Technical Adapting Power Steering to a Merc Flat Head Ford Engine
Discussion in 'Traditional Hot Rods' started by Ehlien, Sep 17, 2015.
  1. Ehlien
    Ehlien
    Has anyone adapted/mated a GM (or other) power steering pump to a 49 Merc Ford Flat? I'm dropping the engine into an S-10 ch***is that has a power steering gear box.
    Thanks
  2. Jalopy Joker
    Jalopy Joker
    No - refer to your other thread on subject
  3. tb33anda3rd
    tb33anda3rd
    yes i did it years ago, but i do not have any photos. i made brackets to mount it on the driver side head and used a second pulley on the crank. the tricky part was i cut two pulleys, the one that mounted to the gm pump and a chevy 6 cylinder 5/8 crank pulley. i machined the out side of the pump pulley off and cut the inside of the wide pulley out then welded them together. this allowed the use of the wide belt.
  4. Ehlien
    Ehlien
    Thanks ..sounds like your more of a mechanic than me.. seems like I'm being persuaded to go the easy way and just swap out for a manual box.
  5. Bruce Lancaster
    Bruce Lancaster
    The '49 has wide pulleys, an obstacle to building wit a late model pump. If you are not using early Ford type mounting, swap your pumps and all pulleys for one of the '50
    -53 Ford setups and you'll have modern belt widths. From there on it's just bracketry.
  6. Ehlien
    Ehlien
    Good points.
