Technical Adding CDI to Points Ignition
Discussion in 'The Hokey Ass Message Board' started by blowby, Jan 16, 2022.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
  2. blowby
    blowby
    from Nicasio Ca
    Oops, missed that, thanks.
  3. Harv
    Harv
    from Sydney
    I'm running MSD CDI in my avatar, with an OT distributor. The voltage they produce is incredible. Over the years I've had a few ignition systems make me do the Scintilla Shuffle... never much fun, but you get over it with a few choice latin phrases.
    Getting a belt from the CDI is something else. I broke down mid-trip at one stage, and had the Youngest Child crank the engine over while I held a plug lead near the block. The CDI felt I was a better earth, and gave me one hell of a boot. I unintentionally threw the allan key I had in the other hand, and damn near ended up on my ***. Took the Youngest Child a good few minutes to stop laughing.
    Had a problem early-on where it would arc out and blow holes in the dizzy rotor. Turned out that one of my home-made plug leads was high resistance. Car ran fine, no miss, but at some stage the CDI felt it was easier to earth through the plastic of the rotor than through the high-resistance #1 lead. Remade the lead, and solved the problem.
    Cheers,
    Harv
    G-son likes this.
  4. sunbeam
    sunbeam
    Chrysler modules are like GM 4 pins you get what you pay for.
  5. blazedogs
    blazedogs
    How about just going with a pertronix pointless Set up ?
  6. squirrel
    Connecting the wires to them is a bit different, though.
    alanp561 likes this.
  7. Mimilan
    Mimilan
    @blowby
    You can also use a GM HEI 4 pin module.
    The problem is the HEI is triggered when the points close, whereas Points ignition [and TFI] are triggered with the points opening
    This causes rotor phasing issues, but this can be easily remedied with a simple transistor in the wiring
    [circled in red]
    Figure 2 shows how to connect a 6 pole DPDT switch and still keep the condenser.
    If you ever have a module failure, you can switch it back over to points / condenser ignition
    Budget36 and Blues4U like this.
  8. blowby
    blowby
    from Nicasio Ca
    Is the extended coil saturation time of a dual point still relevant with a CDI?
  9. squirrel
    No.
    Also, this is the HAMB, so if you use a CDI, be sure to find an old one, and be prepared for it to not work....
    Moriarity likes this.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    File and adjust your points, apply some lube to the cam. Test the resistance (ohms) on the primary side of the coil and also test the ballast resister. They should be 1.5 ohms each. buy some NOS points and condensers on ebay . Then enjoy the car.... no modern electronics required
  11. blowby
    blowby
    from Nicasio Ca
    Good idea, I should at least carry spares. I'll look at Turlock in a couple weeks, might be some there. You don't go to Turlock do you? ;)
    I try not to mention it much, but having a wheelchair bound p***enger adds a whole new dimension to breaking down on the road.
    rod1, Blues4U and Moriarity like this.
  12. squirrel
    then stay away from that electronic ****!
    Barrelnose pickup and Moriarity like this.
  13. blowby
    blowby
    from Nicasio Ca
    Well that's what interests me in a CDI. If it ****s out you just put the point wire back on the coil. Or even have it on a switch.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    An ounce of prevention is worth a pound of cure, file em. set em. lube em. and there will be nothing to worry about... haha no sir I don't go to Turlock.... too far to drive...
  15. Mimilan
    Mimilan
    The major advantage of CDI is that the capacitor can be fully charged in a very short time [approx 1 millisecond]. So the CDI is suited to a high RPM application where insufficient dwell time is available.
    The short spark duration is not good for igniting relatively lean mixtures in high vacuum cruising situations. To solve this issue many CDI ignitions release multiple sparks at low engine speeds.
    GM went the opposite with the HEI which stretches the dwell time as RPM increases.
    This can easily be achieved with a DPDT switch [I posted a schematic earlier], But you can easily wire it to switch over to another HEI or TPI module as well.
    Points ignition is relatively simple and reliable. Points are simply a mechanical switch [every switch in your vehicle has contact points]
    All a CDI conversion does is replace the condenser [also called a capacitor] with an amplified capacitor.
    CDI's need a healthy charging system.
    alanp561 and Blues4U like this.
  16. blowby
    blowby
    from Nicasio Ca
    Yep, MSDs only multi spark to 3,000 rpm. And use .9 amp per 1,000 rpm.
    Blues4U likes this.
  17. Mimilan
    Mimilan
    Don't let that .9 amp per 1,000 rpm. fool you!
    Everytime you double the volts ,you halve the amps so the energy remains the same [except for heat losses]
    This was the marketing ******** years ago when the hot ticket was a 90,000 volt coil [or whatever]
    I've seen this as the cure-all on HEI ignitions which were limited to 5500 rpm. And higher voltage coils made them worse!
    Sparks require energy....as in Joules [not just volts]
    A coil is just a transformer, so the best way to get more out of it is to put more in [that's the story of life as well:D]
    Most CDI's, TFI's, and HEI's work on that principle . So the perform better with a good charging system.[because they need an external source of power to perform the wizardry]
    I prefer the HEI because it provides a big fat wet spark at low RPM , and as the revs climb it stretches the dwell [because there is less time/milliseconds at higher RPM]
    TrailerTrashToo and Budget36 like this.
  18. Mimilan
    Mimilan
    Budget36, rod1 and Truck64 like this.
  19. squirrel
    The recent consensus on the British car forums is to just keep the old condenser in there....
  20. Truck64
    Truck64
    from Ioway
    "Back in the day" good mechanics didn't necessarily swap out the ignition condenser routinely as part of a Tune-Up, this can be difficult to explain to the customer, who might not understand why, and after all he is paying for new parts.
    But if the points are wearing evenly there is no benefit to replacing it as such. These days it is practically a foolish thing to do, and the parts stores are practically complicit.
  21. Mimilan
    Mimilan
    That's if you can get a decent one [not made from "Chinesium"]
    When we rebuilt the engine in our 57 Chevy, we had 3 condensors fail in a row [straight out of the box]
    So we scavenged the old Delco condenser out of the trash and reinstalled it [it's been there ever since]
    Truck64 likes this.
  22. Truckedup
    Truckedup
    if some of you can use 4 speed auto OD transmissions and 5 speed transmissions, something like a reliable solid state capacitor should be just as acceptable…
    GM HEI can draw 20 amps under certain conditions…The original applications had #10 feed wire
    Norris McCarty and G-son like this.
  23. blowby
    blowby
    from Nicasio Ca
    Hey don't confuse me with difficult math formulas. :) So at the 3k rpm you say an MSD is drawing more than 2.7A?
    My '56 came to me with the internal condensers replaced by this elegantly mounted external one. Been on there since it was parked in 1974, and by looks of it a lot longer. I'm afraid to touch it.
    Jet96 and alanp561 like this.
  24. squirrel
    That looks like a Mallory "trash can" condenser.
    Show us the other end of the wire, and inside the distributor....please?
  25. blowby
    blowby
    from Nicasio Ca
    There's pic in post 28 on page 1. The big black wire goes to it, the green to the coil.
  26. squirrel
    thanks, I missed that.
    If the wire connection at the condenser looks ok (hard to tell from the picture?) then just leave it alone. Or get an NOS Delco condenser or two from ebay, and either take it with you, or install one now and take the other along. And leave the trash can there, and keep the wire, just in case you need to get it going again. But that's unlikely.
  27. Harv
    Harv
    from Sydney
    Getting this condensor tester running is on my (long) to-do list. Suspect the "specially calibrated leads" are long gone. It tests at 500V DC, which makes me suspect that at some stage I will end up looking like Beaker from the Muppets when I pull it apart. Need to think through how I turn my 12V battery charger into a 6V power source too.
    Cheers,
    Harv
    alanp561 and blowby like this.
  28. squirrel
    One problem with using a capacitor tester on ignition condensers, at least modern condensers, is that the failure mode is usually something that the test won't detect. It's usually intermittent, and caused by varying internal resistance, where the film ***embly meets the metal housing, or the contact terminal at the other end. But if the condenser is really really bad, the tester will find the problem.
  29. gary macdonald
    gary macdonald
    I bought a case or 2 of new old stock TIGER cdi ignition boxes . Ive been using 2 on different cars for over 15 yrs . No complaints.
    alanp561 and Norris McCarty like this.
