Customs Adding power windows
Discussion in 'The Hokey Ass Message Board' started by chopolds, Jan 26, 2025.
  1. chopolds
    chopolds
    from howell, nj
    I need to put power windows in m Olds-Mad project. My 55 had them from the factory, and since I'm building a '98' type body style, it should have some luxuries.
    I haven't used any aftermarket PW kits on my builds, anyone have some honest reviews of kits they've used, esp. looking to long term use?
    SS327 likes this.
  2. BJR
    BJR
    I just got some from a 70's Cad in a junk yard. Took off the spring from the original stock regulator and the stem for the crank. Mounted the new regulator with the stem removed, but spring on, under the original regulator and ran an arm from the new to the old to raise and lower using the original regulator to keep everything in line.
    SS327 likes this.
  3. K13
    K13
    I used a Specialty Power Windows kit in my truck. Was super easy to install. Seems really well made. Haven't used it for long so can talk to longevity but I would use them again if I needed another kit.
    pprather likes this.
  4. ***Area-51***
    ***Area-51***
    from Ohio
    https://www.nu-relics.com/
    Check these guys out,
    I have no experience with them, I do know a couple guys that use them with no complaint.
    I think @BJR ‘s experience is worth looking at...
    okiedokie and abe lugo like this.
  5. Bandit Billy
    Bandit Billy
    I have 2 cars currently that I added Specialty PWs to. Easy install, work great, quiet and fast.
    dana barlow likes this.
  6. okiedokie
    okiedokie
    from Ok
    I have used Nu-Relics in four cars and they are top notch. They replace the original regulators and bolt in the same place. Easy to use and top quality makes them top on my list.
    SS327 and abe lugo like this.
  7. rdscotty
    rdscotty
    from red deer
    My Specialty Power Windows have been in use for 28 years without a hitch.
    firstinsteele and RMR&C like this.
  8. Bandit Billy
    Bandit Billy
    I'll add that 27 years ago I added power windows to my 442. I used GM motors and regs, I had to replace the motors last year on the fronts, but GM made a simple design, the motors are readily available (new and used) and wrecking yards are full of them last time I checked. Grab the harness and switches while you're at it.
  9. DDDenny
    My 66 Suburban has SPW units in it, also converted it to one piece door gl***.
  10. '49 Ford Coupe
    '49 Ford Coupe
  11. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Let us not forget this method.
    RMR&C and abe lugo like this.
  12. ebfabman
    ebfabman
    NuRelics for my 51 Merc. Top self product.
