1952-59 Ford Additives ?
Discussion in 'Off Topic Hot Rods & Customs' started by JeffB2, Dec 3, 2021.
  1. JeffB2
    JeffB2
    from Phoenix,AZ
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    Then there are more horror stories see column to the right for more.
  3. danman55
    danman55
    "temperature meter" lol oh my! :eek:
  4. Paul2748
    Paul2748
    I have a Ranger pick up (4.0 with an auto trans). One time when getting an oil change the shop ( I knew the owner well) put some Lucas junk in the trans with a trans oil change. After a while I started to have shifting problems (at the height of the pandemic). It took two more oil changes before the trans started to shift correctly. I thought I was in for a costly trans overhaul because of the Lucas.
  5. bobss396
    bobss396
    My dad years ago credited a Bardahl additive with screwing up a 235 Chevy engine. I recall it was in the shop for a few days. I've only used things in the past like STP and an old Alemite CD2 in engines that really burned oil. Today, I would go with straight oil only.
  6. TomDobbs
    TomDobbs
    Hmmm, I've been adding STP to motor oil for high mileage engines for the ZDDP for several years with no discernable ill effects, but I think I'll switch to the Lucas TB Zinc-Plus Engine Break-In Oil Additive. The Lucas additive won the contest hands down IMO.
  7. bobss396
    bobss396
    I took apart used engine that the owner admits to using STP in it. The screen on the oil pump looked like it was coated with honey and was caked on like wax. It may have reacted with something else he poured into it.
  8. TomDobbs
    TomDobbs
    That does it. :eek: I'm switching to Lucas at my next oil change. STP only goes in my steering box from now on.
