Acthung! Let's See Your VWs
Discussion in 'Off Topic Hot Rods & Customs' started by Dan Hay, May 9, 2024.
  1. Dan Hay
    Dan Hay
    I truly believe VWs are a gateway drug to Hot Rods and Customs, this was true for me. I have had the same conversation with several hot rod guys that have the same story. They are simple, easy to work on and learn basic mechanics, and really fun to drive, and relatively cheap. (Not so much anymore but nothing is cheap now)..
    My first submission is my 66 beetle I had from 05-07. I bought it sight unseen online and flew to Vegas then got a shuttle to St. George Utah to drive this thing back to Oklahoma. I was young and dumb. What could possibly go wrong?
    When I saw it the first time, the front tires had the cords showing. Oops, down to the tire shop. Did they carry lowered VW front tires? Nope. Got the smallest tire I could, then adjusted the front beam up until the tires cleared, but I was on the road. I found I ought my uncle was in Arizona with an empty trailer heading back east so after a few miles I called him and headed to AZ instead of all the way back to OK. I got to Wickenberg, AZ and let the clutch out after a pee stop and promptly tore the splines out of a rear brake drum. Stuck. He came and got me with the trailer and I'm glad I didn't try to drive that all the way back. It was lowered with a later 1600 dual port and single carb. No idea how stock it was internally but it ran good. I think I gave $3500 and got $5k out of it, I thought I was a master car flipper with that kind of profit. 91999049_10108733265093637_4639285628595339264_n_10108733265088647.jpg 1505393_10102870155018227_1580111829555327283_n_10102870155018227.jpg IMG_3795.jpg IMG_3796.jpg
    catdad49, Sharpone, Sart156 and 21 others like this.
  2. Dan Hay
    Dan Hay
    My next and last VW showed up in 2019. A friend from church was moving and needed to get rid of his stalled (not started) 20 year project. He had a 65 Beetle he bought from the original owner. He bought a bunch of hot rod engine parts and a beefed up transaxle and then never did a thing.
    When I saw the new magnesium case, Forged Mahle Pistions, **** stroker crank and rods, big cam etc.. I knew I couldn't afford it. He priced it all to me for $2k and I figured out how to make it work. I told him his parts were worth more than that and he should sell it for more, but he really wanted me to have it because he knew I would finish it. And I did.
    This was the first complete engine build I ever did. I started with an absolutely bare case. I had to do a lot of research to figure out what I had and then what I needed to make it run good.
    It ended up being a 2028cc with dual weber 44s. Ran hard, but very streetable. Full flow oil with a spin on filter and external cooler. I really learned a lot building that engine. It had a 4" narrowed adjustable beam in the front, with BRM wheels, and I stepped up for Firestone Wide Ovals on the rear. I wanted it to have a 60's drag bug look and stance.
    I took it to Iowa for Goodguys (got some press in the online gazette) last summer and somebody there wanted it more than I did so I sold it there. I would've liked to enjoy it longer but, strike while the iron's hot. 66405912_10107729816397867_5626125360660742144_o_10107729816387887.jpg IMG_3651.jpg IMG_3626.jpg IMG_3627.jpg IMG_4547.jpg IMG_5463.jpg IMG_5464.jpg BUG jpg.jpg
  3. Jkmar73
    Jkmar73
    from Tulare, CA
    Ok, I’ll add mine to this. First up is 1967 Standard bus. I bought it used from a small used car dealer here in town. I drove it around for a while. It was just a clean little daily driver. It had primer spots on it. Some dents needed to be fixed. Nothing major.
    I took it to a paint shop and had it painted, then one thing led to another. If this was painted, this needed to be chrome. Upholstery was done. So on and so on. And it ended up like this.
    The motor was basically stock except for bigger pistons. The transmission had a taller ring and pinion installed to handle freeway driving. I ended up selling it back in the 2000’s. Last I heard it was in Kansas somewhere.
  4. Jkmar73
    Jkmar73
    from Tulare, CA
    The other one, I still have is a 1969 Ghia. This one I built the motor with my dad. It’s a 1776 with big valve heads and 48 IDA webers on it. Running through a Berg 5 speed.
    While I was building the motor, I gave the car to a buddy of mine to fix some of the dents and told him to just spray it primer black. He did, and we were talking and jokingly said we should shoot some flames on it like and old 50’s hot rod. I came back a couple of days later and he had the flames laid out. Used left over paint he had in his shop. I will finish this car one of these days.
    catdad49, Sharpone, nunattax and 9 others like this.
  5. JimSibley
    JimSibley
    IMG_1509.jpeg I have had a few. My first car was a baja bug. I painted it with flames, found some slot mags and installed a 1776 in it. I was hooked. This started my love of building cars. My wildest was a 1969 bug that I tried to make a real hotrod out of. Black with flames, chopped, motor transplant and slot mags. My latest is a dune buggy and I love it. IMG_0066.jpeg IMG_0063.jpeg IMG_0947.jpeg
  6. Dan Hay
    Dan Hay
    OH YEAH! That bus, flamed ghia and Jim's stuff.... super cool!
  7. 65type1
    65type1
    I've had a couple of VW's...they hate me. Never got to drive or finish the buggy, random guy really wanted it .
    231.JPG DSCF4389.JPG IMG_2801.JPG IMG_2808.JPG 20190622_090740.jpg B5A2EA28-E4B1-4DEB-B4D9-C615D29E8CCC.jpeg
  8. Dan Hay
    Dan Hay
    catdad49, Sharpone and porkshop like this.
  9. tim troutman
    tim troutman
    used to drive this one only photo of it. none with moon disk on it. man it was low 20240509_192525[1].jpg
  10. BamaMav
    BamaMav
    from Berry, AL
    I lost all my pics in a hard drive crash a few years ago. Had a 67, a 71 standard, 72 Super, and a 74 Super that I can remember, there were several others. Never got a Karrman Ghia even though I really wanted one, nor did I ever get a bus. I enjoyed them, got burned out and hated them so much I sold my entire collection of parts and cars. Kinda getting the bug, no pun intended, for another Bug.
    catdad49, Sharpone and Dan Hay like this.
  11. MCjim
    MCjim
    from soCal
    I flat towed this beauty home, and had grand plans... then I sobered up.
  12. guthriesmith
    guthriesmith
    I’ll have to scan some pics of my 62 beetle with the slide back roof… I’ll report back.
  13. hotrodA
    hotrodA
    Ex 67 Bug owner here. Best car I ever owned.
    I remember seeing them at Port of Entry Jacksonville, 100’s of them on one huge lot, all different colors. Looked like a giant field of flowers. They sold new at the local dealers for $1499 bare bones.
    My aunt worked for VW Southeast and got a new one every year. The 67:was hers, but dumb me p***ed on her Ghia convertible a couple of years later.
  14. badshifter
    badshifter
    It’s Acthung, but we get the point!
    Mine
    catdad49, Sharpone, spot and 10 others like this.
  15. nitrobrother
    nitrobrother
    I had this one deleted by the mods on the Altered thread for having a VW body, even though it was a famous car and is no different than a Fiat-bodied racer! Never did understand that one...
    Gene Mori's killer altered as featured in the Oct, '63 issue of Pop Rod.
    catdad49, Sharpone, deadbeat and 7 others like this.
  16. SS327
    SS327
    catdad49, Sharpone, deadbeat and 3 others like this.
  17. Gastrap
    Gastrap
    Found a few old worn pictures from the 80's. This Fastback started out as a Squareback. I had chopped the Squareback 4 inches and filled the back windows like a panel. I was driving it without gl*** one day and got a ticket for everything imaginable, from "too low" to "unsafe condition" and everything in between. Swapped out to this body because I was out of funds to complete the chop.
    This Baja was a great stock '65 when I got it, stupid 17 year old me chopped it up.
    Short bus behind my 1967 Ford "RV" just returning from a cross country trip. I only removed one rear door in length, so no wheelies from that little bus.
    More junk, this Square was my first car. This had the horrible Bosch point-fired fuel injection, so I welded an adaptor on the air manifold and put a little Holly carb on it to simplify things. I put 135's on the front and dropped it a little more after this pic.
    catdad49, Sharpone, porkshop and 2 others like this.
  18. Bandit Billy
    Bandit Billy
    I am going out on a limb here and calling this rare since I have never seen one before. Karman Ghia
    catdad49, Sharpone, nunattax and 8 others like this.
  19. Jkmar73
    Jkmar73
    from Tulare, CA
    This, I believe is a Brazilian Ghia. Made in the South American factory. I think they are called Type 34. Not 100% sure.
    Sharpone, porkshop and Bandit Billy like this.
  20. Bill Schwimmer
    Bill Schwimmer
    Been into VW's for a long time. My tan '55 was a drag/street race car. Ran 12:20's at Palmdale, corrects down to 11:80's at sea level. This was in '87.
    My current car is the coral '59 ragtop. I have owned this since '89. It has gone 12:40's pump gas , muffler, full weight. Both cars have original magnesium BRM wheels. Lots of fun, you have to love VW's , there are way easier ways to go fast.
    8AD9B4F5-CBF8-4EB2-9A08-AB948F8485AD.jpeg 4C23EC0F-002A-41ED-9597-E2F90CA72959.jpeg
    James D, catdad49, Sharpone and 12 others like this.
  21. Dan Hay
    Dan Hay
    My green bug in the post above went low 14s. It felt a lot faster than that! I can’t imagine a bug in the 11s. Crazy!
    catdad49, Sharpone and Bill Schwimmer like this.
  22. Bandit Billy
    Bandit Billy
    Not sure you noticed all of the VWs in the background of that karmas I posted. They were out in force yesterday in Portland.
  23. loveoftiki
    loveoftiki
    from Livonia,Mi
    Hey Bill up there…. My old 68 Cal Looker…built to look like something you’d have seen at OCIR in 78/79…2275 48 IDA’s…super fun car
  24. El Hueso
    El Hueso
    My '58 Beetle, very mild custom. It's my second car, that I've owned since 2003 and restored it in 2006. Shaved hood trim, hood badge, and turn signals. Pop out rear windows, shaved and modified dash, Euro bumpers, original roof rack, and lowered of course. The paint is from a 1951 Packard, called Corona Cream. I drive it most days when its not pouring.
    41895209_1700678750043253_3203165937679204352_n.jpg 41836314_1699812496796545_2162220282087997440_n.jpg Shaved speaker grill and highly modified lower dash, equipped with Stewart Warner gauges of course!
    thumbnail_IMG_4415.jpg 40562537_1680739525370509_5210316343940743168_n.jpg Surfing and camping on the Oregon coast with our family of four. The best. (FYI the surfboard is only on there when I'm... surfing)
    118786146_3046028282174953_112193706034839711_n.jpg 118702211_3046028405508274_58495150757459831_n.jpg 118701099_3047383265372788_7591296608030488540_n.jpg
  25. E93a
    E93a
    Clean, simple and elegant.
  26. Toms Dogs
    Toms Dogs
    from NJ
  27. Not mine.
    Looks fun
    catdad49, Sharpone, Ned Ludd and 5 others like this.
  28. loveoftiki
    loveoftiki
    from Livonia,Mi
    My old VW flat towed to the Dragstrip..
  29. El Hueso
    El Hueso
    A few of Pat's Beetles
