Technical Ackerman question
Discussion in 'Traditional Hot Rods' started by Truckedup, Feb 4, 2014.
  1. Truckedup
    Truckedup
    The build of the drop/belly tank car is moving forward...The owner wants the front axle narrowed 4 inches and the rear axle left stock width. The axles are 47 Ford front and rear, the wheelbase will be 112 inches. I believe 47 Ford wheelbase is around 114 inches.
    Question, will reducing front axle width 4 inches affect the Ackerman enough to work about? This car will be a toy and not raced and only driven short distances ....Thanks
  2. revkev6
    revkev6
    from ma
    I would at least check it.... not hard to do. i'm guessing the axle is not going to be dropped??
  3. Yes, not hard to check.
    Draw it up and see, slight twerk on the steering arms should correct it.
    Ackerman becomes increasingly more important the further the wheels are from straight ahead, and not very important the closer the wheels are to straight.
  4. Truckedup
    Truckedup
    Yes, axle not dropped.....Duh..layout....I'll mock up the axles on the floor and check it... Thanks
  5. junkman8888
    junkman8888
    Greetings! Don't worry about it: Think about all the pickups you see on the road, some short bed, some long bed, some extended cab, all use the same spindle with a different wheelbase. If Ackerman was that critical, they would all have a dedicated spindle.
    Another thing: Before you narrow anything make sure the front and rear axles will end up having the same track width. If the front is narrower than the rear the front tires will "follow" the rut while the rear tires will "hook" the rut pulling the rear of the car sideways. Lots of fun at triple-digit speeds.
  6. Truckedup
    Truckedup
    .....On the axle width, I've swapped later model axles in AD Chevy PU trucks and wound up with the rear axle being 2 inches wider than the front with no difference in handling... And the car I'm building has a V8-60....Maybe see 80 going down hill :D
    Anyways, I did a mockup with the stock front axle and the Ackerman meets at 114 inch behind the front axle.....47 Ford Wheelbase, imagine that. ;) Narrow the axle 4 inches and the lines meet at about 108 inches...The build will have 112 wheelbase so the Ackerman will likely be ok without bending the steering arms...
  7. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    I wouldnt worry about it. Not only does front axle width change ackerma (rear width has nothing to do with it), but wheelbase does. Think about how many model As and model Ts are running a much shorter wheelbase running STOCK 37-48 axles. If it really bothers you, measure and heat/bend the steering arms out that tiny bit.
  8. Bluedot
    Bluedot
    Wow, talk about missing the obvious!! I'd never thought about that before, makes perfect sense.
  9. sunbeam
    sunbeam
    Can't be as bad as a 65 or 66 Chevy. Ever listen to one turn on a gravel parking lot.
  10. Maybe. Not positive about front narrower than rear, but the opposite certainly has no ill effect, or millions of Citroëns would be lining the ditches of the world.
    Cosmo
  11. hotroddon
    hotroddon
    Probably not a problem on a street car, but I can tell you for a fact that it will put you on your lid in an off road racer on a heavily rutted course.
  12. rooman
    rooman
    Ackerman geometry is used to make the front wheels describe the correct arc when the vehicle is turning so that the tires don't scrub. If you are turning that much in a belly tank you are not going fast enough or are in the process of crashing. :)
    Roo
  13. 28 victory
    28 victory
    By the way, there are lots of factory pickups trucks on the highway with different tracks front to back.
  14. Usually they are wider up front no?
  15. Pete Eastwood
    Pete Eastwood
    from california
    I'd think twice about building a race car with the rear track wider that the front track.
  16. 28 victory
    28 victory
    Yes the front track is normally wider on pickups. Heavy truck manufacturers have always had ackerman issues with different wheelbases. They have five or six ackerman arms for a given model with multiple wheelbases that get extreme. Draw a line on the pavement extending out from the centerline of the rear axle on each side. Turn the front wheels against the locks right and or left. Draw a right angle (90degrees) line from the center of each front wheel back and crossing the rear axle line. You should get a single focal point of lines on each side. If the front lines do not converge to a focal point, you will scrub the treads off. A change of ackerman arms or modified arm will be required. Good luck
  17. 28 victory
    28 victory
    To bad the ackerman arms on light vehicles are not removeable independent of the spindles like heavy trucks.
  18. this made me laugh out loud
    thanks
    tk
  19. Ackerman may well be an important
    factor with HD trucks with a greater GVW. But I found that with a smaller medium duty , (F600) the steering arms are the same for 134, 154,172,194, and 200 plus WB . I checked on this because my own truck had been stretched from 154 to 172.
    It can be an important factor at speeds above normal road speeds.
  20. 26 T Ford RPU
    26 T Ford RPU
    One factor that never gets a mention is the length of the arm. With different length wheelbases the arms are of a different length to maintain the correct ratio. I learnt about Ackerman a long time ago and have seen many diagrams that differ from the centre of the rear axle to 3/4 from the front axle so I believe there is a little bit of flexibility. I dont believe different track widths will have an affect on this as its on the centre lines. JW
  21. DICK SPADARO
    DICK SPADARO
    The ackerman angle has a degree of importance. As the steering rotates the inside wheel turns at a sharper angle than the outside wheel to compensate for the difference in turning circle radius. This prevents the wheel/tire form scuffing as it turns and improves the tirewear and handling. Simple backyard mechanics design is that a line drawn from the spindle king pin centers thru the steering arm pivot centers should converge approximately at the center of the rear axle. This gives the steering arms the necessary differential in turning degrees to match the radius of the turn and eliminate tire scuff. It is a wheel base function not a track function.
  22. lothiandon1940
    lothiandon1940
    Right on the money, Mr. Spadaro.
  23. hotroddon
    hotroddon
    ****, If you narrow the track, without changing the steering arm angle, on the same wheelbase, you will move point of convergence forward, right?
  24. 26 T Ford RPU
    26 T Ford RPU
    The rear centre line of the axle is the same and what about the Morgan 3 wheelers. If you narrow the front track then they should be adjusted . JW
  25. Of course it does
  26. DICK SPADARO
    DICK SPADARO
    Hot rod Don yes that is correct.
  27. Truckedup
    Truckedup
    Back to the story about 10's of millions of PU trucks on the road with wheelbase difference of up 20 inches or more and supposedly using all the same spindles and steering arms for all wheelbases... Is it true? Hollander book? If so that's something to think about......Kinda ****s up the Ackerman theory...
    The car I'm building is not a race car and won't be driven on rutted roads at speed.
    And living in snow country and liking off road driving and Jeeps, weraving all over the road is nothing new :D
  28. hoop98
    hoop98
    from Texas
    I know Chevys in the 30's both Trucks and P***enger cars were set 23 degrees on the inside when the outside wheel was at 20 degrees.
    47 HD Trucks were 20 outside 23+-2 inside.
    57 Chevy was 18 deg 10 min inside, 20 outside.
    Calculating Ackerman Percentage is as follows.
    % Ackerman = (Angle Inside Wheel - Angle Outside Wheel)/Angle Inside Wheel for 100% Ackerman
    Where the inside wheel angle for 100% Ackerman is:
    Tan-1(WB/(WB/TAN(Angle outside wheel) - Front Track)) - Angle of outside wheel
    So it's a little easier to go with Toe-out on turn IMO.
    A Static measurement does not allow for slip angle. Under load in a corner the outside wheel will have more slip angle than the inside. A bias ply tire will develop a lit more slip angle than a radial at the same cornering load.
    So lets say we are in a hard low speed turn, and the outside front tire is overcoming 400 pounds of cornering force and the inner is overcoming 200.
    We have the RF Wheel at a 15 degree angle and the inside is at 17.
    Because of slip angle the tire is steering at 7 degrees, the inside is at 14 degrees.
    With radials the outside is steering at 12, and the inside is at 15.5
    So while it is easy to see the ackermann effect when the triangles are drawn, real life is much more complex. So instead of going crazy, a street rod should be fine with 2-3 degrees of toe out angle spread at 20 degrees steering angle.
    20 inside and 18 outside seems like a sweet spot.
  29. Haven't you ever noticed how some trucks eat tires and others don't?
    I had a GMC ex cab short bed that ran down the road like a leather sofa on wheels and I got Super wear on the tires. My buddies Crew cab long bed ate thru three sets to my one.
    My SWB k5 blazer ate tires faster than any suburban ever could.
    I see two vans pretty regularly. One is a extended Wheel base and the other isn't. The extended one eats tires.
    So yeah, there's bazillions of different platforms and there is a difference in tire wear. The thing is, the fox is guarding the chicken coupe and they proclaim the expected wear and life expectancy of the tires- therefore it's reasonable because they said so.
