Hot Rods Acoustimac Soundproofing
Discussion in 'The Hokey Ass Message Board' started by 73RR, Apr 2, 2024.
  1. 73RR
    73RR
  2. Mr48chev
    It looks like it is intended for soundproofing a room. Either somone, music practice room or the hearing test room in a hearing speciaty office = the room they stick you in to listen for the beeps in the headphones to test your hearing after you were around open headers for years.
    Amazon show a 4x25 roll of the 1/16 inch 1/2 lb per sf for 110 https://www.amazon.com/Acoustimac-M***-Loaded-Vinyl-5lb/dp/B0C1ZZ31HY
    Doing some homework shows that the m*** loaded vinyl is popular for car installations though. I'm still studying on what I want in my 48 but I want to cut noise and heat down as we have several trips planned that are 2K one way and up.
  3. 73RR
    73RR
    ...not like hot-rodders haven't found 'other' uses for commercial products before. To my eye it looks like it could be useful, hence the question.
  4. '29 Gizmo
    '29 Gizmo
    from UK
    Looks like it is a barrier layer that goes between hard/strucural surfaces, not an outer surface to mount upholstery or dampen a single panel layer. May be worth a try though
  5. hrm2k
    hrm2k
    It looks a lot like a product called Armaflex. Same stuff used to insulate air conditioning pipes. My wife die cuts that stuff for several different industries. I used this product on my V8 Corvair floors and engine compartments. Used a very hi tac spray glue ( 3M ) . In my application, it works like a dream .
    WHAT IS ARMAFLEX .
    Armaflex® pipe insulation is manufactured from a CFC free, closed cell, nitrile rubber foam. Designed to provide insulation for pipework, ducting and vessels, the low thermal conductive properties of the product help to reduce energy consumption and the risk of pipework corrosion.
    73RR likes this.
  6. Roothawg
    Roothawg
    Dan Hay likes this.
  7. 73RR
    73RR
    Root, I just finished reading through 11 pages of your 55 project...damn, what didn't you touch?
    How is the interior noise today?
  8. Roothawg
    Roothawg
    The car is sort of on the back burner. We have a ton of stuff that has happened. We are in the middle of a house build and a shop build. I figure we can get back on it in a year or so.
    Long way to say....I dunno yet.
    Just Gary likes this.
  9. 73RR
    73RR
    ...house and shop and how many car projects...? You are an ambitious soul.;)
  10. Roothawg
    Roothawg
    King of the half finished projects.
    Crazy Steve likes this.
