Technical ADJUSTING FLATHEAD FORD VALVES
Discussion in 'The Hokey Ass Message Board' started by Frames, May 13, 2023.
  1. Frames
    Frames
    Someone on the Ford Barn had a problem. No holes in the lifter bores to hold the lifter and the damn adjusting bolts were TIGHT. Johnson lifter wrenches broke. I purchased a nice 274 C I D flathead built. No holes. I made this tool. Drill bit schanks for pins. 2023-05-12 18.07.26.jpg Most likely the tool would break with his lifters. Worked great with Isky lifters in this engine. I did not know how to upload pictures on the Ford Barn.
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    Hi Dennis,
    Yes it is alittle more complicated.
    here’s a quick step by step.
    Hit “post new thread” or “reply”
    This window will show.
    hit the blue “go advance”*****on
    That will take you to the next window.
    In that window hit the “manage attachment”*****on.
    That will open up to this screen.
    Now hit the “chose file”*****on. That will open up your pictures for you to insert.
    alanp561 likes this.
  3. Budget36
    Budget36
    Also, the FordBarn is limited in size of the pic. You may need to resize the file, but years back I didn’t know how, many offered to have me send them the pic via email and they would resize it for me.
