Projects Achievable Pre-War Supe Job Build
Discussion in 'Traditional Hot Rods' started by RyanAK, Sep 17, 2022.
  1. RyanAK
    RyanAK
    Thanks, friend! Always stay local if possible!
    What’s the temp in the barn? Are you and your bride surviving over yonder?
  2. AmishMike
    AmishMike
    Fat guys armpit in the jungle - tks for that image. Think I will go take a shower. Hit 102 in south east penn with our normal hi humidity
    Outback and RyanAK like this.
  3. Six Ball
    Six Ball
    from Nevada
    That image won't wash away. He said it and we ate stuck with it. :(
    AmishMike, Outback and RyanAK like this.
  4. RyanAK
    RyanAK
    Yeah. Sorry for the mental imagery. Mike… be glad I didn’t use any Amish metaphors. I live in an Amish town and you should hear the jokes they make about the heat and humidity. Sheesh!
    Brakes all together and all moves as it should. Emergency brakes hooked up and adjusted. Now to go through all the service brake adjustments.
    Once brakes are set, I can go through and cotter pin everything that’s going to be a pain to get to once the body is on. Which is everything.
    THEN we can start ***embling sheet metal and making this look like a car!
    V8-m, brEad, 41 GMC K-18 and 6 others like this.
  5. Martinbuilt
    Martinbuilt
    Great progress. I'm amazed how much you've accomplished out-of-doors.
    I really need to get my act together.
    Six Ball, Outback and RyanAK like this.
  6. RyanAK
    RyanAK
    Our acts all move at different speeds. It’s just about string in an hour to another hour. Thanks for the encouragement!
    41 GMC K-18, Six Ball and Outback like this.
  7. RyanAK
    RyanAK
    Do I look fast?! I feel fast.
  8. Outback
    Outback
    from NE Vic, Oz
    Real dang fast! :D
    Six Ball, Martinbuilt and RyanAK like this.
  9. 5window
    5window
    My dad always said it was better to be fast than half-fast.
  10. RyanAK
    RyanAK
    There’s a lot of work in one of these period correct cars to go not very fast. :cool:
    I think the next t-shirt will be “Amphetamine Bunny”. You know. All GOW’D UP! :p
    41 GMC K-18, Outback and Six Ball like this.
  11. RyanAK
    RyanAK
    How vital is it to have this perfectly vertical? I got a rod or two that’s just a bit short to reach the brake levers without being dangerously close to the end of the threads.
  12. I'd say that was perfect.
    RyanAK likes this.
  13. RyanAK
    RyanAK
    Are we talking the brake cross shaft arm is perfect… or my rugged good looks? :p
    hotrodfil and Six Ball like this.
  14. Six Ball
    Six Ball
    from Nevada
    The brake looks good. :rolleyes:
    RyanAK likes this.
  15. RyanAK
    RyanAK
    Fantastic!
    And also… awww nuts! :cool:
  16. RyanAK
    RyanAK
    I think today is the day we get the brakes fully sorted. I’m so close! That will complete the ch***is. Then we can start ***embling the car and fooling with the banger. Exciting times!
    Next t-shirt, methinks…
  17. ModelAMitch
    ModelAMitch
    My mechanical brakes look very similar to your photo and they work fine.
    Six Ball and RyanAK like this.
  18. RyanAK
    RyanAK
    Thanks, Mitch. All the “tech” stuff aimed at restorers and such say the cross shaft should be vertical and all rods a precise measurement. That doesn’t always work with 94 year old parts! My engineering mind kicked in and said I’m ok… but doubt lingered.
    41 GMC K-18 and Six Ball like this.
  19. RyanAK
    RyanAK
    You can’t make this stuff up… sigh…
  20. RyanAK
    RyanAK
    Placing this here because I'll lose the envelope it's written on...
    NEXT TO DO:
    • Brake rods - set length and take up free play
    • Install return springs/anti-rattlers
    • Adjust brakes - per service procedure 60%+ Rear bias
    • Brake light switch
    • Cotter. Pin. Everything. Ugh.
    • Shocks - bend arms and install dog bones. May need hotter torch... Air/Acetylene might not do it. Oxy/Acetylene... small set up??
    • Install running board brackets. Need to knock out some old rivets.
    • Install splash aprons
    • Install radiator shell - new grommets and lacing
    • Install radiator apron - new felt
    • PREP BODY! HORRAY!
    • Brush paint body - what color...?
    • Transfer body to ch***is
    This may take two weeks. Or 6 months...
    J.Ukrop, Ragged Edge, brEad and 5 others like this.
  21. Outback
    Outback
    from NE Vic, Oz
    Gardener at it again!
    List is looking good, you are certainly getting there. :)
  22. 5window
    5window
    Sorry, missed this. Barn and shops are right warmish with no cross ventilation. We're doing fine even without AC-just fans. The bride! just celebrated her 51st anniversary at the seaside in Oak Island, NC along with all the kids,grandkids and partners. An, me,too.
    Outback, 41 GMC K-18 and RyanAK like this.
  23. 41 GMC K-18
    41 GMC K-18
    Hey @RyanAK
    Bravo on the fine progress of this great project.
    I ***ume that this unit, has been opened up and totally inspected by now?
    I know that at this stage of the project, it may be on the back burner.
    On another note, you might want to go check out my build thread on the antiquated section
    ***led "FORD COE HEADLIGHT UPDATE"
    Guaranteed to bring a smile to your face!
    Thanks from Dennis.
    RyanAK, Ragged Edge and Outback like this.
  24. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    @RyanAK any jalopy plans for the weekend? I've really been enjoying the progress!
  25. RyanAK
    RyanAK
    Joey! The plan is to drain the oil and find out what floated away…
    Six Ball, Outback and 41 GMC K-18 like this.
  26. Hitchhiker
    Hitchhiker
    So sorry pal. We'll get it sorted.
    J.Ukrop, Six Ball and 41 GMC K-18 like this.
  27. RyanAK
    RyanAK
    It looks worse in black and white…
  28. brEad
    brEad
    That ****s! Hope things end up better than that looks.
  29. Martinbuilt
    Martinbuilt
    OMG Ryan, that sux.
    Hopefully, Spence isn't too rattled.
  30. 41 GMC K-18
    41 GMC K-18
    Hey @RyanAK
    Totally blown away by what has happened there in your area, its going to be a long recovery no doubt.
    Let the HAMB universe know, about what ever you need, that we all can help with, in what ever capacity that is applicable !
    After all of this over and kind of dried out, it might be a good thing to consider at some point in the future, about some higher ground to maybe get all of the parts together, to be at!
    I know that sounds ridiculous at this point, but you get my point.
    Hope Spencer is going to be re***ured that it all will work out okay.
    Positive thoughts to you and the family from Dennis.
    Six Ball, Outback and brEad like this.
