Adding an electric fuel pump questions
Discussion in 'The Hokey Ass Message Board' started by rubyreddog, Oct 5, 2010.
  1. rubyreddog
    rubyreddog
    I want to add an electric fuel pump as a back up to my manual pump (mild 350 chevy). I bought a Holley red pump but when I try to blow through it it offers a great amount of resistance. So I figure that fuel will not be able to be pumped through it by the manual unit.
    Do I need to run a byp*** line or is there another pump I can install "in-line" ?????
  2. squirrel
    Sounds like you have it backwards? Generally, you need to install a mechanical pump as a back up for the electric pump
    But yeah, you won't be able to pull fuel thru a vane type pump like the Holley.
  3. the last 5-6 cars i have built i used a Carter electric pump back by the tank in addition to the mechanical. i switch it so it will only run when needed , never had any problems with the mechanical drawing fuel through them
  4. Tee around the electric pump with a check valve if you think it will be a problem. The check valve will allow the mech pump to draw fuel around the electric, but won't let fuel push back to the tank when the electric is on.
  5. rubyreddog
    rubyreddog
    I have had cars where the manual pump will draw through a diaphram type pump but all the pumps seem to be rotary vane types now. Is this the type you use??
  6. Thommyknocker
    Thommyknocker
    from Colorado
    IMHO I wouldn't run both at the same time.
    Just have it mounted up, and some barbed fitting ready to go for when you NEED it.
    Also, don;t push through a mechanical, if the diaphram blows, then the electric will fill the crank case up
  7. Bumpstick
    Bumpstick
    I've been running a solid state 2-3 pound unit for years. Put it on the frame rail just in front of the drivers side rear wheel, block off the mech. pump. Also wire in a relay.
    I've run em' all and the cheap solid state ones have always worked the best. Go figure. Never let it run to empty. Fastest way to burn it out. I have a merc with a small block so I know from what I speak. -stick
  8. HEMI29
    HEMI29
    I have an electric pump mounted on the frame rail just in front of the left rear wheel. it has been there for 15 years. i have it on a toggle switch. i have never had a problem
  9. rubyreddog
    rubyreddog
    Personally, I have had bad luck when relying on an electric fuel pump as my only source of fule delivery on street cars. Now, most all cars have electric pumps due to fuel injection requirements. Given a choice, I will always choose a mechanical pump because they have proven to be much more reliable, IMHO.
    I want to add an electric unit as a back up only. Several times, in the past, having a back up has got me home due to vapor lock and dirty fuel filter problems.
  10. George G
    George G
    What's up with the noise from an electric pump? Is there any out there that are quiet?
  11. pitman
    pitman
    I run a late Ford ~40psi injector type pump, w/a Duratec motor and the best item, which might apply to any elec pump, is the motion shutoff. The Ford Focus has it behind the front p***enger kick panel. Let it power the pump's relay, then if you stop "suddenly" it will shut down.
  12. Napa part # P74019 , made by carter. it's called a solenoid type and uses a piston actuated by a magnetic coil. i only use for starting if the car has been sitting for a while , not full time. the mechanical pump has no problems ****ing through it
  13. rubyreddog
    rubyreddog
    Thanks 36-3window, I'm going to check that pump out. Sounds like it may be what I need.
    Clay
  14. geoking
    geoking
    I have a TPI pump in the tank from Rock Valley and believe that the PSI will be too high for my Holley 670 Avenger. I do not wish to run the extra line for a by p***. Will adding a regulator to maintain a lower flow rate damage the pump? OR would you add a frame mount fuel pump?
    What PSI is good?
    Sorry to ask so many questions, but I do not know the answers. smile.
    regards,
    George in Parker,Co.
    1948 Ford Coupe with 354 Hemi
  15. I have been Running a Carter Electric fuel Pump for 25 years
    in my 50 Merc with a SBC and No Problems
    Just my 3.5 cents
  16. mart3406
    mart3406
    from Canada
    Diaphragm-style electric pumps are quiet.
    Also, they only come on as needed, rather
    than running continuously like the Holley
    and most other actual 'electric-motor' driven
    pumps. At the most a diaphragm pump will
    only make a slight 'clicking' noise when it
    comes on. If you use it as a backup pump,
    mounted near the tank to feed a mechanical
    pump on the engine, you'll probably never
    or only very occasionally ever hear it.
    Mart3406
  17. 29AV8
    29AV8
    I just run a mechanical pump. never really like the electric.
  18. mart3406
    mart3406
    from Canada
    For most applications the stock mechanical
    pump on the engine will probably suffice.
    There are some situations though when
    adding an electric pump back at the tank
    and using it to feed the mechanical pump
    on the engine can be helpful though. Years
    ago when racing my still street-driven
    283/4-spd '64 Chevelle at the track, the
    power would flatten out and fall off above
    at above 5000 rpm in 3rd gear. It didn't
    actually 'miss or ''**** out' or anything, but
    the power just kind of 'went away'. The engine
    had a solid-lifter cam and good valve springs
    (it'd easily and regularly pull past 6500 rpm
    in 1st and 2nd gear) so the problem wasn't
    valve float. Finally, I figured out the car was
    starving for fuel under load at WOT. I solved
    the problem by adding adding a electric
    pump at the rear of the car near the tank to
    push fuel up to the mechanical pump and the
    problem was instantly solved. After that, the
    car easily pulled through 6000 rpm and beyond
    in 3rd gear and went through the lights in 4th at
    about 5500, just starting to come on and really
    pulling hard. The pump I used was a small
    'universal-type' diaphragm-type pump that I
    had lying around - that by itself, probably would
    have been inadequate, -but when combined with
    the also slightly inadequate stock mechanical
    pump, I had all the fuel I needed.
    The other situation where an electric pump at
    the tank pushing fuel to a mechanical pump on
    the engine can be helpful is if you have a chronic
    vapor-lock problem. Pumps push fuel better than
    they pull it and when the fuel is under pressure,
    as it is on the outlet side of the pump, the boiling
    point of the fuel is raised substantially. Conversely
    though, the boiling point of the fuel is also lowered
    by the same amount on the suction side of the
    pump and the harder the pump has to work trying
    to draw fuel through a long and/or restrictive line
    from the tank, the more the boiling point is
    lowered and the more prone the engine is to
    vapor lock. By putting an electric pump at the
    tank - even a small, low-pressure one - to push
    the fuel up to the mechanical pump, the fuel in
    the line on the suction side of the pump, because
    it is now being pushed there under pressure,
    rather than being pulled under a vacuum, has a
    higher boiling point and a greater resistance to
    flashing into a vapor.
    Mart3406
    Mike Miller likes this.
  19. 19Fordy
    19Fordy
    I never had any luck with the type of pump shown. The rubber bellows always developed a small crack in about 6 months causing the pump to malfunction.
  20. ago
    ago
    from pgh. pa.
    The diaphragm pump failure might be cuz of the new fuel additives.
    Ago
  21. mart3406
    mart3406
    from Canada
    That could be caused by modern, supposedly
    "improved" fuel formulations being used
    nowadays. When I installed one on my '64
    Chevelle, that was back in the late-70's-early
    '80's. I never had a problem with it, but that
    was then and this is now and fuel is definitely
    different. It may be a good idea to avoid an
    older diaphragm-style pump, even if it still
    works good. There are some newer ones
    available now though, designed to withstand
    the 'strange brew' chemical ****tails that
    p*** for gasoline these days. One good,
    low-pressure, medium-volume pump that
    comes to mind is the Facet model 40108. I've
    used these before without any problems. It
    will handle modern-day gasoline and is quiet,
    long-lived and reliable enough that it's
    commonly used in a lot of marine and even
    homebuilt aircraft applications.
    Mart3406
