Projects Acrylic enamel paint reducer substitute
Discussion in 'Traditional Hot Rods' started by HuskerNation, May 1, 2021.
  1. Trekhans
    Trekhans
    In the absence of acrylic enamel reducer specifically designed for automotive paint, you can use lacquer thinner as a subs***ute. Lacquer thinner is commonly available and can effectively thin acrylic enamel paint for application on your car's gas tank. However, it's important to note that lacquer thinner may have different drying times and characteristics compared to the intended reducer. Therefore, it's advisable to test the mixture on a small incon****uous area before applying it to the entire gas tank to ensure desired results.
    https://paintsgeek.com/urethane-reducer-subs***ute-the-best-option/
  2. HuskerNation
    HuskerNation
    Hahaha, thanks for help but unfortunately it was back in 2021 when I posted this thread. Tank was sprayed in a single stage enamel & came out beautifully!
    tb33anda3rd and caseywheels like this.
  3. deathrowdave
    deathrowdave
    from NKy
    Acetone I have used to thin enamel for farm equipment . Seems to work perfect to me , but I’m not a painter
