Technical Advance or retard?
Discussion in 'The Hokey Ass Message Board' started by IowaTom, Jan 15, 2024.
  1. IowaTom
    IowaTom
    Guys - I've got an older F150 with the 300 c.i. straight six in front of a trusty NP435 four speed. Oil pressure is great and I'm sure compression is good also. Thing is, she bogs down trying to get up a hill. Now, it could be there's not enough fuel pressure since I'm using the small, red Edelbrock "clicky clacky" for fuel delivery, into a Carter YF knock-off. Could also be timing. Should I try advancing or retarding the spark - and which way do I twist the dist for either? Thanks so much!
  2. RmK57
    RmK57
    Clockwise for advance…..borrow a timing light as a little twist goes a long way.
    It would be easy if you had a fuel pressure gauge to see exactly what the pressure is. Going uphill in high gear would put the most demand on a borderline fuel pump, line, filter…..
  3. squirrel
    looks like they rotate clockwise, so you'd turn the distributor housing counterclockwise to advance it...till it pings...then go back the other way.
    But might want to get a timing light involved at some point. And check the other things that make it not want to go up hills. There are lots of them.
  4. 427 sleeper
    427 sleeper
    When is the last time you changed the fuel filter???
    mad mikey and chessterd5 like this.
  5. chessterd5
    chessterd5
    from u.s.a.
    okay, I am not the most mechanically inclined guys but I have one of those engines in my model T.
    yes make sure the screw in fuel filter at the carb is clean and DON'T strip it.
    those engines don't take a lot of fuel pressure, maybe 8 or 9 psi?
    I don't know what year engine you have but the later ones are a how should we say " managed" and advancing the timing is a little harder. if it is the regular Duraspark II system, you are good to go.
    if it is a stock engine with a stock cam, one of the best upgrades is to install a set of chevy straight six rockers. the increased rocker ratio will give a larger lift and duration to the valve timing and move the power band up in the rpm range. just make sure that the head has the right size rocker studs for the swap. Ford had two sizes on the 300.
  6. lostone
    lostone
    from kansas
    Like my ex wife used to say, "never call it retarded, it's "gifted""...
    427 sleeper likes this.
  7. lostn51
    lostn51
    from Tennessee
    Then I must be the most gifted son of a ***** in here!:D
  8. chessterd5
    chessterd5
    from u.s.a.
    what did one camshaft say to the other camshaft?
    G-son, hotrodjack33 and Desoto291Hemi like this.
  9. BJR
    BJR
    My lobe is bigger than your lobe?
    Your retarded, I'm advanced!
    427 sleeper, G-son and hotrodjack33 like this.
  10. JohnLewis
    JohnLewis
    The point where size does matter.
  11. Bandit Billy
    Bandit Billy
    It always matters. Women lie.
  12. hotrodjack33
    hotrodjack33
    Are you here for the duration?
    Happydaze, 427 sleeper and G-son like this.
  13. Ebbsspeed
    Ebbsspeed
    An increased rocker ratio will increase lift, but not duration.
    chessterd5 likes this.
