Technical admissible concentricity defect on transmission shaft
Discussion in 'Traditional Hot Rods' started by elroots33, Jun 11, 2024.
  1. Hi guys,
    Today, I prepared my transmission shaft, narrowed to fit on my 32, before welding the 2 parts.
    I've built a bracket, with bearings, to tune the concentricity. (see the pic)
    After tuned it, the defect was 0.02-0.03 mm, that was really correct !
    After made 3 welding points to maintain the 2 parts together, the defect was 0.15 mm.
    Is that embarrassing for the shaft working ? And if no, for my information, what would be the max value to not overstep ?
    Thanks !
    winr and Sharpone like this.
  2. Fitty Toomuch
    Fitty Toomuch
    from WVa
    We don`t speak metric:rolleyes:
    Beanscoot and SS327 like this.
  3. Rich796
    Rich796
    To be fare, he is in France . . . That's about .0059" you can probably try to draw it back straighter. With some strategically placed spot welds.
    Unkl Ian and Sharpone like this.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
  5. shorrock
    shorrock
    The rest of the world does know metric - so your 0,03mm is slightly more than 1 thou. Those 0,15mm are slightly less than 6 thou. You could alternate the welding to reduce the runout but I would not worry up to 0,25mm - if you balance the shaft it will be corrected with weight. If not, get is as good as possible -heat and quenching is your friend.
    Unkl Ian, leon bee and Sharpone like this.
  6. gimpyshotrods
    gimpyshotrods
    For the SAE folks:
    0.15mm is 0.006".
    Six-thousandths of an inch.
    I've never seen an OEM driveshaft this good.
  7. Fordors
    Fordors
    Spicer, a major manufacturer of drive line components says allowable tolerance for the ends is .010 and .015 in the center. Of course less is better.
  8. Sharpone
    Sharpone
    Excellent home shop fixture! Welding without movement is an art form. Looks like the yoke is just tack welded, you could grind welds out and re weld. Use very small tack welds and check for concentricity as you go. Tack weld , second tack weld at 180 degrees and so on. Use a soft hammer to make minor adjustments as you go. I don’t think 0.15 mm is bad at all.
    Good luck
    Dan
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Not knowing how to convert mm to inches here in the States is beyond me. Guy’s there are conversion charts available at your finger tips these days.
  10. squirrel
  11. gimpyshotrods
    gimpyshotrods
    1-inch is 2.54cm.
    Or,
    1-inch is 25.4mm.
    Truckdoctor Andy and Sharpone like this.
  12. saltracer219
    saltracer219
  13. Thanks Dan for that !
    The yoke is just tack welded, yes, because my shaft is composed of 3 parts, the cut shaft, a machined sleeve which comes into the shaft tube and the yoke which comes into the sleeve, all these parts tack welded in the good position to have the good length. This waiting the final welding by a professional welder.
    The yoke is well adjusted, I measure the defect on the sleeve which has a very slightly play into the shaft tube.
    Sharpone likes this.
  14. Sharpone
    Sharpone
    The concentricity is very good, the professional welder will know how to keep it straight.
    By the way your English is very good.
    Send us a photograph of your car.
    Thank you
    Dan
    Unkl Ian likes this.
  15. Sharpone
    Sharpone
    I think it means You parle francais
    Dan
  16. Thanks for your compliment !
    I hope that the pro will know how to proceed to keep this good concentricity !!
  17. C'est vrai, çà ! :D
  18. Sharpone
    Sharpone
    True for some but not all
    Dan
    elroots33 likes this.
  19. Sharpone
    Sharpone
    Nice car what engine?
    Dan
  20. saltracer219
    saltracer219
    elroots33 and Sharpone like this.
  21. I’ve never indicated any DS I’ve ever cut
    Yours looks dang near perfect
    Carry on
  22. '66 Oldsmobile 330ci with Holley intake manifold and 2 weber DCNF carbs, hoping it works well !
    Adaptor between carbs and intake manifold is home made with VW beetle valve covers !
  23. Sharpone
    Sharpone
  24. Fordors
    Fordors
    That carburetion setup is very creative, well done!
  25. Is your "Ahhh" a negative or positive one ?
    Desoto291Hemi and Sharpone like this.
  26. saltracer219
    saltracer219
    Positive for sure, Olds engines are great engines!
  27. Sharpone
    Sharpone
    That’s a different perspective LOL I’ve always understood Ahhh as positive Especially when****ociated with an vintage V8
    Love this thread keep us posted
    Thank you
    Dan
    Desoto291Hemi likes this.
  28. 2OLD2FAST
    2OLD2FAST
    from illinois
  29. .02 mm works out to @ 0.000787402
    in machinist terms that is about 7 tenths and change. I have worked to +/- .0005 on a govt project (making parts with part numbers that was all they would let me know) so I am gonna say 7 tenths is plenty close enough.
    @elroots33 the driveshaft on my last 11 second streeter was about .003 0r @0.0762 off if I recall and it worked fine for at least 30K miles or 48280.32 KM. You are probably close enough.
  30. Just Gary
    Just Gary
    Cool taillight / license frame combo.:cool:
