the plastic-type has to be able to hold the paint...
    I realize you're short on time, but in winter, maybe? Spenser could even do it. :) .
    Marcus...
    Carter, Six Ball, 5window and 3 others like this.
  14. 5window
    5window
  15. Six Ball
    Six Ball
    from Nevada
    Spencer is clearly thinking at a different level than a lot of other kids. Just the single word actually means something and is part of a concept about safety/warning that is lost on many. His mind is working on similar tidbits all the time he is working. Maybe a plane is in his future.
    How cool that people here step up. I see it in lots of threads where the build captures the readers. This one has done that!
    Outback, 41 GMC K-18 and RyanAK like this.
  16. 5window
    5window
    Quite a few folks have won a Ridler or AMBR. But how many have one of these??
    Slightly the worse for wear from display.
    tb33anda3rd, brEad, Outback and 3 others like this.
  17. RyanAK
    RyanAK
    Jeff, that’s just amazing! Thank you!
    Marcus, great idea. Matt and I have actually talked about doing something similar.
    Six Ball - Spence is thinking on a different level. He’s an old soul and very considered with a reason and logic many on the Spectrum exhibit. And there are some cool cats stepping up here to bring this car - and Spencer’s vision - to life. Wonderful people. We’ll need to find a way to honor all the contributors. Maybe something like a timing ***ociation tag on the dash with everyone’s name stamped into it…
    Carter and 41 GMC K-18 like this.
  18. RyanAK
    RyanAK
    A complete front end… that I’ll likely need to take apart again. Sheesh. The tie rod isn’t perfectly straight. What’s my tolerance here?
    Six Ball and 41 GMC K-18 like this.
  19. 41 GMC K-18
    41 GMC K-18
    Hey @RyanAK
    The package is on its way, I sent you the tracking number in a PM.
    The package should be there on 8/21/2023
    Keep wrenching on that great project with Spencer!
    Thanks from Dennis.
    Outback, Six Ball and RyanAK like this.
  20. Six Ball
    Six Ball
    from Nevada
    Other than looks the critical part of a tie rod is the distance between the ends. A perfectly straight one might be a little stronger.
    Outback, RyanAK and 41 GMC K-18 like this.
  21. Wow- another one you need to consider for the Friday art show, tell me it is alright, and I will post it up for all to enjoy. 2F3C3CC9-4B2F-4C1C-984F-4885505F80E8.jpeg
  22. 5window
    5window
    Fine by me,but you should clear it with RyanAK-Spencer's Dad
  23. RyanAK
    RyanAK
    Feel free, friend! Share anything I’ve posted… just attribute to me or Spencer and point people to this thread.
  24. wheeldog57
    wheeldog57
    Very cool and very achievable project
  25. RyanAK
    RyanAK
    Thanks, pal. Aside from building a car with the kids, I do hope this thread will show that a traditional pre-war car can be achieved by someone willing to learn and wrench. My job imposed time restraints. My home imposed workspace constraints. My skills and knowledge base placed additional restrictions. And I imposed a budget. If a knucklehead like me can get a car built under these cir***stances, a nice, traditional hot rod is likely achievable for the willing no matter the box they’re working in.
    I will say this… the single most important tool is community. I’m in very rural PA and still have found a few guys that have become friends relatively nearby. Others are far flung. The H.A.M.B. community has thrown support behind the rallying cries of ‘pre-war’, ‘achievable’ and ‘kids’. These cars can be built. They can be period correct. They can be affordable. And they can be achieved… but not without community.
    I brought the first ch***is home last September 15. My goal is to have the rolling ch***is complete and the body mounted. That will give us a ‘car’ that we can ***le. Not too bad considering the challenges of the past year. I’ll do a recap of work and spend then, just to see where we are. It should be enlightening!
  26. RyanAK
    RyanAK
    I need tires. I’ve found affordable 19” rubber… and I have 19” wheels. Can put tires on for ~$650. But I think this car should really be rolling on 18” or 17” wires. Seems the tire situation there is super spendy. Anyone have suggestions on reasonably priced tires in 17” or 18”?
  27. wheeldog57
    wheeldog57
    Good luck with the tire search. They'll pop up if you keep looking. Looks like a furnace or boiler where you work, we insulate all that
  28. nrgwizard
    nrgwizard
    from Minn. uSA
    Have heard good things about Blockley Tire(s). Seems they have some for 16,18,&19", all priced sorta similarly.
    Not sure if those're considered affordable, but Lester also does old-style, as does Lucas. Not horrible on price.
    & then there's the "NO-SKID" tires... :D .
    Marcus...
  29. Six Ball
    Six Ball
    from Nevada
    I have a set of 19" for my '26 Chevy roadster project. I got all four tires on eBay. The fronts are 400x19 Goodyear Eagle D/T motorcycle tires. The rears are 4.75-5.00x 19. They say UNIVERSAL on the sidewalk. I didn't spend a lot on them but I can't remember how much. Decent deals are out there but it may take time to find them.
    41 GMC K-18 likes this.
  30. RyanAK
    RyanAK
    Here’s what I’ve found…
    19”
    • Lucas Olympic 475/500-19s - 29.88” OD - $119
    • Lucas Blackwall 650-19s - 31.50” OD (not sure these will mount on stock Model A wheels…) - $199
    • Lucas Nokia (“Euro” style) 550-19s - 30.50” OD - $149
    • Universal (Coker) 475/500-19s - 30.00” OD - $142
    18”
    • Lucas Olympic 450-18s - 27.38” OD - $119
    • Lucas Olympic 525/550-18s - 29.38” OD - $139
    • Lucas Blackwalls 600/650-18s - 30.50” OD - $169
    17”
    • Lucas Olympic 525/550-17s - 27.50” OD - $139
    Pretty much the next step up is into the ‘name’ tires with the matching pricing. $270-$350 for Firestone, Goodyear, BFG, etc.
