Technical Advice needed:BW T5 electronic to mechanical speedo drive conversion
Discussion in 'The Hokey Ass Message Board' started by Baumi, Mar 5, 2017.
  1. Baumi
    Baumi
    I´m trying to figure out how to convert my T5 from electric speedo drive to a gear driven version. I pulled the electric sending unit and it looks like a TH 350 driven gear housing will fit right in there. All I need to do now is put a drive gear on the output shaft , or am I missing something? IMG_4713.JPG IMG_4714.JPG IMG_4715.JPG
    the hole where the driven gear housing goes is about 22,7 mm or .89 inch... what I also noticed is that the hole is pointing to the output shaft in a 90 ° angle, aiming to the center of the shaft. I wonder how the drive gear would be able to engage with the driven gear in this configuration...
    Thanks for you help guys!
  2. spurgeonforge
    spurgeonforge
    I hope someone has a answer, I've got the same ?
    Baumi likes this.
  3. RMONTY
    RMONTY
    Do a search here. There is a member that converts electronic to mechanical. Can't think of his name ATM
    Baumi likes this.
  4. RMONTY
    RMONTY
    Kato Kings is his HAMB name. Do a search for T5 electronic. The search functions works pretty well.
    Baumi likes this.
  5. Baumi
    Baumi
    Thanks, I'll look him up!
