Technical Advice on power steering
Discussion in 'The Hokey Ass Message Board' started by Christie, Jan 7, 2023.
  1. Christie
    Christie
    I have a 55 ford fairlane that is quite difficult to steer. She has a 272 manual 3speed. I want to put power steering in her but I’m not sure what all it would entail, if I could even do it. Any advice, do’s, dont’s etc. are greatly appreciated!
    I have come to this forum so many times for help and you all have always come to my ***istance. thank you in advance
    Tow Truck Tom likes this.
  2. wc55
    wc55
    I have a 55 Meteor that had factory p/s, but I had problems with the steering box and fluid leaks. I went with a Borgerson box, and although it wasn't as easy or cheap as they would have you believe, once I got it in, it does work well. Better than original. You would have it easier because I had to find standard steering parts, idler arm and inner tie rod( I think, it's been a while).
    You can Utube this and go on the 52-59? social group to find more info. It makes driving the much more enjoyable
    Christie likes this.
  3. klawockvet
    klawockvet
    I believe Cl***ic Performance Parts has a kit. Its not that difficult to install
  4. Christie
    Christie
    !! Will have to check into that! Thank you!
  5. X38
    X38
    There may be multiple reasons for this. Maybe throwing power steering at it is hitting the panic ****on.
    "quite difficult to steer" is also relative. What is your benchmark?
    HSF likes this.
  6. miker98038
    miker98038
    Part of the problem is the 55 has the steering shaft in one piece from the box to the wheel. So it’s a long item to remove. The original p/s was an add on to the manual box. Pump, new center link with the valve, the ram, and some bits and pieces and hoses. The center link/valve is the hard part to come by. All other solutions are more difficult and involve cutting the shaft to adapt more modern parts. Last item is getting the wire for horn, it now runs clear down the column and out the end of the steering box.
    Some of the solutions don’t account for the column shift, so if you don’t want a floor shift watch out for that.
    Theres a fairly recent discussion on the Ford Barn, and probably info here in the social group for those cars. Mostly really off topic for here. Having been down this road, be really careful of simple solutions, it’s very easy to end up with limited turning ability and lots of bump steer. I get why you want it, 70+ years and a bad back makes power a necessity for me.
    Alkemy likes this.
  7. HSF
    HSF
    from Lodi CA
    First thing I would do is check and make sure all of your steering components are in good condition. Most steering problems I've encountered have been due to old worn out parts.
    Just Gary and Christie like this.
  8. I dont have power steering in mine and its nice and easy, do you have the stock wheel?
    HSF likes this.
  9. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Well next time, let's say your wife insists.
    You'll not get pushback
    firstinsteele likes this.
  10. X38
    X38
    I have experienced multiple times on different cars, that a simple change of tires - to another brand - has made a world of difference.
    Each time I have been amazed. I might also add, that I had not been seeking easier steering, just needed new tires.
    Christie and Tow Truck Tom like this.
  11. Mimilan
    Mimilan
    Column shift or floor shift??
    Adding power steering and retaining a column shift is difficult [especially on non-collapsible, one piece steering columns]
  12. Christie
    Christie
    Thank you everyone for your input.
    She is a 3 on the tree and I would like to keep her that way. So I may just **** it up and deal with no ps.
    I think I may just start with the two easiest possible remedies. Change the tires and double check out for worn parts.
    thank you again fellas , Christie
  13. HSF
    HSF
    from Lodi CA
    Brody knobs do wonders too. Cheapest, easiest power ***ist there is!
  14. oldiron 440
    oldiron 440
    The front end alignment can affect how easily it steers also.
  15. gimpyshotrods
    gimpyshotrods
    I make a point of never asking why someone wants power steering.
    Why?
    My shoulder took a 2-ton I-beam, driven by a gust of wind, while on a crane.
    I am 53, and it might need to be replaced. That's my business.
    Why she wants power steering is her business.
    https://www.borgeson.com/?target=search&mode=search&including=all
    This is NOT a difficult adaptation, and you can keep the column shifter. It utilizes ALL of your stock steering components, so there is no change in turning radius, or bump steer.
    Just a little cutting, a little grinding, and drilling a few holes.
    Christie and Truckdoctor Andy like this.
  16. Mimilan
    Mimilan
    To keep it 3 on the tree and add power steering would require a "Ram" setup.
    Not as good as a steering box but definately doable.
    You would need a correct pitman arm ,drag-link [centre-link]with the control valve, frame bracket , Ram ,hoses and pump.
    An Original rebuilt set-up would cost plenty.
    Have a look at T-bird set-ups [they might interchange]
  17. miker98038
    miker98038
    IIRC the tbird link is narrower. And very pricey these days.
  18. gimpyshotrods
    gimpyshotrods
    Kinda weird that this as been done before:
    Yes, that's an auto, but a manual needs 0.6" more.
    Truckdoctor Andy likes this.
