Hot Rods Adapting 35 Ford Wires
Discussion in 'The Hokey Ass Message Board' started by flip, Apr 2, 2016.
  1. flip
    flip
    What is involved in adapting 1935 Ford wire wheels to a standard 5x4.5 Ford bolt pattern? How much wider does it make the track width. Thanks
  2. TagMan
    TagMan
    I have no idea what the bolt circle diameter is on a '35 wire wheel, so I can't address that part of your question.
    As to the 2nd part, how would changing the bolt pattern affect track width ? Track width is a function of width of the axle you're using.
  3. GordonC
    GordonC
    Flip,
    I just adapted 35 wires to my 31 roadster. I bought the adapters from Speedway. They were 5 on 5 1/2" to 5 on 5 1/2" and measured about 1 1/4" in thickness so that is how much the wheel moved out from the drum surface. I am running a dropped A axle in front with F100 drums and a Bronco 9 inch rear end. Some folks have mentioned they think they don't look good that way. Personally I think they don't look any worse than any other wheel combo. I would bet you can get a set that adapts from the 4 1/2" you have to the 5 1/2" you need for the wire wheel.
    Gordon
  4. GordonC
    GordonC
    Oh, almost forgot to mention that the adapters also have a ring machined on them that provides support on the inner mounting surface of the inside of the wire wheel. This is needed to properly support the wheel on a drum that does not have that ring built into it. If you have the correct bolt pattern of 5 1/2" already then you just need the support rings.
    gas pumper likes this.
