Technical Adjustable proportioning valve
Discussion in 'Traditional Hot Rods' started by Timothy Murphy, Dec 27, 2024.
  1. Timothy Murphy
    Timothy Murphy
    I’m building a ‘32 with new drum brakes on all 4 corners. When installing the proportioning brake valve do I just run the back brakes through this valve or should I also run the front brakes through it. The valve is a Speedway block valve with the brake light switch on it. It includes ports for the front brake line. Literature I’ve read in other publications do not show the front brake lines running through this valve. Thank you
  2. NJ Don
    NJ Don
    Just the back line will be fine.
  3. hepme
    hepme
    did the rears only on my 40.
  4. krylon32
    krylon32
    from Nebraska
    I plumbed 100's of ch***is in my ch***is business and always did the prop valve in just the rear brakes line. On another note I also did countless numbers of 28-34 ch***is with drums front and rear and never used a prop valve. I did always use an MC that had the residual valves built in.
  5. RICH B
    RICH B
    Sounds like you are describing a combination valve.
    A proportioning valve has only an inlet and outlet and incorporates an adjustment knob.
    Neither is required for a front & rear drum brake system.
    If the master cylinder does not have residual check valves (which aftermarket "Corvette" style masters do not) you need to install 10 psi valves in both the front and rear circuits.
    bschwoeble and clem like this.
