High group, I'm looking at a set of Holly 9776 which are 450 CFM carburetors. These carburetors do not have a choke, they do have the horn but no holes drilled in it for a choke ****erfly. Has anyone ever drilled the holes to add a choke to one of these carburetors (or carb similar) and how did you go about it Thank you.
That is a tunnel ram carb…. I guess there’s no reason why it can’t be done. Running it as a single carb?
Thank you Area 51, Im considering running two on a low riser dual quad manifold on a Ford FE 390. John
